It is currently Mon Jan 23, 2017 1:51 am
Post new topic  Reply to topic  [ 343 posts ]  Go to page Previous 17 8 9 10 1123 Next
PostPosted: Fri May 16, 2014 7:13 pm
The Bona Fide
PostPosted: Fri May 16, 2014 7:35 pm
I like the expander! Twist-to-expand mechanism?
Going with the firearms theme:
Rimfire
Breech-Loader
Breech Block
Barrel Lock
Pro-Lite Cuneo
PostPosted: Fri May 16, 2014 10:31 pm
name it after something from Speci so you can get some free press when Mikey sues you.
Casati Vola SLi and Dolan Preffisio
viewtopic.php?f=10&t=108931" onclick="window.open(this.href);return false;"
btompkins0112 wrote:
It has the H2 geo......one step racier than a hybrid bike
PostPosted: Fri May 16, 2014 11:29 pm
How much will the expander weigh Rico? On par with Tune GumGum or an Ultrastar?
2012 BMC SLR 6.02kg http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=110390
PostPosted: Sun May 18, 2014 11:22 pm
Many thanks all for the suggestions. Let's just keep an open mind for now, with the confidence that a suitable name will emerge in due time. :D
Thank you for your compliments and your suggestions. The expander part inside the fork will require a tool, but the top cap is entirely tool-less. We hope to find out how well it works with an upcoming prototype.
I get the tongue in cheek. Who would want to evoke such legal action? It's a waste of valuable time and resources which could otherwise be spent on riding. ;)
Besides, press coverage can be arranged through other methods. :beerchug:
The unit, that acts as a fork steerer expander mechanism, top cap and 5mm spacer on top of a stem, should weigh about 15 grams. How much does your current setup weigh?
“I always find it amazing that a material can actually sell a product when it’s really the engineering that creates and dictates how well that material will behave or perform.” — Chuck Teixeira
RideWert.com
Wert Cycling on Facebook
PostPosted: Mon May 19, 2014 12:35 am
That's pretty good! At the moment rnning a POP top cap and bolt @ 4 grams and a Tune GumGum @ 9 grams so 13gm all up. So yours including the 5mm spacer is really good. :thumbup:
PostPosted: Tue Jul 15, 2014 6:43 pm
any updates on this?
'83 De Rosa Professional | 2011 Baum Corretto | 2008 BMC Pro Machine - sub6 | '86 Pinarello Team | '72 Cinelli SC NOS | '58 Bianchi (in bits) | '71 Cinelli SC Reborn | '78 Masi 'Breaking Away' Replica | Project 2016.1 - underway
PostPosted: Fri Jul 18, 2014 7:46 am
i believe myth has the intentions to prototype the headset expander as soon as possible, i for one cant wait to see the result!
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=100739
PostPosted: Sat Jul 26, 2014 9:11 am
Oh, Tune Gum gum, how can you use that as reference? I have one and honestly, i would not recommend it to anyone.
My question for Wert would be about the lower stack stem designs.
I might be wrong here, but is it not so that a longer stack stem will be more stiff/ rigid?
I use a Rotor S3X among others, great stem (also low stack) but i always like to have a stem that is higher than the ordinary 40mm versions.
Why no 45mm stack? To heavy or?
Is it even possible for these light weight stems to compete with more heavy alu stems?
Let us see more picture of the expander and stem are you nice :)
Bikes:
Ax Lightness Vial EVO D
Paduano Racing Fidia
Open *UP*
https://opencycle.com/showcase/xplr3r-1-by-rickard
PostPosted: Sat Jul 26, 2014 1:43 pm
@dadoflam08: Howzit going, mate? Thanks for your interest. There's a distinct lack of updates since I thought I'd spare everyone the nuisance of not getting production going yet. Having tried to come to an agreement with various manufacturers in the past months, being let down by each one and still coming up empty-handed is nothing to write home about.
