It is currently Sun Jan 21, 2018 12:12 am
Post new topic  Reply to topic  [ 4 posts ]
PostPosted: Tue Oct 08, 2013 7:59 pm
I'm looking into buying a used Sram Red Quarq (2012, compact version (50/34), but having allways ridden standard chainrings I'm not sure if I'll like the smaller rings. Does anyone know what my options are if I want to change the rings to something bigger (say 52/36 or 52/39)?
I see Sram makes a 110mm BCD Red chainring in 52t, but those are the 2010 red version. Are they compatible with the 2012 cranks which have 1 bolt going in the crankarm?
Also, I read somewhere that Praxis 110bcd chainrings are not compatible with 2012 Red Cranks, is that correct?
This is my Bike. There are many like it, but this one is mine. Without me, my bike is useless. Without my bike, I am useless.
PostPosted: Tue Oct 08, 2013 8:54 pm
Hi there.
I have been running sram red 52/38 110 with no issues on an S900 crank. I presume the rings should be compatible as they all have the holes in the same place.
PostPosted: Wed Oct 09, 2013 2:46 am
Basically any chainring will work. You need to remove the pressed in chainring bolt (hidden)
On a Quarq it does not go into the arm it's just hidden. I picked up a Red 22 Quarq and removed the rings and replaced with my Praxis rings.
Just put the chainring bolt over a socket and give it a good whack with a plastic hammer. Reverse to install in new ring.
The Quarq cranksets are not the same as the Red cranks that have the hidden bolt.
Oh and by the way if the 2012 is the new style Quarq with the little led on it you can use any rings with no calibration issues.
PostPosted: Thu Oct 10, 2013 10:06 pm
Good to hear, thanks for the info!
Any tips for good 52t, and 36t/38t 110BCD chainrings? Preferably available in Europe, as I don't think the Praxis are?
There are no new unread posts for this topic. SRAM Red Chainring confusion
TimW
11
1001
Mon Jul 24, 2017 5:35 pm
pdlpsher1 View the latest post
There are no new unread posts for this topic. SRAM Red chainring compatibility with Shimano 9150 Di2
bpe
Sat Jul 08, 2017 4:53 am
There are no new unread posts for this topic. Sram Red BB386 Crankset with BB386 Bottom Bracket in BB386 Frame: Small Chainring touches Frame
jbattermann
Sun Jul 23, 2017 5:06 am
KCookie View the latest post
There are no new unread posts for this topic. Which power meter: Sram Red + Stages or Quarq Dzero Sram
[ Go to page: 1 2 3 4 5 6 ]
Shrike
75
12002
Thu Dec 14, 2017 7:12 pm
FIJIGabe View the latest post
There are no new unread posts for this topic. F10: Which headset top cap options are available?
TonyM
7
641
Sun Dec 31, 2017 11:02 pm
TonyM View the latest post
Users browsing this forum: jrccomponents, LAN and 42 guests
cron
