It is currently Sat Jan 21, 2017 4:47 pm
Post new topic  Reply to topic  [ 12 posts ]
PostPosted: Thu Oct 10, 2013 9:25 am
Hello,
Any RCA owner with electronic group had this problem?
On my RCA frameset, the hole for the front derailleur wire is too big to cover it with Shimano grommets...
PostPosted: Thu Oct 10, 2013 10:54 am
Sorry for the pics, now updated
PostPosted: Thu Oct 10, 2013 11:05 am
Send it back.
Although it sounds flippant a product at this pricepoint should involve no compromises at all. I can think of several solutions, but would say that the customer should not have to fudge a solution at this level.
PostPosted: Thu Oct 10, 2013 11:10 am
Best Freak bike poster
From memory there are two different sized grommets available from Shimano, you may have the smaller of the two.
CAAD10 Di2
PostPosted: Thu Oct 10, 2013 12:21 pm
6mm Round
7 x 8mm Oval
PostPosted: Thu Oct 10, 2013 7:17 pm
ghisallo2003 wrote:
Send it back.
Kinda jumping the gun there. That big hole is intended for the older Di2 plugs or some other larger cable. The hole behind the seat tube is the intended route for e-tube wiring to the FD.
My Cervelo R5
My Lynskey Helix
My MTB
PostPosted: Sat Oct 12, 2013 3:55 am
A great deal of frames now have larger diameter openings for wiring, and the supplied Shimano groms are too small.
You could send it back like a dick, or just get some campy or generic plugs that will fit the frame properly, fit the cable properly, and start riding the thing.
Why?
Di2 standard was released to frame manufacturers before Campy officially released their stuff, and grommets were made to fit those holes.
Then Campy officially came out with EPS.......
The Campy wire terminals are wider, because they don't give a shit what Shimano does. -So many unknowing folks who built a bike with the brand new EPS and an (electronic ready) frameset found out that these frames were built for the Di2 standard, and subsequently had to drill the frames out or get upset about how multi-thousand dollar bike frames and parts sometimes don't go together like legos..
Now, most manufacturers are widening holes on upper-end whips for EPS, and the standard Shimano style plugs are too small for larger Omni-electronic friendly frames..
I'm not trying to be a naughty cock here, but I have heard this over and over in the last few years, and it is just an issue of Campagnolo making things difficult. -So now frames can have have bigger holes, and we can be supplied with grommets that are too small.
Hope this was entertaining. Toodles.
PostPosted: Sat Oct 12, 2013 10:25 am
Sugru is great for this. Make your own grommets.
My RCA
PostPosted: Mon Oct 14, 2013 6:51 pm
I tried all kind of Shimano grommets, SM-GM01 of 6mm, SM-GM02 od 7x8mm and grommet for old Di2 7x8mm also.
All them are loose on the FD frame hole.
I looked at Shimano and Campagnolo specifications for frame holes and are the same: 7x8mm
PostPosted: Wed Oct 16, 2013 4:33 am
Hi Please I need help for make bit my frameset Orbea Orca 2012.My frame is mechanical and wish install my DA 9070Di2 internal system so I wish make bits same position frameset Orbea Orca eletronic.I have all photos holes frame eletronic and I wish make identic but....What fiber carbon 0.8mm? Tungsten carbide bit?
Sorry my english
Thx
Sandro
PostPosted: Wed Oct 16, 2013 3:00 pm
Drill with little pressure. I used a carbide bite. A cheaper bit could be used but it will not last as long. Smaller drill size than what you need. Use a small stone or carbide grinder bit to grind the hole to the final size. I did mine and had no problems.
PostPosted: Thu Oct 17, 2013 4:17 pm
ok Thanks!
There are no new unread posts for this topic. Electronic front shift question
mbrider
Wed Jun 01, 2016 2:40 am
2lo8 View the latest post
There are no new unread posts for this topic. Front derailleur
banik69
9
975
Mon May 30, 2016 12:53 am
2old4this View the latest post
There are no new unread posts for this topic. 9070 front derailleur trim
Delorre
13
485
Tue Apr 05, 2016 9:57 pm
goodboyr View the latest post
There are no new unread posts for this topic. S2-system on Campagnolo front derailleur
Daniel1975
Thu Jan 05, 2017 10:16 pm
Calnago View the latest post
There are no new unread posts for this topic. Weak front derailleur clamp
Daniel1975
15
759
Mon Dec 19, 2016 2:03 am
Users browsing this forum: Baidu [Spider], Bing [Bot], cep111, darnellrm, Exabot [Bot], jj911c2, ooo, Treelegs and 39 guests
