Tune Mag 180 hub campy 10 speed to 11 speed
adrien de la touche
by adrien de la touche
Hi I've got some wheels with Tune mig and mag hubs for 10 speed campagnolo. They are a few years old and fit 9/10 speed.
I want to use them on my best bike with 11 speed.
Does anyone know how I can upgrade the freehub? Do i simply buy the "red for 15mm campagnolo": http://www.starbike.com/en/tune-spare-freehub-body/
Thanks in advance for your help
Aidee
fitty4
by fitty4
Did you look at this?: viewtopic.php?t=57380
adrien de la touche
Hi fitty yes I did, but it didn't answer my question.
LionelB's post alarmed me a bit which was-
This is the answer I got from Tune. Seems that the old ones would not work...
"Hello,
The new Mag 180 is with campa 11 speed compatible.
When you like to buy a older version ( used ) it is not possible!
best regards A. Mandl
I know 11 speed won't work, but how to resolve it? new freehub?
ergott
by ergott
I have a 180 hub on my 11 bike (Campagnolo). The back of the cassette carrier will rub the hub shell. I currently have 2 micro shims (.25mm) before the cassette. This alleviated things and it's a tight fit at the dropout. If you can find a .5mm spacer it would do the same thing.
jmartpr
by jmartpr
If it's a Mag 180 you will be able to use the Campy 11-speed on the "red" freehub.
The last cog does stick a bit more than usual from the freehub but it will hold.
adrien de la touche
Thanks jmartpr, do you know if it's the 15mm or the 17mm?
Cheers
jmartpr
by jmartpr
I have right here a set of ENVEs build on the older Mag 180 (red freehub) and have a 11-speed super record 12-27 on them. The only thing is what I told you that it does stick out a bit but once tight it's Ok. If you do add the spacer try to find one that's is not too thick.
adrien de la touche
Thanks jmartpr, mine have the green freehub though and it's miles too short. Just about to buy a new red freehub but there are two options...
Thanks again
jmartpr
by jmartpr
The only options are either campy or shimano...BTW...you will probably also need both end caps.
