sram exogram rings??
ninjanoir78
by ninjanoir78
hi, do you think a 50T exogram 2014 with small 36 2011-2012 previous model would be ok?? or I really need 50-36 in exogram??
thanks
Ninja
deek
by deek
Depends how picky you are. Rings are definitely designed as a pair so that the chain can transition smoothly between rings. So shifting won't be nearly as good with your 36 as it would be with the 34. I'm not saying that it won't shift, just that it won't be very smooth.
Also there is no 50/36 Exogram combo.
ninjanoir78
by ninjanoir78
but I guess 50-36 shift better than 50-34
Ninja
FIJIGabe
by FIJIGabe
No, 50-36 won't shift better than 50-34. The 50-tooth ring is designed to work with the 34-tooth ring. The ramps are setup for the 34. 36 will work, but the physical shifting won't be as smooth, and in tight situations, you may have problems.
ninjanoir78
by ninjanoir78
FIJIGabe wrote:No, 50-36 won't shift better than 50-34. The 50-tooth ring is designed to work with the 34-tooth ring. The ramps are setup for the 34. 36 will work, but the physical shifting won't be as smooth, and in tight situations, you may have problems.
ok, and what you are saying is just about exogram ?? cause with my 2011 sram black, I have 50-38, 50-36 and 50-34 and no problems at all..
Ninja
deek
by deek
Like I said, depends how picky you are. You'd probably be fine with the 36, but I don't really see the point in switching to Exogram since those rings are heavier and you don't seem to care about shifting too much.
ninjanoir78
by ninjanoir78
deek wrote:Like I said, depends how picky you are. You'd probably be fine with the 36, but I don't really see the point in switching to Exogram since those rings are heavier and you don't seem to care about shifting too much.
I broke my 50 sram black.. and its easier to get exogram than black ring here...
Ninja
JasperGr
by JasperGr
Sorry for kicking this topic to the top but I have a question about the chainrings. On the bike of Cavendish last year I saw the black sram chainrings. Does someone knows where to buy those chainrings? Prefer compact.
