It is currently Fri Jan 19, 2018 2:57 pm
Post new topic  Reply to topic  [ 73 posts ]  Go to page Previous 1 2 3 4 5 Next
PostPosted: Sat Feb 08, 2014 4:24 pm
Angle of the cable guide doesn't sound like it's just cosmetic to me. People tend to retain respect for companies that own up to their mistakes and move on. That's not true when a company gives people the "these aren't the droids your looking for" treatment.
My Cervelo R5
My Lynskey Helix
My MTB
PostPosted: Sat Feb 08, 2014 5:31 pm
VNTech wrote:
The changes to 9001 have nothing to do with the cable issues. They were cosmetic, adding a cover on the inside of the shifter, between the hood and the brake lever.
Shimano does not believe it has a problem except in select, long-mileage cases. That's the quote. We had one break here at VN and they sent someone over to add a notched housing ferule to the right hand shifter housing, and greased the hell out of the cable. They also made a running change to the cables, adding more of whatever slickening agent they had been using before.
But that's it. They said the only reported cases had come from high mileage users who had not changed the cables.
More later.
Intrigued by notched ferule. Is this a change that could be copied by modding a
standard ferule? If so ? pics/diagram of notched one?
PostPosted: Sat Feb 08, 2014 6:43 pm
The bike we had the failure on had about 8k miles I believe. The idea was to test to failure (though we did swap chains in the middle).
I'll take a picture of the ferrule and post up, probably Monday.
VeloNews Magazine/VeloNews.com tech
PostPosted: Sat Feb 15, 2014 7:36 am
I'd like to see a picture of this as well. thanks!
PostPosted: Sat Feb 15, 2014 2:37 pm
Shop Wrench
9000 and 6800 both come with "notched" ferrules for the shifters. I'm guessing the bike was a complete that was built without them?
PostPosted: Sat Feb 22, 2014 5:54 am
I had about the same on mine before the same issue.
Compared to other brands (and the fact I've not had this happen with them), "high mileage" is an interesting reason to give...
Why can't brands simply admit when they've not gotten something right? It's not a murder trial - and we'd have a lot more respect for it.
VeloKicks
The Gram
The Men of Steel
PostPosted: Sat Feb 22, 2014 6:41 am
That's not how they think. They are trying to save "face". They take this very seriously.
PostPosted: Sat Feb 22, 2014 7:34 am
When I'm stuck in the 11 ten minutes in to a race and already off the front, I (funnily enough) tend to take it seriously too...
VeloKicks
The Gram
The Men of Steel
PostPosted: Sun Feb 23, 2014 11:17 am
I had DA 9000 fitted to my Parlee Z5SL when it came out. Replacing the trusty DA7800. Works brilliantly btw. Spoke to my LBS about the DA 9001 update and they said the cable issue only affected certain batches of 9000 and Shimano would replace mine if they were in the batch. Haven't had time to take it in for them to check yet, riding my CX bike most of the time in this weather!
Riding my road bike in North Wales
http://www.strava.com/athletes/keith_robertson
PostPosted: Sun Feb 23, 2014 10:36 pm
I have 8000 miles on my campag cables they are still like new so no need to change they have not failed either. I would not consider 8000 miles high mileage for cables normal if you are a campag user.
www.thecycleclinic.co.uk
PostPosted: Mon Feb 24, 2014 2:26 am
Campagnolo cables have a tendency to break inside the levers pretty regularly, not 8000 miles but not a whole lot more. Depends on how often you shift I guess.
PostPosted: Mon Feb 24, 2014 6:42 am
Got nearly 15,000km on my Campag cables. 2009/10 model 11sp SR shifter.
Not saying breaking doesn't happen. But I've tens of thousands of km's on Campag and now 9000 and the speed at which it occurs is a whole quicker in 9000. Which, it must be said, is about the only downfall of the groupset (brakes with poor modulation and a non-dedicated brake lever being the others).
VeloKicks
The Gram
The Men of Steel
PostPosted: Mon Feb 24, 2014 6:50 am
I've never used my 11 speed campag shifters long enough to break cables, but never got anywhere near 15,000 on my 10 speed levers without right hand cable breakage, or at least strand breakage.
PostPosted: Tue Mar 11, 2014 12:13 am
Cable finally failed yesterday, I would say I had done approx 5-6k miles on it. Kept the cable as I'm going to take a picture and send it off to Madison, the UK distributor tomorrow. Not impressed...
PostPosted: Tue Mar 11, 2014 12:55 am
No need to quote above
Please keep us updated.
I bought my shifters from Merlin Cycles, but I am living in Turkey.
Since I bought them from UK, I guess that I need to get them serviced in UK too.
After I get a few positive information about getting new shifters, I will demand a change too from them.
I will be in UK for 3 months in the summer time, so I can wait some and get things much more faster there...
My Orbea Orca
My Stava
My Instagram
There are no new unread posts for this topic. Dura ace 9000 rear derailleur?
sinjun
Mon Apr 10, 2017 6:02 am
richscott View the latest post
There are no new unread posts for this topic. Dura ace 9000 V 9100 brakes
scottmmw
Mon Oct 23, 2017 7:51 pm
evan326 View the latest post
There are no new unread posts for this topic. Tips for dura ace 9000 hood replacement.
SpecializedColnago
Wed Jan 25, 2017 7:21 pm
rossjm11 View the latest post
There are no new unread posts for this topic. 28C tyres on Dura Ace 9000 Brake Calipers
chutneyyy
Thu Jun 29, 2017 7:58 am
Delorre View the latest post
There are no new unread posts for this topic. Dura Ace 9100/9150 noisier than 9000!
James0133
11
3503
Sun Aug 20, 2017 5:44 am
James0133 View the latest post
Users browsing this forum: benzebub, Bing [Bot], bobones, Chris3g, keaton, tonytourist and 39 guests
