Carbon pads, expensive or cheap ?
bman11
by bman11
The Reynolds blue pads work very well, but I actually prefer the Enve pads in vet weather. They are pretty comparable in the dry though. I didn't like the yellow residue that the SWiss Stops left on my rims though.
Just dig in and climb it!!!
Ottoturbo
by Ottoturbo
I've used the no-name blue pads that came with my carbon Farsports wheelset. These have been all over good in dry and wet. Also the wear is pretty good. These are $5 a set.
stuka666
by stuka666
Blue pads on ebay are ok for carbon? Are these the ones you talk about?
http://www.ebay.com/itm/181515887857?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Same as the blue pads that came with planet-x brakes?
natefontaine
by natefontaine
I've had good results with these, http://www.ebay.com/itm/221576302195 but I think most of it has to do with 6800 brakes. I have used them exactly 1 time in the wet, they are passable.
Ottoturbo
by Ottoturbo
stuka666 wrote:Blue pads on ebay are ok for carbon? Are these the ones you talk about?
Not the same as came with Farsports wheels. Buy direct from them. I have ordered the new black pads they sell, said to give even more friction and better at higher tems. $10 a set. I have a set that came with my Planet-x ultraligh cnc brakes, but not used them since I never asked if they are for carbon brake surface.
F45
by F45
No one uses Shimano OEM carbon pads? I have a set but haven't installed them yet.
p3dalfaster
by p3dalfaster
I used them for a bit with C50's, now using the Swiss Yellow's.
eric
by eric
Swiss yellow pads are the worst for putting heat into rims. I'd use something else, preferably pads recommended by the manufacturer.
dmulligan
by dmulligan
Is there a big difference between Reynolds Cryo Blue and Reynolds Blue pads?
Do basalt brake tracks generally all perform the same with the same pads? Which pads work well with basalt brake tracks?
Sent from my A0001 using Tapatalk
prebsy
by prebsy
Another vote for 'nolds pads.
I find the cheap Kool stops do a good job but wear out way too fast.
KarlC
by KarlC
Ottoturbo wrote: Not the same as came with Farsports wheels. Buy direct from them. I have ordered the new black pads they sell, said to give even more friction and better at higher tems. $10 a set. I have a set that came with my Planet-x ultraligh cnc brakes, but not used them since I never asked if they are for carbon brake surface.
Got a link to the Farsports pads you are taking about here ?
Thx
glepore
by glepore
The cryo's modulate better, but not worth 3x the price imho
Cysco Ti custom Campy SR mechanical (6.9);Cannondale SS Evo Di2 7970 (5.79); Willier Cento Uno Air Di2 9070 (7.0); C40 Mk2 DA 7800 ; Anvil Custom steel Etap;1996 Colnago Technos Record
dmulligan
by dmulligan
Right. I forgot to ask if they are worth the difference.
