Where is the best place to add weight?
deltree
by deltree
aaric wrote:Heavier cassettes and skewers would be my first choice.
Skewers are the only place I don't try to save weight.
But seeing as the OP is trying to add almost 1000g I'd go with a weight in the seat tube.
Zoro
by Zoro
Conclusion:
I will be using a 2nd heavier weighted seat and post that can be used if they are weighing. Primary reason is it is a quick change unlike other parts. Skewers - are good, but not enough weight. Cassette - maybe 200g. Seat setup seems easiest.
Otherwise - riding the normal bike most the others are.
davidalone
by davidalone
adding functional weight is easy.
the heaviest functional groupset you can get (105 or new tiagra,) skewers, alloy cockpit, a heavy chunky stem ( that will be stiff as hell.) skewers, casette, a hardier chain ( think 105 or tiagra level instead of DA.) heavier saddle and seatpost, and pedals . I think all these shhould gain you a good 300-500 odd grams.
Chainsnapper
by Chainsnapper
Stiffer hubs, skewers, HD chain, crank arms.
g32ecs
by g32ecs
No idea on why hasn't anyone suggested:
1. heavier wheelset - just use tires that have low rolling resistance
2. cranks
3. saddle (very cost effective)
These parts are the heaviest on the bike.
AlphaDogCycling
by AlphaDogCycling
Drop weights in the seat tube. You can easily add / remove as necessary.
Good luck to your son
Zoro
by Zoro
They rattled in the seat tube.
New solution.
http://1drv.ms/1ChEGsK
em3
by em3
DMF wrote:Just place a cylindrical steel-weight inside the BB-axle, if you have Shimano cranks you already even have a bolt that stops it coming out. With Campaq/Sram you just duct tape around it 'til the fit is snug.
Low center of gravity - Good
High center of gravity - Just crap handling, the seat mounted bottles work for triathlon as active handling is of no.concern
+1
BB area should b only place where weight is added for center of BB issue stated above. No need to change components just slide weight into ur hollow crank spindle
______________
