2012 SRAM Red vs. DA 9000
Frankie - B
Administrator
by Frankie - B
if you are going to use a 10 speed cassette, you are.
addictR1
by addictR1
Sweet... thanks Frankie
s4life
by s4life
DA for sure.. smoother, quieter... but if you really want the best go Campy:)
oreoboreo
by oreoboreo
I now have 400 miles on the new DA9000. sure like it better than the Red that I had, Red was not bad, I just like the 9000 better.
Let's finish the ride with a 20% grade.
2011 Scott Addict R1 DA 7900 Matt black
2012 Scott CR1 Pro Ultegra 6700
2015 Specialized SWorks Tarmac Da 9000
2016 Specialized SWorks Tarmac DA 9100
eric
by eric
In what way? "Better" is not very descriptive.
oreoboreo
by oreoboreo
Like it "Better". Crisper shifts, feels precise, the toss on the shifters is the same on every shift, easier to make the shifts (compared to my 7900), shorter throw to make the big ring small ring shifts, smaller hoods for my small hands. taller shifter knobs, better hand holds on the larger knobs more secure alternate position. I like the shim on the shifters better than the 7900 for small hands.
On the Sram red, shifts were loud, however positive. Small ring to large ring too effort all the time, had to mix and match some Shimano parts to achieve the quiet and best possible shifting solution. Double tap, really like it however like the DA "better" better can just be a personal thing in this case.
I ride an 11-28 the jump on the 10 speed the jump to the 28 is 24-28 limits the range on some hills for me. On the 11 speed the final range is 25-28, on some of the steeper hills I really prefer the climb with the 25 and recover with the 28 instead of grinding the 28 the whole time. I am sure some will say get stronger and push the 24 up the hills, on some of the rides, I like to finish strong also. Is the 11 speed better, not better, however I have a better range for my riding area and style. the 9000 brakes stop, brakes they say are a upgrade maybe, the 7900 brakes and Sram red brakes worked just fine
Better :)
