It is currently Sat Jan 21, 2017 7:39 am
Post new topic  Reply to topic  [ 54 posts ]  Go to page 1 2 3 4 Next
 Post subject: Cannondale CAAD11 soon?
PostPosted: Wed Sep 25, 2013 12:51 am
CAAD10= 2011- current (4 years)
CAAD9= 2007-2010 (4 years)
CAAD8= 2005 - 2006 (2 years)
CAAD7= 2002 - 2004 (3 years)
We know the CAAD10 is still around for 2014, but it is getting towards the end of its "design cycle" based on how often Cannondale has updated the CAAD series in the past. Could we potentially see a new CAAD next year (2014) for model year 2015? While the CAAD is great, other competitors are starting to catch up on aluminum bikes (Specialized, Felt, Canyon...etc.).
What would you guys eventually want to see done or hope Cannondale does for the new model?
PostPosted: Wed Sep 25, 2013 1:10 am
What could they possibly do to it to make it better than it does now? Maybe a different alloy? Not really sure what they could improve.
Gramz
Strava
PostPosted: Wed Sep 25, 2013 2:03 am
KW, that is what I thought as well regarding a slight change in alloy used. Was also thinking slight changes in tube shapes just like the CAAD family of old went through? Maybe a move away from BB30 to some new standard (I know, blasphemy to think Cannondale would ever do this).
PostPosted: Wed Sep 25, 2013 2:22 am
They've innovated themselves into a pretty tight spot IMO. They created a frame that's tough for even themselves to improve upon. It'd be tough for it to get lighter since the Al tubes are probably as thin as can be. I'd imagine Cannondale would let it ride another year while they refine other bikes. They revamped the Synapse already, so maybe a new Evo or an aero bike is around the bend. Or just repainting all the CAADs and badging them with "11 sp" and raising MSRP another $200.
PostPosted: Wed Sep 25, 2013 3:33 am
I'd like to see the CAAD 10 split into the CAAD10F and CAAD10S. The F would be for Fat people and not have a weight limit. The S would be for skinny people and not be as heavy.
PostPosted: Wed Sep 25, 2013 3:48 am
Im guessing they will give it the 73mm bb30 bottom bracket shell they did with the 2014 Synapse. If they do it till be interesting to se how they make it work in aluminum .
PostPosted: Wed Sep 25, 2013 4:07 am
For those that don't know- They just updated the caad10 frame. The rear brake cable is now routed through the top tube a la evo. We won't be seeing a caad11 any time soon.
PostPosted: Wed Sep 25, 2013 4:13 am
Seems like their current strategy is to update one model at a time, and it looks like the Synapse this go around..
PostPosted: Wed Sep 25, 2013 4:42 am
"Seems like their current strategy is to update one model at a time, and it looks like the Synapse this go around.."
Exactly. I don't follow their MTB line that closely, however it seems like we got:
CAAD10- new release for 2011 model year
SuperSix Evo- new release for 2012 model year
Slice RS- new release for 2013 model year
Synapse carbon- new release for 2014 model year
Question is what will Cannondale do for 2015 model year? Internal rear brake cable for 2014 CAAD10 doesn't equal innovation nor a new generation of the bike. Eventually a CAAD11 will come out, just like the CAAD10 came out after the CAAD9.
Will Cannondale do a aero road frame for 2015? Will they start the cycle all over again and work on a new CAAD? Will they skip 2015 for any new updates? While many think the CAAD10 is perfect, many thought the same of the CAAD9 (and still do).
PostPosted: Wed Sep 25, 2013 5:03 am
I own a CAAD7 and a CAAD9 bicycles. Pretty similar equipment on both. Centaur, Chorus, Record, Shamal on the 9. Veloce, Open Pro on the 7. Both 9 speed cassette. I consider both bikes to be identical. Both good frames. Neither better than the other.
PostPosted: Wed Sep 25, 2013 5:10 am
Even the CAAD7 and 9 had their differences. The CAAD7 used the "Optimo" tubing for the first time and the frame had the teardrop shaped toptube and used round seat stays. The CAAD9 used the same rear end as the SystemSix which used the bladed rear stays similar to the CAAD8 but they were moved laterally slightly. The CAAD9 was also stiffened to make it more comparable to the CAAD4/5/6 in terms of stiffness. While you might consider both to be identical, they really weren't.
Cannondale makes changes from one generation CAAD to the next that are greater than just adding internal cables for the rear brake. Maybe for CAAD11 they will go with internal cable routing.
PostPosted: Wed Sep 25, 2013 5:25 am
I think it will be a while before you see any significant change. They still sell very well so it's a staple to the line up.
PostPosted: Wed Sep 25, 2013 7:48 am
They could replace some of the tubes with carbon :lol:
Ti or dye!
PostPosted: Wed Sep 25, 2013 10:56 am
May seem a bit of a U turn, but wonder if they might go back to smooth welding. IMO it differentiates them from the competition and the caad8. A bit more costly in the build but supports the premium pricing.
PostPosted: Wed Sep 25, 2013 2:40 pm
As others said, it's hard to improve on such a great platform. I'd like to see full internal cabling and have the frame compatible with both mechanical and electronic drivetrains. Maybe a tapered headtube?
My Bikes:
BMC SLR01 TeamMachine
Cannondale CAAD8
There are no new unread posts for this topic. Cannondale 3.0
Enda Marron
Thu Feb 18, 2016 1:56 am
Bluechip View the latest post
There are no new unread posts for this topic. Cannondale Si 130 Bcd, usable with 52/36 or 50/34?
ultyguy
Thu Mar 03, 2016 9:02 am
ultyguy View the latest post
There are no new unread posts for this topic. What Colour is My Cannondale?
Valbrona
Fri Jun 03, 2016 1:46 am
BRM View the latest post
There are no new unread posts for this topic. Cannondale Contact?
Enda Marron
Tue Mar 15, 2016 11:30 pm
Skylark View the latest post
There are no new unread posts for this topic. Cannondale Custom Lab
phlip
11
1445
Tue Mar 29, 2016 9:02 am
jdecraene85 View the latest post
Users browsing this forum: Bing [Bot], thprice, wootenlakeguy and 21 guests
