Shimergo? Tiagra triple 10 speed & Campy veloce ergo levers
onesweetkitty
by onesweetkitty
This is my first post, though I've read a lot of the threads.
I'm building a All City Space Horse with a a 105 front and rear hub, Tiagra triple crank (30/39/50t) et al. I'd like to use Campy veloce ergo levers because of their fit (plus they're a wee bit cheaper and maybe I'll switch to Campy when I have more money). Is this possible? I've read a lot of conflicting information online.
SDP
by SDP
You will need a shift mate on the rear.
Sent from my GT-I8160 using Tapatalk 2
bikerjulio
by bikerjulio
In the previous generation of ergopower shifters, the left would handle both double and triple.
With current Power shift that is no longer the case. There are specific left triple shifters. See here
http://www.campagnolo.com/jsp/en/groupsetdetail/item_Ergopower-Veloce-10x3_catid_8.jsp
Whether a Shimano FD will work - I don't know, but only if it has an identical pull ratio to Campy. I'd seriously suggest buying the specific Campy triple FD at the same time. And BTW the prices on Campy groups are extremely competitive now. Is there really that much difference? http://www.ribblecycles.co.uk/gsd/road-track-bike/campagnolo-2013-veloce-black-10-spd-triple-groupset?part=GSCAMP2013VELB10T&sub=conf_GS_CAR&bike=1
Add the cost of a shiftmate for the rear too.
There's sometimes a buggy.
One.
bikerjulio
by bikerjulio
Since you already have the hub, you are locked into Shimano compatible cassettes.
If you decided to go all-Campy otherwise with the shifting components, which would be my suggestion, then a spacer kit or conversion cassette that has Shimano splining but Campy spacing is probably the best option. So you'd need to buy Campy triple shifters, FD and RD. The rest can be Shimano.
One.
DMF
by DMF
Your setup will run an 8 speed Shimano cassette as is, or a 9 speed Shimano cassette if you attach the cable at the wrong side of the bolt on the RD, plenty of pictures of this if you google Shimergo. No need for Jteks unless you want a 10 speed cassette. (That requires 11 speed Campy shifters, if you want to so it without the Jtek).
I don't know where you found conflicting info, this works fine and has been done many times for many years. It's very common practice.
