It is currently Wed Feb 22, 2017 11:09 pm
Post new topic  Reply to topic  [ 28 posts ]  Go to page Previous 1 2
PostPosted: Thu Nov 07, 2013 8:57 pm
Tinker, Taylor, Tart
There's numerous folk out there who have tried the 9070 rear mech with 10spd spacing with no issue - because of the way Shimano have spaced their 11spd cassette it seems to work just fine.
PostPosted: Fri Nov 08, 2013 5:13 pm
My understanding is that cog spacing is the same with shimano 10 and 11 speeds. At least it seems to be since I can run 10 speed cassettes with 11 speed shifters.
BdaGhisallo wrote:
In that scenario the shifting will not be perfect since the 6870 RD will be shifting to 11sp cog spacing. If you want 10sp cassettes, you will need a 6770 RD and can use 6870 everywhere else.
The RD determines the the cog setup. 6770 = 10sp 6870 = 11sp. All other components are compatible, though not optimal. The 6870 FD will trim based upon 11sp chain and chainring architecture, so you may have some misalignment, though you won't know how much until you try it.
PostPosted: Fri Nov 08, 2013 6:07 pm
The 10sp and 11sp cogs are the same width, but the spacing between the 11sp is a hair narrower than 10sp. I can't track down the actual numbers but you can impute the difference from the different dimensions for the 10sp and 11sp chain.
From BikeRumor:
The 11-speed chain is 5.62mm at the widest point, and the current 10-speed chain is 5.88mm.
Now it may not make a difference in the real world, but they are different.
PostPosted: Sat Nov 09, 2013 1:33 pm
Could i use 6700 shifters with a 6800 rear derailleur and 11s casette to make it 11s?
2015 S-works Tarmac DA9000, 6,29kg
PostPosted: Sat Nov 09, 2013 1:45 pm
No.
PostPosted: Sat Nov 09, 2013 1:49 pm
Mixing and matching mechanical and DI2 10 and 11sp are different animals. With mechanical, the cog number the system can control is dictated by the STI levers. 7900 and 6700 are 10sp only. 9000 and 6800 are 11sp only.
It is with DI2 that the RD dictates the cog number. 6770 is 10sp and 9070/6870 is 11sp.
PostPosted: Sat Nov 09, 2013 2:01 pm
Ok, thank you.
PostPosted: Sat Nov 09, 2013 10:37 pm
Yes, but use an 11spd chain on the 10spd setup and you'll be fine.
It works - I know people doing it.
PostPosted: Sun Dec 08, 2013 4:40 pm
hi,
I have an ultegra 6770 and I wanted to bring it to 11s.
Can I just replace my RD-6770 with RD-6870 with, 11s chain and cassette 11s?
PostPosted: Sun Dec 08, 2013 6:19 pm
...and the chainring 6750 is compatible with chain 11s?
The SM-EW67-A-E and ST-6770 are compatible with FD-6870 and RD-6870? thanks
PostPosted: Sun Dec 08, 2013 8:26 pm
You'll need the 6870 rear mech and a firmware upgrade - then you're good to go.
PostPosted: Mon Dec 09, 2013 1:01 am
6870 RD is only 11 speed. I guess you could try limit screws but the electronics will always be programmed for 11.
PostPosted: Mon Dec 09, 2013 2:58 am
Ah, my bad - I meant if you wanted to upgrade to 11spd.
There are no new unread posts for this topic. DA Direct Mount Compatibility with Ultegra Di2 (6870) shifters?
bkw
Tue May 17, 2016 10:35 pm
Kongbop View the latest post
There are no new unread posts for this topic. Ultegra 6870 di2 Rear Shifting Problem
hlvd
16
1002
Mon Aug 29, 2016 6:34 pm
goodboyr View the latest post
There are no new unread posts for this topic. Attachment(s) Di2 Ultegra Rear Mech Rd-6870. Will the short cage SS work with single chainring 11-32 cassette?
Ed209
10
862
Sat Oct 15, 2016 6:59 am
allenpg View the latest post
There are no new unread posts for this topic. chain skips when pedaling backwards?
bontie
18
875
Wed Mar 09, 2016 5:15 am
mike View the latest post
There are no new unread posts for this topic. Dogma F8 hydro disk brakes/ Di2 Ultegra vs Cannondale SuSix Di2/Ultegra
bikebike
Sat Oct 29, 2016 4:41 am
bikebike View the latest post
Users browsing this forum: Baidu [Spider], Bing [Bot], ceee, Cocolo, djbowen99, gsindela, hlvd, shonanmike, tuba and 39 guests
