It is currently Thu Jan 18, 2018 3:26 am
Post new topic  Reply to topic  [ 2 posts ]
PostPosted: Fri Oct 11, 2013 8:16 am
can the exogram 2X10 Red crankset be used in the Red22 2X11 configuration?
If not, is the difference in the rings or the cranset itself?
My goal is to use the Red crank with Q-Rings in Red22 setup and the preference would be to reuse my older Exogram 2X10 Red crank with appropriate Q-rings.
Any info would be appreciated
Racing and Training Cycling Tires
www.tiremaniacs.com
PostPosted: Fri Oct 11, 2013 10:57 am
Quarq said it was only a ring change, I assume the same would apply for a regular spider.
There are no new unread posts for this topic. Compatibility Question - 11 speed Crankset & 9 Speed running gear
pfnsht
13
737
Fri Aug 25, 2017 2:31 pm
goodboyr View the latest post
There are no new unread posts for this topic. Mixing 10 speed sram and 11 speed 105
jowen
Mon Mar 06, 2017 8:40 am
kulivontot View the latest post
There are no new unread posts for this topic. 11 Speed on 9 speed crank set?
Willem
Sat Apr 22, 2017 4:13 am
Willem View the latest post
There are no new unread posts for this topic. campagnolo centaur 11 speed chainring compatibility
JoO
Sun Oct 22, 2017 3:19 pm
JoO View the latest post
There are no new unread posts for this topic. Sram Red BB386 crank arm compatibility
Jian81
Sun Dec 17, 2017 2:00 am
Jian81 View the latest post
Users browsing this forum: chronsbons, CrankAddictsRich, Google [Bot], Jereb, jlok, nobuseri, Roentgun and 28 guests
