It is currently Wed Jan 17, 2018 1:33 pm
Post new topic  Reply to topic  [ 15 posts ]
 Post subject: Evo BB tools
PostPosted: Mon Oct 14, 2013 2:57 pm
Hey
So, I want to get a complete set of tools in order to service or replace the BB on my Evo.
I have the SiSL2 cranks and BB set installed.
So, what would I need to extract, and re-install the cranks and BB, tool wise?
I was thinking-
-Extracter
-something to get the bearings and cups out
-something to get them back in straight!
Any ideas, knowledge, or suggestions for what I need to buy, and what I should look out for?
Thanks in advance.
 Post subject: Re: Evo BB tools
PostPosted: Mon Oct 14, 2013 3:02 pm
I use a Park Bearing Press (HHP-3) and BBT-30.3 removal tool.
http://www.parktool.com/blog/repair-hel ... nd-removal
PostPosted: Mon Oct 14, 2013 3:07 pm
And these work ok on BB30 (or whatever it is they are calling what I have installed in my frame)
PostPosted: Mon Oct 14, 2013 3:08 pm
Yes, I used them on my EVO's bearings. I haven't removed the cups yet, there's another tool for that - but I can't recall the part number.
PostPosted: Mon Oct 14, 2013 3:11 pm
http://www.parktool.com/product/head-cup-remover-rt-1
PostPosted: Mon Oct 14, 2013 3:15 pm
Thanks, will check it all out. Any issue getting the bb in straight, or did it go in ok?
PostPosted: Mon Oct 14, 2013 3:19 pm
My cups were reamed by the shop when doing the initial build. I just removed the bearings and reinstalled them, it was simple and painless.
PostPosted: Mon Oct 14, 2013 3:27 pm
Reamed? The Evo has a carbon BB shell. What BB did you install?
PostPosted: Mon Oct 14, 2013 3:28 pm
The BB shell is carbon, but the pre-installed PF30 cups are aluminum. I don't know what tool they, but Park sells one.
I'm using Hawk Racing bearings.
PostPosted: Mon Oct 14, 2013 3:33 pm
Ah, so you bought the Evo as a frame, which had empty PF30 cups in it?
PostPosted: Mon Oct 14, 2013 3:38 pm
I got the frame through their frame upgrade program. I traded in a CAAD9.
Yes, it came with empty cups pre-installed.
PostPosted: Mon Oct 14, 2013 3:52 pm
OK. Mine has the sisl2 bb installed. I doubt the bearings will come out without the cups, so I will be pressing the cups in myself. What cranks are you using?
PostPosted: Mon Oct 14, 2013 3:55 pm
SRAM Red Quarq
PostPosted: Wed Oct 16, 2013 4:43 pm
Unless Cannondale has made a change, the PF30 bottom bracket cups have typically been made from Delrin (SRAM) where as the alloy bearing cups were usually spec'd for when installing an SRM Hollowgram powermeter.
PostPosted: Wed Oct 16, 2013 5:54 pm
Here is my 2013 EVO's BB, post reaming, with the cups Cannondale supplied.
There are no new unread posts for this topic. Tools Required to File Down an ISP
hogehoge
Tue Jun 13, 2017 10:02 pm
2lo8 View the latest post
This topic is locked, you cannot edit posts or make further replies. Lightweight Multi Tools / Pumps - What are you carrying thread?
vneilv
12
1103
Wed May 24, 2017 2:46 pm
Hawkwood View the latest post
There are no new unread posts for this topic. Campagnolo TOOLS UT-FC220 - Over-Torque crankset assembly and disassembly tool
moccacaffee
Thu Jan 04, 2018 5:43 pm
bm0p700f View the latest post
Users browsing this forum: Everyone, Google Adsense [Bot], halcyongolf, Rudi, rynogee, wobbly and 30 guests
