It is currently Tue Jan 16, 2018 8:39 pm
Post new topic  Reply to topic  [ 1 post ]
PostPosted: Mon Nov 04, 2013 3:56 pm
Hi guys,
I have a question about the wire running from junction B to the battery for 7970 Di2.
Let me explain my situation:
My old bike (Addict SL) was running the full external wiring harness, with an internal seat post battery (bought from eBay seller 'eapathome'). To achieve this I cut the battery wire, and soldered red-red and black-black to the internal battery. The wire was run through the drain hole at the bottom and rear side of the seat tube, found on most Addict frames. This worked perfectly.
My newest bike (S-Works Venge) is now running the full internal wiring kit (EW-7975). I have cut the wire running from the battery holder to the internal connection (with the 6.5mm non-waterproof 4 pin connector) with the intention of soldering the plug (and run of wire still attached) to the wire from my internal battery.
Upon stripping this wire, I have found that it contains 2 red, and 2 black wires within it. This is different to the external harness battery wire which only contains 1 red and 1 black.
My dilemma:
I need to know which pins require power from the battery and thus which wires should I connect my battery to.
The options are either to join my internal battery wire to either one, or both wires at the same time.
At this stage I'm not willing to touch wires and 'see how it goes' so I thought I'd see if anybody has has experience with this.
My next step is to buy a multimeter and try and determine which wires go where, both around the harness itself and to which pin at the internal battery connector.
Thanks,
Tom
:beerchug:
There are no new unread posts for this topic. Gold derailleur inner wire
NiFTY
Sun Sep 03, 2017 1:12 am
NiFTY View the latest post
There are no new unread posts for this topic. Sidi Wire -vs- Gaerne G Stilo pretty unbiased
wheelbuilder
19
1948
Tue Nov 28, 2017 10:58 pm
PJCM View the latest post
There are no new unread posts for this topic. Campagnolo EPS V2 Battery Repair
Diverse
Sun Mar 19, 2017 5:11 pm
ferrarista View the latest post
There are no new unread posts for this topic. EW-WU111 with a SM-BTR2 battery for only ANT+?
Gearhead65
10
1753
Tue Mar 07, 2017 8:05 pm
Pokerface07 View the latest post
There are no new unread posts for this topic. Di2 battery drain problem
quango2k
Tue Feb 21, 2017 1:30 pm
Users browsing this forum: Baidu [Spider], Bing [Bot], Flasher, Google [Bot], Malammik, sun, sungod and 37 guests
cron
