It is currently Wed Jan 17, 2018 11:20 pm
Post new topic  Reply to topic  [ 11 posts ]
PostPosted: Fri Sep 20, 2013 7:29 pm
Any experience with this? Worth using?
PostPosted: Fri Sep 20, 2013 7:33 pm
Never had great success with FSA cranks, but honestly, that's mostly due to the chainrings... I bet if you replace the rings with something that shifts better, you'd be ok.
PostPosted: Fri Sep 20, 2013 10:08 pm
Can't speak to experience on the road or the road chainrings, but I have used that crank on cyclocross bikes paired with Thorne and later Wickwerks chainrings with no issues.
PostPosted: Sat Sep 21, 2013 12:29 am
I have one that I have been using for about a year and it has been rock solid. No problems at all. I had an early K-Force crank that I hated but this one has been very good.
PostPosted: Sat Sep 21, 2013 1:23 am
I have the SL-K Light crankset on one of my road bikes and I've had zero problems with it. I am running Praxis (50/34) chainrings on it, although the stock chainrings aren't too bad, but about 28 grams heavier. Crankset weight with the Praxis rings is a respectable 549 grams (175mm).
PostPosted: Tue Sep 24, 2013 11:12 pm
I had mine for 2 years and had no problems apart from a small creak but think that was just down to the BB30 frame but I never tried to fix it. The rings were fine for me. I think they actually shifted better than my Sram force setup that I'm using now. I did weigh the rings and think the big one was either 130 or 150 so weight savings to be had if you do change them.
PostPosted: Wed Sep 25, 2013 4:18 am
Good light cranks for the money. Only issue I have seen with them is when someone man-handled the one key release.
PostPosted: Wed Sep 25, 2013 4:47 am
What is the weight of a standard crankset? Compact seems to be in the mid-500g range. Would assume standard might be another 15-20g on top of that?
Would you guys go with the FSA SL-K Light crank or one of the first gen Hollowgram SI cranks? Hollowgram should still be slightly lighter, but I don't know about stiffness?
PostPosted: Wed Sep 25, 2013 4:58 am
In terms of quality, workmanship, and future resale value, I would go with the Hollowgram Crankset. Opinion only.
I got a set of the Magic Motorcycle cranks not long after they came out (now on my beach cruiser), and was in love with that design for good..
PostPosted: Wed Sep 25, 2013 10:08 am
Swapped out my k light for a hollow gram sisl. It's stiff. I love it.. No issues after 10k
Sent from my GT-I9305T using Tapatalk 2
David
[b]'10 CANNONDALE CAAD10
PostPosted: Wed Sep 25, 2013 12:11 pm
considering price against performance it's FSA all the time
but, this place being called weight weenies...
There are no new unread posts for this topic. Which Rotor crankset for Power2Max for BB30?
JunkyCollegeBiker18
13
1045
Wed Mar 01, 2017 7:32 pm
jfranci3 View the latest post
There are no new unread posts for this topic. SRAM Etap crankset with BB30 compatible with Scott Addict SL (BB86)?
wootenlakeguy
Mon Feb 20, 2017 11:17 pm
grover View the latest post
There are no new unread posts for this topic. FSA K-Force light crankset with Shimano BB?
ave
Tue Apr 04, 2017 11:14 pm
MisterMuncher View the latest post
There are no new unread posts for this topic. Carbon Ti \ DA9000 chainring experience?
itsacarr
Fri Sep 01, 2017 5:30 pm
itsacarr View the latest post
There are no new unread posts for this topic. Input on new frame (carbon, disc, bb30) - opinions welcome
ToughInTheStreets
Fri Dec 15, 2017 4:25 pm
dim View the latest post
Users browsing this forum: Bing [Bot], flafonta, Geordiepaul, jb, mortirolo, Zakalwe, Zitter and 44 guests
