Campagnolo discs?
Miller
by Miller
mattr wrote:Its to reset/refill/top up the hydraulic circuit.
It allows for wear of the pads and heating of the fluid. Not having the piston go back past the port on the actuation side of the unit will lead to (eventually) the brake losing all power.
It's still not a problem. Just open out the brake quick releases from time to time and give the levers a few squeezes. I haven't lost any power on the brakes and I've been running them since October. They're working just fine.
mattr
by mattr
Yeah. that'll sort the issue.
it's not ideal, but it is a functional workaround.
Guinea
by Guinea
I made the switch last night.
Released the leavers, then set the TRP to spec. When I engage the levers correctly and tighten up the barrel adjustor the brake feels good.
I only use this bike for a ~52km commute, so every day I'll release the lever and give them a pump.
This isn't ideal, but it saves me making some more expensive changes later.
Thanks!
Miller
by Miller
Yes, if you can get enough travel the brakes are very good. Don't ignore replacing the housing with a compressionless option, it made a surprisingly positive difference for me.
Miller
by Miller
Digging up an old thread, what are the options for a Campag 11-speed disc hub this year? Looking for 135mm 6-bolt hub with 11-sp cassette carrier and quick release fitment.
Valbrona
by Valbrona
Mavic - but lots of other disc wheels out there in both Campag and ShimRAM flavours.
Donn12
by Donn12
I have campy chorus on my CX bike. I Had bb5s and bb7 road brakes on the bike and the brakes were garbage because of the lever pull. I switched to compressionless housing and problem solved. I have also bought a synapse disc bike and those brakes are incredible....but when campy finally has hydros I will take the shimanos off.
mvacolnago
by mvacolnago
I have been using a set of these Juin Tech R1's on my cx bike (SR-11) king/enve wheels. They are pretty amazing, close as straight hydro that I have found
http://www.edgesportsuk.com/store/index ... -road.html
Miller
by Miller
I would not want to get that Colnago dirty.
To answer my own question the likely contender is Novatec D772.
Benno
by Benno
FWIW I believe the TRP Spyre to be the best mechanical disk caliper by a long shot. Ingeniously they are dual piston and deliver a much better brake feel than any of the other single piston options.
Light. Strong. Cheap. Pick one.
ultimobici
by ultimobici
Miller wrote:Digging up an old thread, what are the options for a Campag 11-speed disc hub this year? Looking for 135mm 6-bolt hub with 11-sp cassette carrier and quick release fitment.
Hope, White Industries, King R45 Disc.
bigfatty
by bigfatty
have a friend who made his own cable to hydraulic adapter. did a quick search and I see there is an actual product on the market for this. do not know how great it is but it may be an option.
http://www.cxmagazine.com/trp-parabox-h ... first-ride
sugarkane
by sugarkane
Wtf!! Why? Such a waste of engineering. Combining all the short comings of hydro disks and cable disks in to one really heavy package...
bm0p700f
by bm0p700f
I have record 10 speed and tektro hyrd calipers on 160mm rotors. I use compressionless casing. There is no lever throw issue i pull the lever and the brakes work very well indeed. There is enough braking torque and these brake saved my bacon earlier this year. Simply wonderful. If you do have lever pull issues it is down to the brake setup or how else i have i got mine working. I did not set mine up with the arm locked in position either.
bm0p700f
by bm0p700f
As for campanolo compaitble disc brake hubs i have used novatec d772 but miche , hope white industries and royce do hubs too. Chris king have an over priced hub as normal.
Miche syntium is a pretty good alternative to hope i think. any shimano hub though will work with an 11 speed cassette and campanolo 11 speed. Opening up dt swiss hubs.
