It is currently Fri Jan 19, 2018 8:58 am
Post new topic  Reply to topic  [ 4 posts ]
PostPosted: Thu Nov 07, 2013 10:49 pm
My problems with this rear hub continue. The axle is now broken after two/three months of light usage and needs replacing. I am posting here because Novatec company policy is not to respond to end user enquiries in respect of problems like this, and there is seemingly a lack of information on servicing these hubs on the internet.
1/ Okay ... I remove each of the sidecaps. I pull off the freehub body. The axle is now still sitting in the hub shell, with both ends sticking out either side - but how do I get the axle out? It is held firm.
2/ Anyone know if an F482SB axle and an F582SB axle are one and the same thing?
Thanks folks.
PostPosted: Fri Nov 08, 2013 12:29 am
Hi, you will need to remove one bearing from either end as this is what's holding the axle in place. This also means pressing in the bearing again once you have fitted the new axle. Make sure you have the right tools to press the bearing in again.
PostPosted: Fri Nov 08, 2013 2:03 am
Yup. I got it. You whack the DS end of the axle with a hammer to drive out the NDS bearing, and then you whack the other end of the axle to drive out the DS bearing.
Anyone know if F482SB and F582SB axle is one/same thing? Thanks.
PostPosted: Sat Nov 09, 2013 4:16 am
Yes, they are exchangeable, F482 has Shimano cassette body and F582 is for Campy, otherwise they are the same.
There are no new unread posts for this topic. Attachment(s) Need help - Is this cassette body from Novatec F482 rear hub?
itspat
Thu Nov 23, 2017 9:54 am
alistaird View the latest post
There are no new unread posts for this topic. Can anyone tell me what kind of hubs these are?
bjbbiker
Tue Jun 27, 2017 8:14 pm
bjbbiker View the latest post
There are no new unread posts for this topic. Which Skewers for Chris King R45 Hubs?
dim
Sun Jan 07, 2018 8:44 pm
jrccomponents View the latest post
There are no new unread posts for this topic. Attachment(s) Servicing Campag Record OS silver hubs (pre-2006)
Eleven21
Tue Nov 28, 2017 9:21 pm
Bondurant View the latest post
Users browsing this forum: cyclenutnz, kdawg, kgt, kyleFu, nlop, slake21 and 27 guests
