Ultegra 6870 Di2 with SRAM 1190 misc questions
Gearhead65
by Gearhead65
I am looking to install a new Ultegra 6870 Di2 mini-group. I would be running it with a Dura-Ace 7900 crank.
My question/slight concern is I would like to use a SRAM 1190 cassette (partially because of some of the negative reviews on the Dura-Ace 11 speed cassette).
Any reason the 6870 would not 'play well' with an 1190 cassette?
recommendations on 11 speed chains for this setup?
Thanks...Di2 newbie.
2015 Specialized Crux Pro
2013 BMC TMR01 custom build
2013 Cannondale F-Series 29'er, Carbon 3
2012 Cannondale CAAD10-1 custom build, 14.06 lbs
1980 Palo Alto custom build
Chello
by Chello
A Sram cassette will work perfectly with that setup.
For a chain I would go with either of the Shimano offerings or a KMC.
RichieE46
by RichieE46
I switched from Shimano ultegra chain to KMC DLC. Seems a little quieter on shifting, but no complaints on either chains.
Sent from my GT-I9505 using Tapatalk
Tamu8104
by Tamu8104
Should work fine. I'm currently using 9070 with a SRAM 1190 and KMC X11SL chain.
Gaulzetti Cabron Disc = (weight unknown)
Rock Lobster Team Tig SL Disc = (pending)
Sold: Ridley X-Night Disc = 7.80 kg | Ridley Noah FAST = 6.86 | Ridley Fenix = 6.74 | Raleigh HiLife = 7.46 | Fuji SST = 7.34 | Van Dessel FTB = 7.58
rmerka
by rmerka
Only issue I've seen using the 1190 cassette with the DA chain was very noisy, rattling sound, when shifting. Otherwise quiet, just when shifting. If you're going with that cassette get a SRAM or KMC chain.
Gearhead65
by Gearhead65
Thank you for the replies. I'm probably going to start out with an Ultegra chain after all based on some pricing I'm getting.
