It is currently Mon Jan 22, 2018 4:54 am
Post new topic  Reply to topic  [ 19 posts ]  Go to page 1 2 Next
PostPosted: Mon Oct 21, 2013 9:56 am
Administrator
Saturday was a scheduled team ride. The weather was poor, cold and raining the first hour and very windy. Some of the team was off cross racing and I guess others decided since it is off season to pass on this ride due to weather so it was a small group of 6 of us. Cinders are not used where I live in poor weather but for some reason we had quite a bit in places on the roads and experienced a few flats including myself but mine decided to not go flat until over night Saturday. So I woke up to a rear flat on my road bike. I always am cleaning my bike and since I had to change the flat I cleaned my bike and pulled my front wheel. I felt something under the crown of my fork so I took a little better look. This is what I found:
The fork is a 7 year old Alpha Q GS30 that I bought from a builder raw. I would hit it pretty frequently with 303 for UV protection but can't say the underside of the crown got hit that often. I'm not sure if that contributed to this kind of deterioration of the carbon. There are two small holes and you can see the fork mounting bolt on the front brake.
The only good things about this is I have a brand new GS30 that is painted as a spare and the other is that with such a windy day we came back at a pretty fast pace hitting speeds up to 61 km and the fork did not fail!
Words of wisdom? Clean your bike often and inspect everything closely. Also the underside of this crown was fine last time I had a look at it a few weeks ago.
Here is a link to the ride:
http://app.strava.com/activities/90038993" onclick="window.open(this.href);return false;
I guess my being cocky in my title gave me the next day flat. Karma.
RESIDENT GRUMPY OLD MAN.
PostPosted: Mon Oct 21, 2013 1:11 pm
looks like delamination with some stress fractures. it that hole caused by rocks/debris hitting and getting stuck up there?
good thing you checked. count your lucky stars.
- AX Lightness Vial EVO D + DA9070 + Enve SES 3.4 carbon hubs
- Parlee ESX + DA9070 + THM SRM PM + Enve SES 6.7 CK hubs
- Independent Fabrication Ti FLW + Campy SR11 + Enve 3.4 CK hubs
PostPosted: Mon Oct 21, 2013 2:34 pm
2 things
to me the pic looks like the underside of just about every carbon fork that gets ridden a lot.
the amount of material around that area on an Alpha Q in that area is very thick. 10mm or more. Are you saying the hole goes through the wall?
www.crumptoncycles.com
PostPosted: Mon Oct 21, 2013 2:53 pm
Administrator
Nick, that is correct. I cac see the front brake bolt thru one of the holes. I've never had a rock wedge in it either.
PostPosted: Mon Oct 21, 2013 3:38 pm
scary...
PostPosted: Mon Oct 21, 2013 5:58 pm
I am glad the bike is okay (and you as well). An ounce of prevention...
-Deacon Doctor Colorado Slim
PostPosted: Mon Oct 21, 2013 5:59 pm
I've never heard of a fork breaking in that spot. I'd patch it up with a couple layers of cloth and resin and call it good.
formerly rruff...
PostPosted: Mon Oct 21, 2013 7:03 pm
^ Darwin award of the year for this character.
  • 2011 Cannondale Flash F1
  • 2010 Cannondale Caad9
  • 2000 Caad 4 aero
PostPosted: Mon Oct 21, 2013 8:04 pm
( I'd patch it up with a couple layers of cloth and resin and call it good. )
Then put that sucker on ebay, no one will ever know. :oops:
PostPosted: Tue Oct 22, 2013 12:28 am
I could see that sort of thing happening if you're running 25c tires (or bigger). I had an older 3t fork that just couldnt take a 25 without the sand and grit rubbing the fork right at that same spot. You can see plenty of scratches leading to that center area which would imply the same type of damage. Just a thought.
Casati Vola SLi and Dolan Preffisio
viewtopic.php?f=10&t=108931" onclick="window.open(this.href);return false;"
btompkins0112 wrote:
It has the H2 geo......one step racier than a hybrid bike
PostPosted: Tue Oct 22, 2013 5:06 am
No, but I'd happily ride it.
Seriously, has anyone heard of a fork breaking in that location? Looks like erosion rather than a structural crack.
First, I'd try to pull the blades apart... and if that doesn't produce any strange sounds then patch it up. That's how they'd fix it if you sent it somewhere anyway.
formerly rruff...
PostPosted: Tue Oct 22, 2013 5:32 am
The photo doesn't do it justice then. Just looks delaminated. Cosmetic.
PostPosted: Tue Oct 22, 2013 6:22 am
...an actual hole doesn't just happen from carbon delamination. Even if a rock never got wedged in there u could have hit a rock that got shot onto the underside or a nail or other sharp object. Carbon doesn't just disintegrate and fade away leaving a hole that appears like a puncture wound. EM3
______________
PostPosted: Wed Oct 23, 2013 2:39 am
Fault in manufacturing along with poor QC would be a pretty safe bet.
PostPosted: Thu Oct 24, 2013 2:29 am
Seven years seem pretty good to me for a non-coated carbon fork.
Both UV radiation and moisture have adverse effects on the mechanical properties of the polymeric epoxy matrix, while the carbon fibers are not affected significantly by either environment. The polymer matrix in a fiber-reinforced composite serves to transfer the loads to the reinforcing fibers and provide shear strength. Its not the non-coated carbon but the non-coated epoxy that leads to reduced damage tolerance and lack of long-term durability. But really seven years is good, consider the flat a blessing.
There are no new unread posts for this topic. Best way to strip paintwork to inspect carbon underneath?
Shrike
7
660
Wed Mar 22, 2017 6:39 pm
mvacolnago View the latest post
There are no new unread posts for this topic. Leather top vs. Carbon Fiber saddles (SMP Forma vs. Carbon Lite)
dgeesaman
Thu Aug 31, 2017 11:52 am
kgt View the latest post
There are no new unread posts for this topic. Attachment(s) New Saddle: Selle Italia Carbonio Flow vs San Marco Aspide Carbon vs San Marco Mantra Carbon
3Pio
35
3389
Fri Oct 27, 2017 9:48 pm
3Pio View the latest post
There are no new unread posts for this topic. Is carbon lugged dead? Have modern monocoque frames usurped carbon lugged frames outside of just weight?
tranzformer
Sat Jul 22, 2017 4:14 pm
spartacus View the latest post
There are no new unread posts for this topic. Attachment(s) Garmin Vector failure
jpanspac
12
1805
Sun Aug 13, 2017 3:29 am
NGtim View the latest post
Users browsing this forum: BikeKingV1r, Bing [Bot], MomentumR5, nemeseri, trex021, wheelbuilder, Wildh and 32 guests
