It is currently Sun Jan 21, 2018 12:12 pm
Post new topic  Reply to topic  [ 6 posts ]
PostPosted: Thu Sep 26, 2013 5:28 am
my stock bike comes with 6700 calipers. My friend is selling his brand new 6800 caliper for USD150. Is this consider a brake performance upgrade? or just keep the $$$ for 7900, 9000? sorry no budget for eebrake.
http://www.starbike.com/en/thm-carbones-fibula/
thanks.
PostPosted: Thu Sep 26, 2013 5:49 pm
it's an upgrade, but not huge. Admittedly, I have not used 6800, but Shimano claims a 10% improvement in braking. I don't personally consider that to be a huge gain, especially given that the brakes are around the same weight (it's also a bit of a nebulous term. 10% improvement in what?). The principal design change is going from a single pivot to a dual pivot. if your brakes work well, go with a good upgrade, to something lighter, or more powerful. This is, in my opinion, barely an incremental step.
also, that price isn't great, considering you can get them brand new for $140 and probably less, if you shop around a little.
PostPosted: Sat Sep 28, 2013 5:07 pm
FIJIGabe wrote:
...The principal design change is going from a single pivot to a dual pivot.
Uhm, both 6700 and 6800 are dual pivot, or did I misread you there?
High-jacking the thread a bit, are the 6800 substantially smaller in outer dimensions, as in narrower frontal area, more petite appearance than the 6700? They look that way, but I can't find any decent pictures that would showcase the difference, if there is any?
The Shivenge
PostPosted: Mon Sep 30, 2013 3:58 pm
6700 isn't a true dual pivot. 6700 uses the attaching bolt as the second pivot, whereas 6800 has two dedicated pivots, where the attaching bolt only attaches the brake to the bike.
PostPosted: Tue Oct 01, 2013 3:57 am
The 6800 brakes have more power and better modulation than the 6700's.
Just like the 9000 brakes, the 6800 have a roller between the two arms that they pivot against, giving a very solid, smooth feel.
PostPosted: Tue Oct 08, 2013 1:04 am
finally i have changed from 6700 to 7900 without paying a premium price. For a brand new set of 7900 only for USD180 and managed to se my 6700 for 70 so i need to top up another 110. result? almost the same but i managed to reduce another 30g.
There are no new unread posts for this topic. Caliper: Tiagra 4700 vs Ultegra 6700
WiryMike
Mon Feb 27, 2017 4:31 pm
hambini View the latest post
There are no new unread posts for this topic. Hope RX4 Caliper
justaute
38
3743
Sun Jan 14, 2018 10:08 am
scale29 View the latest post
There are no new unread posts for this topic. Ultegra 6800 brake feel
mvcap
23
2540
Wed Mar 22, 2017 12:45 pm
redna12 View the latest post
There are no new unread posts for this topic. Matching 9100 cassette cogsets with 6800
LouisN
Mon Sep 11, 2017 2:51 pm
Ritxis View the latest post
There are no new unread posts for this topic. need a lighter front brake caliper
addictR1
Mon Nov 13, 2017 4:52 am
addictR1 View the latest post
Users browsing this forum: BdaGhisallo, jrccomponents, lone wheeler, raisinberry777, themidge and 23 guests
cron
