Committing an atrocity: DA7900 calipers with campy shifters
seanblurr
by seanblurr
Has it been done? Could it theoretically be accomplished?
You might be asking why… Well, I fell in love with the braking on my friends Dura ace equipped bike, so much so that I want to buy a pair, paint them black, and throw them in with my SR11 group set. What makes this situation even worse is that fact that I live in Campagnolo world. Vicenza, Italy. Literally on the same road as their factory. Despite this, I am full willing to commit this horrendous act to bring my braking performance on par with his complete 7900 bike. Should I do it? Should I slam my face into my desk, shut up and ride on?
Thoughts? :beerchug:
Instagram @seanblurr
prendrefeu
by prendrefeu
Just don't brake.
That way you'll never know what you're missing.
ultimobici
by ultimobici
seanblurr wrote:Has it been done? Could it theoretically be accomplished?
Aside from your heresy, are you sure that the set up is not the reason your "friend's" brakes feel better?
mrfish
by mrfish
Go for it, I think it's a cool idea. If you are good with paint then a screenprinted white Prototypo would keep your local friends guessing.
seanblurr
by seanblurr
Could be. My bike has more miles then his set up does, that could play a role as well. We used to run the same wheels, I however, Just made an upgrade to a full carbon wheel. So that will dramatically change the feel from what I hear. That is partly what sparked my quest for better braking…
kode54
by kode54
seanblurr wrote:What makes this situation even worse is that fact that I live in Campagnolo world. Vicenza, Italy. Literally on the same road as their factory. :
not sure you should attempt to go that route. change the pads and see if that helps…or get an aftermarket brake like EE Cycleworks…which i love on both of my bikes (one campy and the other shimano).
- AX Lightness Vial EVO D + DA9150 + Enve SES 3.4 carbon hubs
- Parlee ESX + DA9150 + THM SRM PM + Enve SES 6.7 CK hubs
- Independent Fabrication Ti FLW + DA9100 + Enve 3.4 CK hubs
Geoff
by Geoff
Nope. I think you'll find that Campagnolo and Shimano both pull different cable rates for shifting and braking.
I am a bit surprised about the cause of your question, though. I actually prefer the Campagnolo lever feel, although the Shimano is plenty powerful. I find that Campagnolo is better for me from the 'hoods.
If you do try it, make sure you report back and post pics...
Valbrona
by Valbrona
Do the Malaysian brakes actuate on cartridge bearings like Record/SR?
Calnago
by Calnago
...Should I do it? Should I slam my face into my desk, shut up and ride on?
Thoughts?
The second... slam it and shut up. (you gave a choice, I chose the second) :noidea:
Frankie - B
Administrator
by Frankie - B
Moved to road.
JackWalk
by JackWalk
seanblurr wrote:Could be. My bike has more miles then his set up does, that could play a role as well. We used to run the same wheels, I however, Just made an upgrade to a full carbon wheel. So that will dramatically change the feel from what I hear. That is partly what sparked my quest for better braking…
Carbon wheels will make a massive negative difference to braking performance compared to an aluminium braking surface. It makes the brakes feel more sluggish. Did you put on carbon specific pads when you changed wheels? If you didn't try that and see if that feels better
seanblurr
by seanblurr
I will. Haven't put the new wheels on yet. The caparison was made with the same Cosmic SL wheels. Stock pads.
DMF
by DMF
The braking will be much mushier and more powerful with less wheel clearance than a full 7900 setup. The 7900 is 1:4 pull ratio, Campagnolo is closer to 1:3. 7900 levers with Campy brakes would give you a firmer lever feel, more clearance and less braking power.
So short answer you will get mushy but powerful braking. It will not feel like your friends brakes.
Svetty
by Svetty
If you think 7900 brakes are good, wait til you try 9000 ;)
stella-azzurra
by stella-azzurra
Looks like people have yet to understand how to set up brakes and why braking feels different from rim and pad type used. :noidea:
DA and Campy all can have the same reliable braking if you understand what you are doing.
I have Gravity, Shimano and Campy and they are all set up to brake the same way except for the center pull c-records. Those are totally designed differently but I have them set up to feel similar to the regular campy brakes. They are equipped with KoolStop brake pads for better braking over the original brake pads.
