It is currently Sun Jan 21, 2018 8:14 am
Post new topic  Reply to topic  [ 12 posts ]
PostPosted: Sat Nov 09, 2013 10:21 am
Hi
I am going to put Ui2 on my bike and been advised for a cleaner look to put the battery in the seatpost.
Unfortunately my Pro Vibe 7s aluminum seatpost isnt Di2 ready.
http://www.parker-international.co.uk/1 ... post-.html
Rather than buying a Di2 compatible seatpost I wondered if either of these battery holders would work with my existing seatpost?
http://www.3tcycling.com/accessories/battery-holder
http://dedaelementi.com/index.php?page= ... 94&lang=en
Thanks
PostPosted: Sat Nov 09, 2013 3:28 pm
Just use some cheap foam and tie it up with some cable ties and you are all set. Simple and easy.
PostPosted: Sat Nov 09, 2013 6:41 pm
I've used this one. Works on all seatposts of standard sizing. Two sizes to chose from.
http://ritcheylogic.com/road/seatposts/di2-seatpost-battery-mounts.html
PostPosted: Sun Nov 10, 2013 2:36 pm
If u want lighter, just go a lipo stick battery and fix it into the seatpost with space invader foam insulation in a can...
PostPosted: Sun Nov 10, 2013 2:56 pm
Thanks for help guys, will probably go for one of these suggestions :)
PostPosted: Sun Nov 10, 2013 3:59 pm
[/quote]If u want lighter, just go a lipo stick battery and fix it into the seatpost with space invader foam insulation in a can...[/quote]
Have you done this yourself? If so which battery did you use, I have done an internet search and the range of lipo slim line batteries is mind boggling :shock: Thanks :D
PostPosted: Mon Nov 11, 2013 1:35 am
DELETED.
PostPosted: Mon Nov 11, 2013 1:37 am
PostPosted: Mon Nov 11, 2013 6:26 pm
I used a similar method to the above, though I wrapped it in a single layer of packing foam and jammed it down inside the seat tube rather than up into the actual post. Lower COG and slightly shorter cable required..
PostPosted: Mon Nov 11, 2013 6:35 pm
will the battery eventually slide down due to all the bumps you hit on the road?
- AX Lightness Vial EVO D + DA9070 + Enve SES 3.4 carbon hubs
- Parlee ESX + DA9070 + THM SRM PM + Enve SES 6.7 CK hubs
- Independent Fabrication Ti FLW + Campy SR11 + Enve 3.4 CK hubs
PostPosted: Mon Nov 11, 2013 6:43 pm
Not in my case as it is sitting nice and tight and my seat tube tapers right down to shape around the wheel, although it's a valid consideration to raise for those with cylindrical tubes. No different to fitting it into the post I suppose - common sense approach to make sure it won't move over time.
PostPosted: Wed Nov 20, 2013 5:33 am
Have you done this yourself? If so which battery did you use, I have done an internet search and the range of lipo slim line batteries is mind boggling :shock: Thanks :D[/quote]
Sorry for late reply...
Yes I have done this many times with ui2 battery conversions... Very easy to cut down the mount to a very small size to run inline, in the seat tube... The selection of lipo stick battery depends on the size you have to play with, the mAh capacity u want to run, and weight considerations. I run a 1600mAh battery with my 7970 setup, and get about 7000kms out of it between charges...
This is the exact battery I run:
http://bit.ly/19FlnIf
There are no new unread posts for this topic. Pro Vibe Seatpost w/ di2 battery
raggi
Tue Oct 24, 2017 10:44 pm
raggi View the latest post
There are no new unread posts for this topic. EW-WU111 with a SM-BTR2 battery for only ANT+?
Gearhead65
10
1786
Tue Mar 07, 2017 8:05 pm
Pokerface07 View the latest post
There are no new unread posts for this topic. Di2 battery drain problem
quango2k
Tue Feb 21, 2017 1:30 pm
There are no new unread posts for this topic. Campagnolo EPS V2 Battery Repair
Diverse
Sun Mar 19, 2017 5:11 pm
ferrarista View the latest post
There are no new unread posts for this topic. Mysterious Di2 battery drain
havana
26
2310
Fri May 26, 2017 6:45 am
eaglejackson View the latest post
Users browsing this forum: Delorre, maxxevv, Zakalwe and 32 guests
cron
