It is currently Sun Jun 25, 2017 2:53 pm
Post new topic  Reply to topic  [ 6 posts ]
PostPosted: Wed Oct 30, 2013 5:28 am
I have a PF BB30 bottom bracket, running Campagnolo cups.
Since I run EPS, I have the spindle protector installed inside between the 2 cups to protect the wires from the rotating spindle.
I am about to fit the new V2 internal battery and need to remove the cups in order to gain access to the wires to remove the external battery and install the internal battery.
Ordinarily, without the spindle protector fitted, you would just pop the cups out using a splayed headset cup removal tool. However, because of the sleeve, the tool will not splay out to engage the cups.
Any ideas on how to remove the cups by any other method?
 Post subject:
PostPosted: Wed Oct 30, 2013 6:09 am
PostPosted: Wed Oct 30, 2013 6:26 am
A puller won't work unfortunately. Same problem as the headset tool.
Namely that the protective spindle sleeve is narrower internally than the cup and there is nothing for the puller to get purchase on.
I might have to destroy the sleeve somehow. Then either method will work. I was trying to avoid that though.
 Post subject:
PostPosted: Wed Oct 30, 2013 7:09 am
PostPosted: Tue May 31, 2016 12:21 pm
Bring up old thread.
I am in same dilemma now.
I am also trying to pop out PF30 cups but dont want to ruin plastic sleeve.
Anyone got solution?
You only live twice
PostPosted: Tue May 31, 2016 12:36 pm
A large bearing puller?
There are no new unread posts for this topic. Removing Sram Red BB30 self extracting collar
NiFTY
Wed Oct 12, 2016 1:56 pm
sungod View the latest post
There are no new unread posts for this topic. Campagnolo UT SR BB Cups - difference between 2011 and 2015 versions?
RJKflyer
Tue Apr 11, 2017 9:49 pm
Calnago View the latest post
There are no new unread posts for this topic. Campagnolo Record EPS Compatible Ultra Torque cups vs standard
Slimtim
9
568
Fri Oct 21, 2016 2:29 pm
goodboyr View the latest post
There are no new unread posts for this topic. Campagnolo C-clip on drive side EPS Ultra Torque cups
58teeth
Fri Jul 01, 2016 11:26 pm
58teeth View the latest post
There are no new unread posts for this topic. Removing 2015 Campagnolo rear derailleur from hanger
timmbo
12
1167
Sat Jan 14, 2017 1:41 pm
timmbo View the latest post
Users browsing this forum: Attermann, hlvd, LouisN, possibleweenie, sungod, tibikeboy, Yahoo [Bot] and 30 guests
