Castelli sizing (shorts)
Devon
by Devon
So I'm looking at a pair of new shorts and have found a good deal on Castelli Velocissimo. I have an issue with sizing however. According to their size guide, the 'Small' size is huge around the waist, yet the 3XL is too short in the leg...
My measurements:
Waist: 76cm
Inseam: 88cm
Any recommendations as to size?
It upsets me a lot how cycle clothing manufacturers refuse to produce clothing for real cyclists.
Campagnolo; because it's a bicycle, not a fishing rod.
farva
by farva
Not sure what to say about your sizing issue. The 3 pairs of castelli bibs I have all ran small.
I normally wear a size small but medium fits in castelli
Devon
by Devon
In regards to things running small, is this the usual "oh they're race fit so they're small", or are they genuinely small? Shorts should be tight fitting.
Stoo
by Stoo
I usually go for medium and run large in Castelli
76cm waist
'17 Giant Trinity Pro TT - DA9070 - Rotor 3D+ P2Max - Zipp 900T/HED Jet 9+
'16 Genesis Equilibrium - U6800 - FSA SRM - WH6800
'15 Cannondale Super Six Evo HM - DA9000- DA9000 SRM - CC40C
'13 Giant Trinity Composite - U6800 - QuarQ DZero
AFA
by AFA
I wear a small in Castelli, they fit perfect for me. My waist is 76cm, inseam is 82.5cm. I would say that if you were between sizes on their chart it would probably be a good idea to size up.
AFA
by AFA
On the running small, I would say the sizing chart is spot on for race fit. If you are used to a "club fit" go one size larger.
Devon
by Devon
AFA wrote:On the running small, I would say the sizing chart is spot on for race fit. If you are used to a "club fit" go one size larger.
The issue is the size chart starts massive! The Small is 80cm waist! So going solely on that I'm screwed for race fit.
Devon
by Devon
I guess a lot of it is down to thigh size - as two people with my waist size use very different sizes (Small to Large). My thighs are approximately 50cm (measured over my trousers at my office desk with a tape measure haha)
AFA
by AFA
I believe since the size chart does not list a range, the number listed is the maximum that will fit. Shorts stretch to fit, but there is a maximum that they can stretch. My thighs are 55cm and I could not imagine wearing an XSmall.
Devon
by Devon
AFA wrote:I believe since the size chart does not list a range, the number listed is the maximum that will fit. Shorts stretch to fit, but there is a maximum that they can stretch. My thighs are 55cm and I could not imagine wearing an XSmall.
That is very logical, hadn't thought of it that way, thanks!
HUMP DIESEL
by HUMP DIESEL
Check this site out and you can email the owner. He can help you with the sizing.
www.classiccycling.com
HUMP
Why are the best things in life always the ones you start last?
bman11
by bman11
As others have stated, I also sized up in Castelli. Shorts went from M to L and jersey from L to XL. I am 6 ft 1 in tall and 170 lbs. hope this helps
Just dig in and climb it!!!
Ceebers1
by Ceebers1
Older Castelli stuff fit pretty much like everything else (except gloves, which ran way too big)
Newer stuff runs small (and gloves still run big)
It seems like some of the lesser expensive shorts run a little bigger than upper end, but that may be due to compression fabs and what not.
Devon
by Devon
Thanks for the advice guys, I went with Santini in the end! Cheaper :lol:
shimmeD
by shimmeD
Prendas Ciclismo is where I get my Santini.
Less is more.
