Di2/Osymetric Installation issues
Fixie82
by Fixie82
Did a google and site search and haven't really come up with much relating to spacers that raise the height of the FD. I am installing on a Storck Scentron frame with a 54 tooth chainring, with the FD set at it's highest position with the provided 5mm spacer I am short approx 2mm from the required height.
Does anyone know of spacers the raise the FD height? I am reluctant to try and alter the mount unless I am forced to do so.
Kayrehn
by Kayrehn
Tried the 10mm spacer? I couldn't make it work even with that and had to drill holes to modify the spacer as per Tillquist's instructions.
Fixie82
by Fixie82
hmmm, its the largest spacer so may have been off with my estimate in size. Do you have a link to Tilquist's instructions? Would be very appreciative if you do.
