It is currently Thu Jan 18, 2018 5:15 pm
Post new topic  Reply to topic  [ 146 posts ]  Go to page Previous 14 5 6 7 810 Next
 Post subject: Re: Schwalbe One
PostPosted: Tue Jul 01, 2014 3:33 am
Roel W wrote:
Roel W wrote:
As I'm typing this message I can still smell the rubber: just mounted some brand new Schwalbe One 25mm clinchers on a pair of second hand Campe Neutron wheels.
Will test them tomorrow...
Tested them on a 170km ride: they are fantastic. I've ridden 3 km off-road an a wet path full of stones (testing some new roads with my Garmin went wrong) without a flat. So they seem quite puncture proof.
Grip and cornering speed are much better then the Mavic Yksion tires on Mavic Ksyrium Elite wheels I used before on the same bike.
Mavic tires (the ones that come stock on Ksyrium SLRs) were TERRIBLE in the wet. No grip whatsoever. I literally back flipped my bike trying to avoid a toddler on a tricycle. Landed on my ass, and my butt bones hurt for days!
I am stuck between purchasing the Schwable One and Veloflex Carbon. Any thing to help my decision either way?
PostPosted: Fri Jul 11, 2014 8:27 am
@ steel515
I cannot reply to your PM (no clue why is that).
Concerning the pressure I'm running, I'm following the guidelines in the spreadsheet I built (attached)
<iframe src="https://onedrive.live.com/embed?cid=0A3B0820117A3295&resid=A3B0820117A3295%2115978&authkey=AEUDTAGgiR0VX_E" width="98" height="120" frameborder="0" scrolling="no"></iframe>
https://onedrive.live.com/redir?resid=A ... ile%2c.xls
PostPosted: Tue Jul 15, 2014 12:16 pm
I've had Schwalbe One tubeless in 25mm on back order from Starbike for some weeks. Does anyone have a feeling when or if the 25mm tubeless version will be available? I could just accept the 23mm version but I like the idea of the plumper tyre.
PostPosted: Tue Jul 15, 2014 1:49 pm
I have a 25mm tubeless One, coming direct from Scwhalbe North America arriving tomorrow so it seems they'll be in shops sooner than later.
My Cervelo R5
My Lynskey Helix
My MTB
PostPosted: Tue Jul 15, 2014 2:25 pm
Thanks for that info, interesting. Perhaps you could be good enough to post back here confirming when you have them in your hand so I know this format isn't just vapourware?
PostPosted: Tue Jul 15, 2014 3:21 pm
I'll be happy to Miller along with a "proof of life" photo.
My Cervelo R5
My Lynskey Helix
My MTB
PostPosted: Tue Jul 15, 2014 9:04 pm
I'm nearly convinced to try the One clincher ... bit more weight than ZX, but hopefully more than offset by being a bit faster. Change is hard!
My Addict chainstays don't look compatible with anything wider than a 23c tire, so that's the one for me.
5.7kg / 12.7lbs Addict SL w/PowerTap
9.3kg / 20.5lbs Scale 29 Pro ... woefully under-used
Retired: 5.9kg / 13lbs Addict R1 w/PowerTap ... lowest was 5.593kg / 12.33lbs
PostPosted: Wed Jul 16, 2014 12:00 am
[quote="tnc1970"]@ steel515
https://onedrive.live.com/redir?resid=A ... ile%2c.xls[/quote]
Someone wrote app or program for tire pressure. Have you tried? (Didn't work for me). You can try to PM me again.
PostPosted: Wed Jul 16, 2014 12:17 am
I bought two from bikediscount.de in late May, the arrived within a few days. Not sure if they have stock at the moment
PostPosted: Wed Jul 16, 2014 9:44 pm
Here's a photo of sasquatch:
Weight is 331g on the postal scale here at work, 9 grams lighter than the claimed 340g ;) Incidentally the 23c that's going on the front came in at 294g 11 lighter than the claimed 305g.
My Cervelo R5
My Lynskey Helix
My MTB
PostPosted: Wed Jul 16, 2014 11:49 pm
They were a pita to get on ultegra tubeless rims.
PostPosted: Thu Jul 17, 2014 1:55 am
I just ordered 2*28mm Schwalbe One's. I'm looking forward to trying them out. They replace Durano plus as my commuter tire.
Come winter I might change for something wider and with more grooves for displacing snow and water.
Current: Colnago CX Zero Di2 Disc, Cannondale F29 carbon3
Previous: Scott Plasma 3 premium, Parlee Z3SL, Parlee Z4, Argon18 E112, TREK TTX7.0, S-Works Transition, Pinarello F4:13
PostPosted: Thu Jul 17, 2014 3:39 am
Ditto on Pacenti's
My Cervelo R5
My Lynskey Helix
My MTB
PostPosted: Thu Jul 17, 2014 5:57 pm
Can you measure width after installed on wheel? ie true 25mm or narrower like 23-24mm
PostPosted: Thu Jul 17, 2014 6:38 pm
Sure no problem. I'll do it tonight for both the 23c and 25c.
My Cervelo R5
My Lynskey Helix
My MTB
There are no new unread posts for this topic. Schwalbe One Tubular- Max Loading
lord_brush
Fri Mar 03, 2017 10:18 am
lord_brush View the latest post
There are no new unread posts for this topic. Schwalbe One tire weights?
2lo8
Sun Jun 25, 2017 12:28 am
gewichtweenie View the latest post
Users browsing this forum: darnellrm, erik$, MoreRideTime, WESTMOTORSPORTS and 56 guests
cron
