Colnago C60 when will it be?
fromtrektocolnago
by fromtrektocolnago
ianSWBB wrote:A great afternoon at South West Bike Builders today
Got our hands on a C60 frameset - photos on our facebook page - just follow the link below
The Seat Tube and Down Tube are massive!!!!!
BB was interesting - a large hole with an alloy insert, with screw in cups, that will then house an 86mm pressfit BB!!
fork was the same as the C59 fork - double checked it!
can't wait to get one built up and test ridden now :D
regards
ianSWBB
Thanks for posting. I guess the expression "form follows function" certainly applies here.
Colnago C-59 (Dura Ace)
Firefly(Ultegra)
Trek 5200(ultegra)
nobrakes71
by nobrakes71
@calnago - thanks for the info on the MTBK you are building. I guess it all depends on the dealer you are using to get those special orders. I found it quite hard to get the colour scheme I wanted when I was ordering my C59 so ended up going for the stock options.
I was doing some research on the C60 bottom bracket, and I guess that I'll need these cups to fit my Chorus Cranks:
http://www.campagnolo.com/jsp/en/groups ... atid_3.jsp
and I'll have to spend some more cash to buy a press fit tool too. Campagnolo says I have to use their own otherwise I might die:
"The use of any other tool may cause damage to the cups and lead to accidents, injury or death"
There is a video on youtube showing how it's done
https://www.youtube.com/watch?v=gjxEPtjk3yY
topgun06
by topgun06
nobrakes71 wrote:I was doing some research on the C60 bottom bracket, and I guess that I'll need these cups to fit my Chorus Cranks:
Well that is my understanding also. I've been doing some research for a build myself.
nobrakes71 wrote:and I'll have to spend some more cash to buy a press fit tool too. Campagnolo says I have to use their own otherwise I might die:
Are there any recommendations for a suitable press fit tool? Campag's £80 offering is a bit steep... I have only used a very very cheap one when installing a headset before.
ianSWBB
Shop Wrench
by ianSWBB
nobrakes71
Yes, they are the correct cups you'll need
Yes, the campag press fit tool works best - but you will find that any decent bearing press tool can be organised to do the job!
regards
ianSWBB
Zakalwe
by Zakalwe
Surely the dealer you buy from will be decent enough to press your cups in for zero cost?
tortor
by tortor
ianSWBB wrote:fork was the same as the C59 fork - double checked it!
ianSWBB
I have some doubts on the fact that C59 (2012) and C60(2014) forks are the same.
Emonda SLR
7 Sola 8.100gr
C59 TSMR
Extreme C PR82
tortor
by tortor
I really love my C59 and M10. And I must say that for my possibilities and power their stiffness is enough :-)
I have some doubts on the C60 esthetics and behaviour. On my Opinion, tubes are too large, too square. It looks like a exaggerated caricature of the C59. I think Colnago will continue to sell C59 for some years :P
Emonda SLR
7 Sola 8.100gr
C59 TSMR
Extreme C PR82
ianSWBB
Shop Wrench
by ianSWBB
@tortor
OK!! I will be more precise - the 2014 C59 fork is the same as the 2014 C60 fork!!
regards
ianSWBB
tortor
by tortor
Thanks.
Right. On your picture of C59 2014 fork seems to be different than my C59 2012 fork, but same with C60 fork.
One model production is probably easier than two different models
Emonda SLR
7 Sola 8.100gr
C59 TSMR
Extreme C PR82
HillRPete
by HillRPete
From ianSWBB's FB: https://www.facebook.com/photo.php?fbid ... =1&theater
Does anyone else think they might have been able to find a spot for the charging socket, that was not quite as exposed to spray and dirt from the road?
markyboy
by markyboy
ianSWBB wrote:@tortor
regards
ianSWBB
My 2014 c59 fork is not the same as the c60 fork
COLNAGO C60 SUPER RECORD EPS
Pinarello f8 sram etap
Eddy merckx 69 ultegra disc winter bike
ianSWBB
Shop Wrench
by ianSWBB
Thanks for that Tortor - I think maybe the stock images (computer generated in the Colnago IT dept) don't have the exact items - we've checked through our 2014 C59 and they have all had the same fork!
@wassertreter - yes, charging point positioning will require more thinking in the future!
Fondriest put it on the seat tube, just above the BB area
regards
ianSWBB
markyboy
by markyboy
regards
ianSWBB
It seems that there are 2 different versions of fork for the C59
My 2014 fork :noidea:
ianSWBB
Shop Wrench
by ianSWBB
@markyboy
Well that's my explanation for the difference out the window!!
Maybe the very first batch came with the 2013 fork sprayed up in 2014 colours?
regards
ianSWBB
ianSWBB
Shop Wrench
by ianSWBB
@markyboy
In fact it must be that - as I've just noticed you have external EPS, which was only on the very very first batch of 2014 frames
The second and third edition come without the powerunit bracket plate underneath, just a charging point for internal V2 system
regards
ianSWBB
