It is currently Tue Apr 25, 2017 6:00 am
Post new topic  Reply to topic  [ 96 posts ]  Go to page Previous 13 4 5 6 7 Next
PostPosted: Thu Feb 20, 2014 11:41 pm
drainyoo wrote:
I will never be changing wheels, would you still not recommend them?
Set them up correctly and they will not let you down. In my experience, of course.
PostPosted: Thu Feb 20, 2014 11:43 pm
By setting them up correctly, do you mean follow the directions provided by Ciamillo?
6.24kg CAAD10
PostPosted: Fri Feb 21, 2014 12:45 am
Quote:
Thanks, which version? Micro?
Yes; Micro's with all mounting hardware minus pads.
"You can't get there from here"
PostPosted: Fri Feb 21, 2014 12:47 am
Hmmm. 12g over claimed. Did you use any extra washers?
6.24kg CAAD10
PostPosted: Fri Feb 21, 2014 2:06 am
Yes; 1. make sure the cam is correctly placed (i.e. in its lowest position) when not pulling the lever, and 2. cut the cable housing to precisely the correct length such that it does not push or pull the brakes out of center. This latter point will require some patience. And, of course, if you're not purchasing the micros (with the adjustable cam), be sure to use the correct washers.
Last edited by crimsonbadger on Sun Feb 23, 2014 12:28 am, edited 1 time in total.
PostPosted: Fri Feb 21, 2014 2:31 am
No - that weight is with the thin brake pad washers and short brake pad mounting screws.
PostPosted: Fri Feb 21, 2014 2:43 am
crimsonbadger wrote:
Yes; 1. make sure the cam is correctly placed (i.e. in it's lowest position) when not pulling the lever, and 2. cut the cable housing to precisely the correct length such that it does not push or pull the brakes out of center. This latter point will require some patience. And, of course, if you're not purchasing the micros (with the adjustable cam), be sure to use the correct washers.
Thanks. So I assume that the Micros are easier to install?
6.24kg CAAD10
PostPosted: Fri Feb 21, 2014 2:44 am
That weight is a little disappointing for the Micros, which are claimed to be 150g.
6.24kg CAAD10
PostPosted: Fri Feb 21, 2014 5:20 am
Only if low weight is more important to you than function.
It's online again:The Machinist
My CAAD10:http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=109014
PostPosted: Fri Feb 21, 2014 5:53 am
Huh? I didn't say that. The brakes are claimed to be 150g and the real weight is 12g over. That's a bummer. This is weight weenies after all.
6.24kg CAAD10
PostPosted: Sat Feb 22, 2014 4:57 pm
FYI
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=112078
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=129360&p=1106656#p1106656
 Post subject: New Ciamillo GSL Micro
PostPosted: Sat Feb 22, 2014 5:09 pm
Wow, 185g for the Micros?? Are you including all the washers? Even so, I can't imagine washers adding 30g.
This is the same weight as the Planet X brakes. What's the point of these then?
6.24kg CAAD10
PostPosted: Sat Feb 22, 2014 5:47 pm
This is including everything in the box... I accidentally took them with both the long and short bolts. Correct weights shortly.
PostPosted: Sat Feb 22, 2014 5:55 pm
Short
Long
Sent from my iPhone using Tapatalk 2
PostPosted: Sat Feb 22, 2014 6:06 pm
Brakes no hardware
Pad holders
Hardware with short bolts
Hardware with long bolts
There are no new unread posts for this topic. Attachment(s) Just got my new Micro SL
atwong1
15
2374
Mon Nov 28, 2016 7:46 am
KC View the latest post
There are no new unread posts for this topic. specialized emt micro
ericmerg1
Sun Dec 11, 2016 10:35 pm
ericmerg1 View the latest post
There are no new unread posts for this topic. anyone use rithey micro road pedals?
addict
Wed Jul 06, 2016 9:11 am
addict View the latest post
There are no new unread posts for this topic. Ciamillo OG-05 Ti with Zipp 303s?
nvroadie
Mon Dec 26, 2016 6:58 pm
nvroadie View the latest post
There are no new unread posts for this topic. Ted Ciamillo Gravitas Cranks - Anyone else still waiting for a refund????
lumbardcs
Thu Sep 08, 2016 2:41 am
Juanmoretime View the latest post
Users browsing this forum: AJS914, lovemyway, Samklee15 and 33 guests
