It is currently Wed Jan 24, 2018 6:45 am
Post new topic  Reply to topic  [ 4 posts ]
PostPosted: Wed Sep 25, 2013 11:06 am
Saw a post recently on a facebook group I'm a part of showing a 2007 CR1 BB shell shreaded to pieces, the guy said it has been repaired a number of times.
Is this a common issue? I am now worrying about my 2009 CR1, fitted with Campagnolo Ultra Torque.
Campagnolo; because it's a bicycle, not a fishing rod.
PostPosted: Wed Sep 25, 2013 12:38 pm
Not common, no. I've seen one. About 5 years ago.
It was (massively) overtightened, and fitted dry.
The threaded insert came adrift and was damaged (as well as the frame itself) when the bottom bracket was removed. After a couple of years of all weather use. (very very corroded)
Probably around the same age as the one above, 2006/2007, maybe earlier.
PostPosted: Wed Sep 25, 2013 12:42 pm
Okay well I will watch out for corrosion. It's kept indoors so tends to dry off well.
PostPosted: Sun Sep 29, 2013 4:24 pm
I have seen one CR1 where the bottom bracket shell came un-bonded from the frame when the bottom bracket was removed, Scott immediately warrantied it no questions asked.
There are no new unread posts for this topic. PF30 shell diameter discrepencies
Flapmeat
Wed Nov 01, 2017 1:00 pm
sungod View the latest post
There are no new unread posts for this topic. Oversize bearings in out of spec Trek Carbon Shell BB
[ Go to page: 1 2 3 4 ]
Mr.Gib
45
4504
Sun Jan 21, 2018 11:17 pm
spud View the latest post
There are no new unread posts for this topic. Older Quarq BB30 - still worth it?
Clean39T
Fri May 12, 2017 9:46 pm
simoncx View the latest post
There are no new unread posts for this topic. Noisy Older Hollowgram crankset and 10s Campy Record Driveline
M2G
11
635
Tue Oct 10, 2017 4:52 am
M2G View the latest post
There are no new unread posts for this topic. Attachment(s) PLEASE HELP!!!! FORK ISSUES!!!!
2phat2slow
Thu Oct 19, 2017 8:15 am
Stolichnaya View the latest post
Users browsing this forum: Baidu [Spider], Google Adsense [Bot], Hexsense, PinaF8 and 25 guests
