It is currently Fri Jan 19, 2018 1:07 am
 Post subject: Help Fuji SST 2.0
PostPosted: Sat Sep 21, 2013 6:34 am
I recently bought a 2010 fuji sst 2.0 and thought the seatpost was going to be high enough but it is a few cm to short. i have researched and tried to find a fix for this but doesnt seem like there is much hope. i was thinking of having someone do some carbon work and extend the seatpost a little but i cant find anyone to do this other than a company in australia and might as well buy a new frame for the cost. I also contacted fuji about getting a seatpost and clamp from the non isp version but they will not do this. does anyone have any suggestions or know of a seatpost that will work with this frame so i can make it into basically a non isp.
any advice appreciated.
 Post subject: Re: Help Fuji SST 2.0
PostPosted: Sat Sep 21, 2013 8:00 am
How many cm's too short is it?
If its only a bit you might be able to find a saddle with higher rails to make up the difference? Not ideal and wouldn't be able to make up a large difference but could be worth a look. There is a good 1cm hight difference between my Arione and an old Flite.
PostPosted: Sat Sep 21, 2013 10:56 am
Does it have the Ritchey aero ISP seat mast head? I think they had an extended version for such cases as yours. But good luck finding one. Also think it came on Wilier, Scott and GT frames.
PostPosted: Sat Sep 21, 2013 2:16 pm
The seatpost topper can handle up to 2cm extension. You just need to find some shims... A fuji dealer should have some, or at least leftover isp that you can cut to size. Also consider a new saddle with larger rail to seat top dimension, if you are really close and need those extra few mm to stay within 2cm.
PostPosted: Sun Sep 22, 2013 3:21 am
thanks for the replies...i think ill need a little more than larger seat rails...but could be helpful. im not real familiar with shim deal your talking about with the post topper near the top of the seatpost i still need to go up about 2.5-3cm. it has an oval concept seatpost topper. where exactly are you placing shims to get height and keep it from moving. with it placed in the high position now it rocks back and forth due to not enough support from seatpost.
PostPosted: Sun Sep 22, 2013 4:00 am
i think i figured it out. adding spacers under the seatpost topper.... ill give that i try and see how much i can get and if it stops it from moving.
PostPosted: Sun Sep 22, 2013 4:17 am
The topper should sit on ISP, not just stay in place with bolt tension. The 2cm is the maximum amount of spacer/shim material you can stack on top of the cut ISP for the topper to sit on.
PostPosted: Sun Sep 22, 2013 5:34 am
ok that and a seat may make up enough difference. hopefully
PostPosted: Mon Sep 23, 2013 2:36 am
There is an extra large seat topper too with 4cm worth of increase. Ritchey do it too
PostPosted: Mon Sep 23, 2013 3:07 pm
ya ive tried to find one but im having a hard time finding the right one in teardrop shape. my other option is that i can have a fabricated extension piece made to fit into the seatpost and have a lip that would rest on the existing seatpost and is exact teardrop shape and diameter. so the topper could be on that, but this piece would have to be epoxied or something to stay in place. i was trying to avoid this...but it would give me the height i need easily. any thoughts.
There are no new unread posts for this topic. 2018 Fuji SL
Roni1
32
7034
Mon Nov 27, 2017 4:44 pm
Hamfist View the latest post
There are no new unread posts for this topic. Fuji SST 1.0 Aero set up
jchehan
Mon Feb 27, 2017 9:49 pm
Allen254 View the latest post
There are no new unread posts for this topic. 2017 Fuji SL Elite value?
frknvgn
Thu Sep 07, 2017 8:50 am
Squashednuts View the latest post
There are no new unread posts for this topic. 1X Fuji Roubaix Build
ohyeah22
Thu Dec 28, 2017 11:27 am
Marin View the latest post
There are no new unread posts for this topic. What light seatpost clamp for a Fuji SL 1.1 and size
Roni1
Sat Aug 12, 2017 10:33 am
zoki76 View the latest post
Users browsing this forum: Baidu [Spider], BigPoser, Esterhas, ghostryder, Imaking20 and 29 guests