And yes, it's true what weeracerweenie said. And he is the first official Wert client. We're in the process with a long time CNC partner of prototyping the revised seat clamp, road hubs, a headset expander. Unfortunately, this firm doesn't do production. The plan was to have the stem on the market already. Hopefully, the manufacturing gods will grant Wert a good omen soon.
Let me refer to the Fair Wheel Bikes' 2014 Stem Review. The aluminum stem with the least deflection is a Thomson Elite X4 and has a specified stack height of 40.64mm, while a Thomson Elite X2, which wasn't featured in the test, has an even lower specified stack height of 36.07mm. Many stems typically have a similar or greater stack height. My reference stem is a Thomson's Elite X4 in 130mm, which I rode in the past years with great enjoyment. All my lighter previous stems weren't as stiff, even with a taller stack height, and with stems I prefer stiffness over weight.
Stiffness and durability aren't necessarily correlated, although a lighter stem is typically also less stiff due to its design limitations. My aim with the Straight Shooter was to design a stem within the stiffness range of a Thomson but at half the weight while also passing EN14781 for safety and durability. We still don't have the final pre-production prototype yet so stiffness is only indicative. Nevertheless, it seems our goal are attained with the Wert Straight Shooter stem.
Stack height of a hair under 38mm was a result of the design, and being lighter than a 45mm stack height is a matter of volume. The transition between the barrel and steerer clamp area dictated its given stack height.
On a full carbon steerer however, it's recommended to keep a few mm extra length above the stem to favor a slightly stiffer interface and, more importantly, to spread the stress a stem exerts on a steerer over a larger surface area. In addition, this provides added safety against steerer cracks to avert potential catastrophic failure.
Let's have Wert clients be the judge of that. First things first: getting these stems in production and meeting customer demand.
We'll post photos as soon as the expander proto's are done.
RideWert.com
PostPosted: Sat Jul 26, 2014 10:18 pm
I was comparring the weight to the GumGum, not performance. But on performance, I've never had any problems with any of my GumGums at all
PostPosted: Sun Nov 23, 2014 8:35 pm
Any updates?
PostPosted: Mon Nov 24, 2014 6:57 pm
Thank you for asking. To simplify machining, some minor design changes had to be implemented for the handlebar clamp area. It looks slightly different (better, if you ask me) yet weight remains unaffected. Currently, the wait is for specialty production tooling, followed by the final fatigue testing of soon to be made pre-production samples. After that, production stems should be in stock in a matter of weeks, accompanied by a few other parts.
Wert Cycling still lacks a fitting visual logo, which affects graphics, packaging and the nearly finished website, therefore making this a priority. This also influences possible Wert videos, apparel, merchandise, etc.
There is only one chance to get things right the first time around. :wink:
RideWert.com
PostPosted: Mon Nov 24, 2014 8:12 pm
Yay!
PostPosted: Tue Nov 25, 2014 3:46 am
So it'll be an 8˚. A -17˚ would have been nice, but I can live with that.
There are no new unread posts for this topic. Wert parts
HaakonJohansen
9
897
Thu Sep 15, 2016 9:17 pm
mythical View the latest post
There are no new unread posts for this topic. New derailleur-hanger not straight
Zak
7
628
Mon Nov 14, 2016 12:59 pm
sugarkane View the latest post
There are no new unread posts for this topic. Okay to stick a SRAM GXP crankset straight into a Shimano bottom bracket?
Shrike
14
774
Sun Jan 15, 2017 4:32 pm
Shrike View the latest post
There are no new unread posts for this topic. Angled brake track or straight brake track for maximum aero
mpulsiv
Thu Feb 25, 2016 6:52 am
WMW View the latest post
There are no new unread posts for this topic. Integrated bar/stem
polaris
7
910
Fri Apr 08, 2016 4:31 pm
KarlC View the latest post
Users browsing this forum: albertop07, ArtV, Baidu [Spider], Conradsleight, Gehenna, Google Adsense [Bot], JohnHinMD, TomColnago, topflightpro and 27 guests
