It is currently Mon Mar 27, 2017 6:12 am
Post new topic  Reply to topic  [ 14 posts ]
PostPosted: Tue Oct 22, 2013 11:38 pm
Can someone confirm if this cassette has a carbon or alloy sprocket carrier? I've heard people mention that it has a carbon carrier but can find no mention of that in any advertising I've seen for it.
Ti or dye!
PostPosted: Wed Oct 23, 2013 1:01 am
I can confirm that it's got one carbon piece:
Would post a pic of the actual part but it's mounted on the wheel :p
PostPosted: Wed Oct 23, 2013 2:01 pm
Has anyone actually tried to remove a sprocket (and a spacer) in the middle of the cassette and fitted it to a 10s freehub?
How does it work?
PostPosted: Wed Oct 23, 2013 5:07 pm
How does it work?
I haven't, but why do you ask? You have a 11sp cassette and only a 10sp freehub?
PostPosted: Wed Oct 23, 2013 5:16 pm
Yeah, something like that. I quess that I, like most, would like to get full use of all "old/obsolete" wheels before jumping to the 11s freehub wagon.
To be honest, my right Sram Force shifter broke yesterday. A real bummer! It's 3 years old and therefore not covered by the warranty. I'm thinking of either going Ultegra 6700 by getting the shifter and rear derailleur (already have the cassette, chain and front derailleur) or get Ultegra 6800, which basically means all the group(po).
Choosing 6800 mean that I have to make do with 10 of the 11 sprockets in order to make it work with my current 10s freehubs.
PostPosted: Wed Oct 23, 2013 5:33 pm
Also a 10sp Shimano/Sram wheel with an 11sp 9000/6800 cassette minus 1 sprocket will run perfectly with a Campy 11 derailleur and shifters. Very, very useful for beaters and winter bikes :)
The Shivenge
PostPosted: Wed Oct 23, 2013 6:50 pm
Yes. I guess it means that you, for instance, can indeed run Campagnolo Chorus shifters and derailleur with a Shimano Ultegra chain and cassette.
...together with Sram Force crankset with FSA 10s chainrings!
PostPosted: Fri Oct 25, 2013 8:05 am
Well my plan is to machine out the rear of the sprocket carrier so I can run 11speed Shimano on my Gen1 Lightweights. I don't fancy doing it to the rear of a Sram Red cassette, guess I'll have to wait for 105 11speed cassettes 8) What is the rear of a Force 22 cassette like? Does it use an alloy sprocket carrier like older Shimano 105/Ultegra etc?
Ti or dye!
PostPosted: Fri Oct 25, 2013 11:28 am
Why not get a 6800 and remove the 16T sprocket?
PostPosted: Fri Oct 25, 2013 1:16 pm
Because I want 11 sprockets :evil:
Ti or dye!
PostPosted: Fri Oct 25, 2013 1:21 pm
I get it.
PostPosted: Mon Oct 28, 2013 5:40 pm
Alloy carrier - my recollection is the top 3 cogs are on it.
PostPosted: Mon Oct 28, 2013 7:55 pm
I actually have a similar question- can I run an 11s shimano cogset on a 7800 hub? I was thinking I would remove the 11 from an 11-25 and then be able to run shimano or campy 11, but I dont know if the 11s cogs have the deeper notches needed to fit over the taller splines on the alu casette carrier. The alternative at this point is to either sell my wheels for a loss, do some machining or use a jtek with 10s, neither of which i'm particularly fond of...
Thanks,
Stefano
PostPosted: Tue Oct 29, 2013 6:40 am
I'm thinking of removing a 16T in the 11-25 cassette. It would give me even gearing. Combined with a Campagnolo 11s group.
My concernt is either going this path or choosing Ultegra Di2 6770 at a discounted price.
There are no new unread posts for this topic. Ultegra 6800 brake feel
mvcap
23
1397
Wed Mar 22, 2017 12:45 pm
redna12 View the latest post
There are no new unread posts for this topic. Ultegra 6800 Reach Lever Screw broken
probertsqbe
Tue Feb 14, 2017 12:09 pm
probertsqbe View the latest post
There are no new unread posts for this topic. Tiagra 4700 chainrings interchangeable with ultegra 6800?
zalle
Tue Oct 25, 2016 1:41 pm
Michenfelder View the latest post
There are no new unread posts for this topic. Shimano Ultega 6800 pedals-bent axle
rOYk
Wed Apr 06, 2016 4:46 pm
kkibbler View the latest post
There are no new unread posts for this topic. Aftermarket brake choices for Shimano 6800/9000
ultyguy
Wed May 11, 2016 6:46 am
Anders3404 View the latest post
Users browsing this forum: Baidu [Spider], stormur and 27 guests
