It is currently Fri Jan 19, 2018 1:03 am
PostPosted: Sun Oct 13, 2013 3:35 pm
I'm pretty sure this will fit me but would really like a second opinion before I pull the trigger.
My sexy measurements,
height: 167cm
stand over no shoe: 77cm
arm length: 67cm
ground to collar bone: 139cm
PostPosted: Sun Oct 13, 2013 6:05 pm
Top tube seems too long...
PostPosted: Sun Oct 13, 2013 6:13 pm
I would say it's slightly too big, given your size, I think your more suited to a IF 50-51cm frame which will give you a 53cm top tube and more clearance with the stand over height.
PostPosted: Sun Oct 13, 2013 7:03 pm
Thanks guys you're totally right.
PostPosted: Sun Oct 13, 2013 11:26 pm
Uhhhh? Isn't the Crown Jewel custom?
Some will advise you to get a bike-fit, but I'd talk to the frame-builder in the first instant.
Less is more.
PostPosted: Mon Oct 14, 2013 12:10 am
Definitely too big. I'm 168cm, 77cm inseam.
PostPosted: Mon Oct 14, 2013 2:28 am
Horrible. Give it to me and I'll get rid of it for you;-)
www.ergottwheels.com
PostPosted: Mon Oct 14, 2013 7:38 am
same as metanoize here, pretty sure it'd be too big...
PostPosted: Tue Oct 15, 2013 6:17 am
Run- don't walk away from this one.
Not only is it way too big for you (at 77cm inseam), but the bike is a terrible design period.
Really slack front end- but still has a short headtube.
I could see a head angle/fork rake combo like that if someone was trying to make a Roubaix-like bike with a tall front end. But this bike has a fairly short headtube.
Front center is really long.
I can't figure out what the bike was designed for unless the owner had an aggressive position but was super fearful of any toe clip overlap.
PostPosted: Tue Oct 15, 2013 6:41 am
There's definitely something not right there. 745mm seat height for 77cm inseam just isn't right. I'm 165cm tall and my seat height is 670mm.
The IF Crown Jewel is available custom but I'm deducing that the OP went to Adddictive Cycles. So my advice is as before viz contact IF directly if an IF is what the OP wants. Otherwise there are other frame builders: English is my recommendation.
Less is more.
There are no new unread posts for this topic. General comments on Absolute Black oval chainrings
LouisN
16
1920
Fri Jan 27, 2017 2:23 am
evan326 View the latest post
There are no new unread posts for this topic. Between frame sizes - : Going larger frame vs going smaller frame
jeffy
16
1755
Sun Jul 09, 2017 11:03 pm
sooni View the latest post
There are no new unread posts for this topic. Hi-Mod frame vs non-himod ? Different frame quality ?
[ Go to page: 1 2 3 4 ]
destinationwarmth
49
7840
Sun Apr 16, 2017 7:58 pm
Hexsense View the latest post
There are no new unread posts for this topic. Sram Red BB386 Crankset with BB386 Bottom Bracket in BB386 Frame: Small Chainring touches Frame
jbattermann
Sun Jul 23, 2017 5:06 am
KCookie View the latest post
There are no new unread posts for this topic. Fuji SL frame, Transonic Elite frame, or Transonic 1.3 (all are 2017)?
BigPoser
Wed Feb 08, 2017 4:53 am
BigPoser View the latest post
Users browsing this forum: Baidu [Spider], BigPoser, Bing [Bot], ghostryder, Imaking20 and 25 guests
