Covert 10 spd ergopower to 11?
michel2
Location: somewere floating between here and the other side
by michel2
Im building up my old eddy merckx mx leader and i would like to stick the old 10 speed ergo on it, just think they look better than the new ones but on my 'proper' bike i run 11speed campy so i was wondering if i could 'rebuild' the right side and convert it to 11 ?
I had no luck with google ); i know that 09 11 speed ergopowers were able to rebuild to 10 so perhaps it would be possebly to go the otherway around ?
Any help or links very much appreciated !(
bikerjulio
by bikerjulio
The old, pre 2009, ergopower shifters have a completely different internal design to the current generation. So the basic answer is no, it cannot be done. At least not with Campy parts.
Since the shifter bodies also changed in dimensions, I don't believe a current mechanism would fit either.
This not to say that some inventive person couldn't make up the parts to do a conversion, so there could be some after market solution. But I have not heard of one.
Just go with alloy Athena on your Merckx. The levers work better, the ergonomics are better, and they will look nice.
There's sometimes a buggy.
One.
Stefano
by Stefano
You cannot do it using campy parts- but there is a guy who makes custom ratchets for converting the 10s into 11. I believe I got ahold of him by emailing him at tuningxcampy@gmail.com, although it has been at least a year or two, not sure if he still makes them. Worth a shot at least, no?
EDIT: http://www.youtube.com/watch?v=MZBzT4ZmSTU
Here is the link to a youtube video with the upgrade
Good luck,
Stefano
airwise
by airwise
There was an article in last month's Le Cycle magazine explaining exactly how to change the ratchet - which is apparently available from Campagnolo - on I believe the old Centaur lever. I'll try to dig the article out.
bikerjulio
by bikerjulio
airwise wrote:There was an article in last month's Le Cycle magazine explaining exactly how to change the ratchet - which is apparently available from Campagnolo - on I believe the old Centaur lever. I'll try to dig the article out.
Since Centaur has always been 10-speed, I'd be interested to see that.
Also, back in the 2000-2006 time frame Centaur, Chorus and Record had the same shifting internals. There was nothing different about Centaur.
In 2007-8 Centaur went "escape", so I don't think that will help either.
One.
s4life
by s4life
The new campy 11 shifters may not be appealing to you cosmetically -- I think they are great however -- but I think they are much better ergonomically imho.. things like these matter when you start going long distance.
