SRAM Red 2013 with older cranks
by Peter_E
Hi, I have SRAM red cranks w Stronglight CT2 rings (50/39) on my bike. Rest of the group is Campagnolo 10 Speed. It works great bit the campy stuff is getting a bit old. Considering getting some used 10 speed SRAM red stift next year. Will teh group from 2013 w yaw derailleur sork with those cranks? I seem to recall something about different spacing of the rings on 2013 cranks?
Skickat från min Nexus 7 via Tapatalk 2
Frankie - B
by Frankie - B
I use it myself, works fine.
by madcow
I'm using the Red22 stuff with a pair of EE prototypes which were built for 10 speed Shimano and it works really well.
by CharlesM
The 2012 / 13 front Der works really well.
That said, if by "older" you mean 2011 Red or older, the chain rings will not be as high quality as 2012-13 (and or Praxis in the case that's what is on the EE).
Pre 2012 will work, but chain pick up has a little lag.
by kbzoo
I'm using the 2013 Red with a Zipp Vuma Quad crank and it works fine.
by Peter_E
Thanks guys.
Skickat från min MT15i via Tapatalk 2
by fogflip
Should work you can get some yaw rings for your old crank set I did that with my Quarq elsa...
