Light grease for cermaic hub bearings?
OwenJames
by OwenJames
Hi
I am looking for some light grease for the ceramic bearings in my Extralite UltraFront SPM front hub, and wondered if anyone had any recommendations?
I would like something with minimal drag, of course. I am not shy of taking things apart and regreasing every time I ride in the rain (which I try not to do ever), so the grease does not need to be mega weather proof.
Well, cheers in advance!
Owen
atakaoka
by atakaoka
cycling,a great individual sport,were you can't reach anything,whithout group effort.
OwenJames
by OwenJames
Nice one! Will check these out. Thanks a lot.
stella-azzurra
by stella-azzurra
Ceramic grease :lol: :roll:
Q: Do full ceramic bearings need lubrication?
A: No, full ceramic bearings can be run completely dry. They do not need lubrication to run. Ceramic is non-porous, unlike steel, as a result it is virtually frictionless. Ceramic also dissipates heat very quickly, which is the same reason they use it on the underside of the space shuttle. Because there is no heat buildup and virtually no friction, full ceramic bearings can be run completely dry. They can be cleaned out with regular tap water or any cleaner, they are impervious to corrosion and can operate in a vacuum environment.
http://www.bocabearings.com/faq.aspx#help-g16
DMF
by DMF
Stella, you only forgot that we use hybrid ceramic bearings for the most part on bicycles, the bearing race is metal, or it would shatter and crack when used in a hub or headset, even in a BB it's a poor idea with full ceramics.
stella-azzurra
by stella-azzurra
Yeah I have have the stainless steel race with ceramic bearings from VBX which come with grease. Although I question the use of "ceramic" specific bearing grease.
So we have a stainless steel race with ceramic bearing which really do not require grease to begin with.
The steel does to some extent so then would you need ceramic specific bearing grease?
DMF
by DMF
Kind of like saying "Do you NEED to save 1 gram on bolt tuning", every 0,1w matters as much or more than 1g. It's the weenie lifestyle.
by 5 8 5
OwenJames wrote:I would like something with minimal drag, of course. I am not shy of taking things apart and regreasing every time I ride in the rain (which I try not to do ever), so the grease does not need to be mega weather proof.
Use a light oil for least drag if you're prepared to service the hub regularly.
