SRAM 11 Speed Cassette
lotushiast
by lotushiast
Hello,
will a SRAM 11 Speed Cassette work on a 10 Speed Hub?
Thanks!
prendrefeu
by prendrefeu
No.
btompkins0112
by btompkins0112
Depends. Do you have access to a machine shop?
MoPho
by MoPho
It seems most are modifiable to accept 11-speed.
http://glorycycles.blogspot.com/2012/10 ... -some.html
RichTheRoadie
Tinker, Taylor, Tart
by RichTheRoadie
So Mavic wheels will work without the spacer? Now that *is* interesting...
Also (and yes I have said this on at least three other threads already) the 11spd Campag spacing will work on Shimano/SRAM 11spd groups. I'm running a Chorus cassette with 9070 Di2 perfectly. If your hub can be switched to Campag that might be an option for you.
Gearhead65
by Gearhead65
May check to see if you can purchase a 11s replacement freewheel for your hub.
2015 Specialized Crux Pro
2013 BMC TMR01 custom build
2013 Cannondale F-Series 29'er, Carbon 3
2012 Cannondale CAAD10-1 custom build, 14.06 lbs
1980 Palo Alto custom build
