It is currently Thu Jan 18, 2018 1:12 pm
Post new topic  Reply to topic  [ 574 posts ]  Go to page Previous 110 11 12 13 1439 Next
PostPosted: Tue May 27, 2014 9:36 pm
Shop Owner / Manufacturer
Cheers guys and my apologies for having kept you waiting: We have been (and actually still are) really superbusy to finally get all the frames out to you guys!!
As you have eventually come to read on our recent Facebook news (or been informed via email or on the phone) our delay has sadly mainly been down to the paintings lately, but hopefully has been sorted now by our new professional painter so that everyone of the preorderers will get their frames very soon. The waiting time on new orders currently is 4-6 weeks.
To catch up on some of the most recent questions (please feel free to keep asking if anything was unclear or left unanswered):
  • the BB bearings seats are moulded (and no carbon cups) which if the fitting is exact works very well. As one can easily see through the clearcoat the BB seats have specifically been reinforced with layers of carbon fiber cloth (the 3K elements on the UD tubes) in order to be able to withstand and better distribute the forces from the BB bearings (both in rgds to the initial installation as well as the stresses under load).
    The big plus of this way of construction is not only the reduction in weight (ca. 25-35gms thanks to the omission of the nylon/plastic/alu cups) but in the first place especially an increase in bottom bracket stiffness as there is no softer plastic/nylon/alu sleeve in between the frames BB shell and crankset (which is not pictured in magazine tests)
  • The afore mentioned fork weight from marcob (360g, s.o.) was for an uncut 3T fork. I've weighed all of the THM forks and they have been all around 290 to 310 gms incl. the preload adjuster. As a reference my personal THM Scapula CT, cut for a size S frame, weighs 255 gms (fully painted with an even thicker paint coat due to coming in our team paint scheme - pictures shortly, customers of course deserve their glory 1st! :no1: ).
  • The stated weights of the frames are very accurate. Please note that - when shipped - the frames already include the bottom bracket bearings (47gms/pair), installed liners for the internal cable routing (the brake liner will only be needed for installation purposes) as well as also headset, seat post clamp, BB cable guide (moulded carbon as well), RD hanger, RD cable guide, bolted on downtube cable guides and braze-on FD hanger.
    Without faking the stated weights, me personally I at least would not include either the BB bearings, headset, seat post clamp or rear brake liner into the quotation (BB cable guide and FD hanger are at times left out as well, but I think it is necessary to include them here as they are part of the frame).
Hope that helps!
/Nils
ax-lightness GmbH: http://www.ax-lightness.de | http://www.facebook.com/axlightness | http://www.flickr.com/ax-lightness
PostPosted: Wed May 28, 2014 4:22 am
spytech wrote:
The fork in the picture where he mentioned the fork weight is not a "D" frameset, so it has the 3T fork
:doh: Good point, I was looking at pictures on page 11 with the THM fork, not from marcob's post where he quoted the weight for his 3T fork on page 10.
PostPosted: Wed May 28, 2014 6:30 am
Hello,
AXAxel/Nils I have three questions regarding the new VIAL EVO frame,
1. Can you tell us if the Stages Powermeter can be used with this frame? ie Is there enough clearance between the crankarm and the frame?
2. Will ax lightness be selling complete bikes with this new frame built up with all ax lightness parts? When would it be available, and how much will it cost with Shimano Di2?
3. Is the frame and either of the two forks (3T or THM Scapula) suitable to be used with disc brakes once they become mainstream? Eventually disc brakes will become the norm on road bikes so to have to buy new forks or another VIAL frame so soon would not be good.
PostPosted: Wed May 28, 2014 7:17 am
Hi Arlberg and welcome to the forums!!
1.) I have not had yet a Stages in my hands in person and do not know about its dimensions, but please find some pics I just took of a VIAL evo with installed Dura-Ace FC-9000 chainset: clearance VIAL evo/Dura-Ace 9000 cranks.
2.) There also are (ging to be) complete bikes around the VIAL evo, based on different build kits (shifting groups, wheels, cockpit etc.). We have not published the build kits just yet (Eurobike being the target here), so please inquire directly for an offer. Shifting components are available from either Sram or Shimano with a Di2 of course being no problem at all.
3.) The current frameset i(frame as well as both forks) s solely compatible with rim brakes. With the introduction of disc brakes we may eventually see new standards (rear hub width, rear/front axle systems), so without having certainty about these from a current perspective it does not make sense to us to commit ourselves to a certain construction just yet. Rumours are the standards will be finalized at or around Eurobike which is when we will start adopting the VIAL evo to a disc-specific model as well. I do not think hybrids make sense here. The disc model may then already become available in spring next year.
