It is currently Sun Jan 21, 2018 9:45 pm
PostPosted: Wed Oct 23, 2013 9:36 pm
If someone could help me with a dilema, I would appreciate it. I work in a bike shop that is a Trek dealer, so I want to stay with them. I have been riding a Trek Madone 7 Series for the season and am pondering if I could ride a 60. The reason for considering a 60 is the headtube is 2cm taller and it is hard for me to run a aggressive set-up. The reach numbers between the 2 frame is quite small. The 58 is 40.6 and the 60 is 40.9, so it seems quite small unless I am missing something.
I could go to the Domane which is a thought, but I am waiting for the team frames which have a steeper heatube and longer top tube.
Any thoughts would greatly be appreciated :beerchug:
PostPosted: Wed Oct 23, 2013 9:59 pm
The Domane's are only available H3, unless you get a "Team" frame, which is H1, but is only available in a size 54. The difference between the two frames sizes (Madone) is 1.2cm (12mm). You could make up the difference in frame size by running a longer stem, or you could make up the height difference on the 58 by running more spacers beneath the stem. I know many on here are of the "slam the stem" mentality, but I disagree with that, unless your fit allows you.
On the other hand, the 60cm Domane has a smaller effective top tube (57.9 vs 58.6) and shorter reach (38.3 vs 39.5), so that may fit you better in the 60cm size. Either way, both bikes are great.
PostPosted: Thu Oct 24, 2013 1:28 pm
Online
The reach number doesn't take the spacers into account, so by the time you factor in those and the HTA the difference in reach is probably a bit more between the two sizes. What length stem and how many spacers do you run on the 58?
My Bikes
My Photoblog
PostPosted: Thu Oct 24, 2013 2:04 pm
Thanks.. I have all the spacers in and a 100mm stem. I think the 60 will give me the taller head tube without having the reach being to far different. My saddle is also all the way back, I don't if that matters.
PostPosted: Fri Oct 25, 2013 8:59 pm
If you're going to run a 100mm stem on a 58, I would not go with a 60. My experience is that the shorter stems make the bike twitchy and harder to handle.
PostPosted: Fri Oct 25, 2013 9:51 pm
I think I am going to the Domane Pro Fit frame.. have all the geo numbers and that may be my best bet. Thanks for all the help.
PostPosted: Sat Oct 26, 2013 4:22 am
if you fit on a 54, good luck!
PostPosted: Sat Oct 26, 2013 11:52 am
Actually, they will have sizes 54-62 as those are the sizes they build for the team. It is 250 frames and I am just waiting on confirmation whether they will be in Project One. I"ll let you know how it goes.
There are no new unread posts for this topic. Help disassembling Trek Domane 6 Series
Danza
Sat May 20, 2017 11:49 pm
MoreRideTime View the latest post
There are no new unread posts for this topic. Dura Ace brakes 9100 series for Trek Domane SLR
Flint
7
1145
Wed Feb 22, 2017 8:38 pm
Flint View the latest post
There are no new unread posts for this topic. 2018 Trek Domane SL 7
nycjwi
Thu Dec 21, 2017 7:32 pm
SilentDrone View the latest post
There are no new unread posts for this topic. Trek Domane SLR Rear mech cable help needed
Flint
Fri Nov 17, 2017 10:20 pm
There are no new unread posts for this topic. Trek domane/emonda seat mast cap - weight weenie clamp
alcatraz
7
865
Sun Dec 24, 2017 1:24 pm
alcatraz View the latest post
Users browsing this forum: cyclenutnz, StephanP, stormur, TheDoctor, Zakalwe and 37 guests
