It is currently Sat Jan 20, 2018 2:50 am
Post new topic  Reply to topic  [ 116 posts ]  Go to page Previous 14 5 6 7 8 Next
PostPosted: Sat Nov 16, 2013 10:29 am
So I went to my local distributor today and I'm surprised that they are selling a rotor 3d plus p2m ( no rings or bb) for 1700 odd euro, which is quite frankly even counting in distribution costs / profits rather ridiculous.
Forgot to add that I live in Singapore.
PostPosted: Fri May 16, 2014 12:48 pm
How are people getting on with the new type s P2M ?
they look excellent value @ 940 Euros toying with flashing the cash asap
PostPosted: Fri May 16, 2014 1:46 pm
Using one for a couple of months, absolutely no issues so far.
PostPosted: Fri May 16, 2014 1:52 pm
My Type-S has been flawless also.
VeloKicks
The Gram
The Men of Steel
PostPosted: Fri May 16, 2014 1:54 pm
Mine works exactly as expected.
PostPosted: Fri May 16, 2014 2:54 pm
My Specialized Type-S has also been flawless. Very consistent data from ride to ride. Love it!!
Hector Cabrera
Orlando, FL
2011 Spec Tarmac Pro DA
PostPosted: Fri May 16, 2014 2:56 pm
By the way, I have compared my P2M to my Cyclops Power Beam Pro (Built in Powertap) and it's always within about 3 watts of the Powertap (Powertap reads lower which makes sense since you have drivetrain losses). I have tested anywhere from 150-500 watts and it's always almost dead on.
Hector Cabrera
Orlando, FL
PostPosted: Fri May 16, 2014 5:22 pm
My Type S has been awesome. Zero issues, just like with my last P2M.
Gramz
Failed Custom Bike
PostPosted: Sun May 18, 2014 7:07 am
My Type S (for S-works) has been flawless as well. Love it. Never an issue other than needing a 2mm spacer to fit on my BMC TM02- it rubbed without the spacer.
PostPosted: Sun May 18, 2014 12:09 pm
Why don't you order from them direct then ? :noidea:
its Euro 1090 ( including VAT, which you're exempt from, so would be about Euro 927, excluding shipping and taxes for you) .
http://www.power2max.de/europe/en/
PostPosted: Sun May 18, 2014 4:32 pm
Don't have the new type S, but as a brand I could not say enough about them. I have the Rotor 3d P2M and in 18 months of heavy usage, swapping from winter bike, to turbo frame and to road race bike, it has never missed a beat. 2 battery changes, which were carried out stress free. This is just as, something great should be, - it does exactly what it is supposed to so well, you never have to give it a single thought :D
PostPosted: Sun May 18, 2014 7:26 pm
Power2Max have a really good product, and really good customer support to back it up.
Meanwhile, SRM are resting on their laurels and being left behind.
PostPosted: Sun Jun 29, 2014 8:38 pm
Hi, is the Type S just one unit that is the same, I see there is different versions on the site but are you limited to one crank once you decide on one? I think the way the website is setup is to allow different options depending on the crank choice like the BB30 adapter to bb24? I have a cannondale CAAD10 and the bottom bracket creaks like plenty of other BB30 bikes. I was hoping to purchase the praxis adapter, but I am undecided on which cranks I will need. I don't think my existing FSA-SL-K carbon cranks can be reused if I am ditching the BB30?
PostPosted: Sun Jun 29, 2014 9:43 pm
Hi,
the Type S models differ by crank, because the crank interfaces differ.
If you want to use a 24mm crank with a conversion BB I would recommend the Rotor 3D with the Rotor or Praxis Works bottom bracket adapter.
You won't be able to use a SL-K crank set because the spider and crank are integrated in one piece and you need a separate spider and crank arm. Hence the recommendation for the Rotor 3D.
Best
Nicolas
No longer in the industry
There are no new unread posts for this topic. Wich TT size is best (huge diff in BB drop !!) ?
LouisN
Mon Jan 15, 2018 4:16 am
alcatraz View the latest post
There are no new unread posts for this topic. Top tube internal cable adapters for huge holes
LouisN
Thu Nov 16, 2017 1:43 pm
Rudi View the latest post
There are no new unread posts for this topic. best gps unit for power2max
dedobike
18
1267
Fri Nov 10, 2017 6:59 am
TonyM View the latest post
There are no new unread posts for this topic. power2max power meter
bikeracer99
35
3696
Thu Mar 30, 2017 6:12 am
PinaF8 View the latest post
There are no new unread posts for this topic. Power2max vs Pioneer Ultegra
JBeauBikes2
9
1021
Wed Aug 30, 2017 9:22 am
RJKflyer View the latest post
Users browsing this forum: Bing [Bot], bouds, Google Adsense [Bot], oldnslow2 and 25 guests
