It is currently Sun Jan 21, 2018 6:13 pm
Post new topic  Reply to topic  [ 146 posts ]  Go to page Previous 13 4 5 6 710 Next
 Post subject: Re: Schwalbe One
PostPosted: Tue May 27, 2014 2:43 am
Anyone else trying the Ironman tires? Allegedly 185g with a low(er) Crr per Schwalbe.
Are they new? Or, did I just wake up?!
5.7kg / 12.7lbs Addict SL w/PowerTap
9.3kg / 20.5lbs Scale 29 Pro ... woefully under-used
Retired: 5.9kg / 13lbs Addict R1 w/PowerTap ... lowest was 5.593kg / 12.33lbs
PostPosted: Wed May 28, 2014 4:55 am
had my first ride on the Ones in 23c. Replaced my ultremo zx that had a lot of cracks and got some sidewall tears (resulting in my first flat in 3 years).
No white stripes anymore, but the plain black and more subdued graphics look nice.
Not overly impressed by weight (or at least claims/constancy). One came in at 204g (1 below claim), the other at 218g. Kind of a big difference. With schwalbe extra light tubes the total comes in at 19g heavier than my previous (and worn) setup.
Ride seemed good... maybe not as fast rolling as the ultremos but very predictable and cornered with confidence.
Going to need some more time to come to a true opinion of the tire, but so far they seem decent. Not mind blowing, but not disappointing either.
Sur La Plaque!
2012 Ridley Damocles RS
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=111632
2012 Dekerf Team SST
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=112060&p=957055#p957055
PostPosted: Wed May 28, 2014 7:03 am
My tubulars runs very well. Much nicer in all aspects compared to the GP4000s.
PostPosted: Wed May 28, 2014 11:11 am
One tubeless in 25/27 finally available. Waiting for a set of 25s to arrive
PostPosted: Mon Jun 02, 2014 5:05 am
update.
rolling speed still seems on par with ultremo zx's.... but CORNERING SPEED! That's another story.
These tires instill ridiculous confidence, I've never felt comfortable cornering as hard as I have been on these tires. I certainly hold more speed through corners.
Still happy with the tires, now I just have something to comment on as far as improvements go.
Sur La Plaque!
PostPosted: Tue Jun 03, 2014 11:04 pm
How wide do they run? Asking because I've seen a pair of 25s on one guys bike but they looked quite low volume, whereas from experience ZXs can run quite large.
I've got Open Pave CG now and was struck by their low size, but they measure exactly 25mm and it turns out most other tires run wider. For example a Fortezza Tricomp 25mm is actually the same volume as a Open Pave CG in 27mm!
London2Paris24 2014 Fundraising for Scope UK
Facebook Page for more information and updates!
PostPosted: Wed Jun 04, 2014 6:04 am
i have 25 mm on 202 FC's, and i like them a lot
the measure exactly 25 mm wide and 25 high, so they are good volume
most tires are lower than they are wide (mavic and michelin come to mind)
no need to quote the above.
PostPosted: Wed Jun 04, 2014 8:22 pm
tnc1970 wrote:
I just finished my second ride on Schwalbe One 23 clincher, using Michelin latex tubes: really sweet combo at 7.3/7.8 bar. Be aware that previous setup was Continental 4Seasons with Conti Light tubes, but still...very satisfied so far.
Used in the past Ultremo ZX and I'd say they roll similar and therefore durability will be the key differentiator (if any)
Update: I'm riding also the tubeless version on a Shimano RS50-C50 converted to tubeless. Even better than the clincher version of the One: amazing grip, and very very confortable (you can drop the pressure by 10/15 psi)
PostPosted: Wed Jun 04, 2014 8:23 pm
I forgot to mention that, yes, they might be prone to small cuts. They don't look like compromising safety but I feel better filling those gaps with ShoeGoo.
PostPosted: Sun Jun 29, 2014 4:43 pm
Really interested to see how the wet performance is, with no tread, how is the grip?
PostPosted: Sun Jun 29, 2014 8:45 pm
As I'm typing this message I can still smell the rubber: just mounted some brand new Schwalbe One 25mm clinchers on a pair of second hand Campe Neutron wheels.
Will test them tomorrow...
CANYON Ultimate AL 2010
CANYON Ultimate CF SL 2014
Instagram @coureurdusoleil
So far... no issues when riding in wet conditions (I have the pleasure to experience degrees from just wet tarmac to pouring rain). Latest theories say that thread is of no use in a bike tire -23/25mm-
PostPosted: Sun Jun 29, 2014 8:56 pm
i own a set of 25. vs the conti they feel more compliant/grip better.
fyi tour mag finished testing 2014 batch of tires.... interesting schwalbe one 25/28 have higher rr vs conti gran prix 2.
Current Rides:
2017 Giant TCR Advanced SL 0 DI2 9150
PostPosted: Mon Jun 30, 2014 7:59 pm
Tested them on a 170km ride: they are fantastic. I've ridden 3 km off-road an a wet path full of stones (testing some new roads with my Garmin went wrong) without a flat. So they seem quite puncture proof.
Grip and cornering speed are much better then the Mavic Yksion tires on Mavic Ksyrium Elite wheels I used before on the same bike.
PostPosted: Mon Jun 30, 2014 11:30 pm
Strange that Conti 4000s get faster with increasing width whereas Schwalbe get slower. .......
There are no new unread posts for this topic. Schwalbe One Tubular- Max Loading
lord_brush
Fri Mar 03, 2017 10:18 am
lord_brush View the latest post
There are no new unread posts for this topic. Schwalbe One tire weights?
2lo8
Sun Jun 25, 2017 12:28 am
gewichtweenie View the latest post
Users browsing this forum: benjaminm3, Bing [Bot], Cervelolite, ewwhite, Google [Bot], hcgaloi, JayUK, NYCPrynne, themidge, wheelbuilder and 42 guests
cron