/Nils
PostPosted: Wed May 28, 2014 2:02 pm
AXAxel wrote:
[*]The afore mentioned fork weight from marcob (360g, s.o.) was for an uncut 3T fork. I've weighed all of the THM forks and they have been all around 290 to 310 gms incl. the preload adjuster. As a reference my personal THM Scapula CT, cut for a size S frame, weighs 255 gms (fully painted with an even thicker paint coat due to coming in our team paint scheme - pictures shortly, customers of course deserve their glory 1st! :no1: ).
/Nils
I've wheighted the fork after cutting it to length (26 cm) and without the preload adjuster, but with the ring for the headset, 323 grams.
As said before, my frame XL was 796 grams, but with headset, bb bearings and seatpost clamp. So i guess the weight of the frame alone will be around 700 grams for a XL, that's even less than claimed.
PostPosted: Wed May 28, 2014 3:06 pm
Hi Nils,
Can I check what BB would be required to run the THM Clavicula M3s on the Vial Evo?
Or is it not compatible with the frameset?
Thanks!!
Regards
Freddie
PostPosted: Wed May 28, 2014 3:13 pm
cfred84 wrote:
Hi Nils,
Thanks!!
Regards
Freddie
I just mounted a THM M3 crankset. It fits directly, you only need 1mm spacer on both sides.
PostPosted: Wed May 28, 2014 4:46 pm
marcob wrote:
cfred84 wrote:
Hi Nils,
Thanks!!
Regards
Freddie
Nice!! Thanks for the information!
PostPosted: Wed May 28, 2014 4:55 pm
Under construction!
I'm not sure about what to do with the liners. Do i have to remove them? Do i have to cut the to length? The don't fit in my outer cable, so how do i connect them?
PostPosted: Wed May 28, 2014 6:29 pm
Looks great so far marcob! Exquisite choice of components as well!
The brake liner can be removed completely: Our cable enters the TT on the right side and run diagonally through it to enter it at the left side - hence no chance of rattling.
For the shifters I'd leave in pieces of the liner from just in front of the integrated BB cable guide to the derailleurs to ensure that the cables are running smoothly.
Please note that a (separate) full length liner will dramatically ease up cable changes/installations, so keeping some spare will definitely come in handy.
Integrated carbon BB cable guide:
/Nils
PostPosted: Wed May 28, 2014 6:40 pm
marcob,
i'm curious to see how you like the ride since you've ridden Parlee's before. also, it doesn't look like the inside of the fork is painted with the 3T version...but i suppose that it is with the THM fork?
so far, looks great.
- AX Lightness Vial EVO D + DA9070 + Enve SES 3.4 carbon hubs
- Parlee ESX + DA9070 + THM SRM PM + Enve SES 6.7 CK hubs
- Independent Fabrication Ti FLW + Campy SR11 + Enve 3.4 CK hubs
PostPosted: Wed May 28, 2014 7:56 pm
kode54 wrote:
marcob,
I will let you know my riding experiences. As far as the weight concerns, the Vial Evo frameset is about 300 grams lighter than my Parlee Z5!
And yes, the 3T fork is all black.
PostPosted: Wed May 28, 2014 8:01 pm
Can the frameset be ordered without any paint/graphics?
Or are custom options available if coordinated with AX Lightness?
PostPosted: Wed May 28, 2014 9:49 pm
Currently we only have this one version on offer and would like to keep it at this for now.
There may be certain (limited) editions somewhen down the road, but for now we only offer this semi-gloss version with the silver/grey "stripes".
/Nils
PostPosted: Thu May 29, 2014 7:19 am
So when do the wheels ship?
There are no new unread posts for this topic. Attachment(s) Ax-lightness Vial EVO Race build
[ Go to page: 14 5 6 7 8 ]
sp3000
113
12585
Sat Aug 12, 2017 9:05 pm
4ibanez View the latest post
There are no new unread posts for this topic. I Need Help about Ax lightness Vial Racing with AX Europa Premium
Ashut
Wed Apr 12, 2017 2:14 pm
sp3000 View the latest post
There are no new unread posts for this topic. Ax Lightness Vial Evo Frame & Morpheus Crankset, rubbing at the BB
DEADRE
Fri Jul 07, 2017 5:30 am
DEADRE View the latest post
There are no new unread posts for this topic. Attachment(s) Ax Lightness Leaf vs Dash M4 saddle
Luca79
10
1677
Wed Apr 12, 2017 5:25 am
spdntrxi View the latest post
There are no new unread posts for this topic. Attachment(s) Berk Lupine, Ax Lightness Leaf II. .
MyM3Coupe
34
5153
Tue Jun 20, 2017 11:13 pm
Vuong05 View the latest post
Users browsing this forum: Baidu [Spider], Stockie, Super Guanche, tvillumsen and 34 guests
