It is currently Tue Feb 21, 2017 2:13 am
Post new topic  Reply to topic  [ 116 posts ]  Go to page Previous 13 4 5 6 7 8 Next
PostPosted: Wed Oct 23, 2013 11:30 am
Hi ash1,
The Type S - a new power2max model - will be available for Cannondale SI and SISL cranks from February, but we won't sell the cranks with the power meter.
Best
Nicolas from power2max
No longer in the industry
PostPosted: Wed Oct 23, 2013 6:11 pm
will be available in february all the s type models??
PostPosted: Wed Oct 23, 2013 6:21 pm
Hi trilocus,
yes, that's the plan.
Best
Nicolas
PostPosted: Wed Oct 23, 2013 9:01 pm
Is there any plan to use Shimano crank arms, or just to offer the 4 bolt drilling for a spider that will go on a different set of arms?
PostPosted: Wed Oct 23, 2013 10:02 pm
PostPosted: Wed Oct 23, 2013 10:27 pm
@Dammit: unfortunately we don't have access to Shimano cranks (Shimano doesn't make any of the current cranks for power meters). We will offer the Rotor 3D+ and the FSA K-Force Light with Shimano 4-hole pattern. Possibly also other models, but that's still TBD.
Best
Nicolas
PostPosted: Wed Oct 23, 2013 10:40 pm
Thanks Nicolas, I'd seen the pictures of the 3D+ with the Shimano 4 bolt drilling, just wondered about other options.
PostPosted: Thu Oct 24, 2013 11:03 am
Curious, can an existing FSA K force light crank (2012) be fitted with a power2max ?
r
PostPosted: Thu Oct 24, 2013 11:10 am
@davidalone: Unfortunately not, because the spider is integrated. The FSA K-Force Light that we have is a specific model for power2max, without the spider.
Best
Nicolas
PostPosted: Fri Oct 25, 2013 1:11 am
Great heads up,thanks?
Sent from my iPad using Tapatalk - now Free
PostPosted: Fri Oct 25, 2013 5:40 am
@jever98: Rotor's compatibility charts show that the 3D is compatible with BBRight, but none of the power2max websites show this compatibility - is this an error on the p2max website, or is there a difference in the cranks that prevents this combination?
long story short: i want to install a road rotor3d into a beer components eccentric bottom bracket on a mtb PF30 frame (niner air 9). it will work with a 3d+, i just need to use less than 11mm of spacers on the NDS, but the 3d is like $200 cheaper from the NZ distributor so if i can use it instead i will.
PostPosted: Fri Oct 25, 2013 6:58 am
@mentok: good catch. The 3D works with BBRight. We recommend the 3D+ because of the 30mm axle. I'll get it corrected on the site in the coming days, thanks for pointing it out.
Cheers
Nicolas
PostPosted: Mon Oct 28, 2013 11:59 am
Paypal or credit card payments isn't available at moment, isn't it ?
PostPosted: Mon Oct 28, 2013 12:14 pm
@ultreia: in the US it is, in Europe it isn't unfortunately,
PostPosted: Fri Nov 08, 2013 4:18 pm
Hi Nicolas ,
Just want to say thank you for your presence in the forum.
Will there be MTB version of S Type ?
I am particularly interested in Hollowgram version that is XX1 compatible .
Thanks
There are no new unread posts for this topic. Wilier 101SR & power2max ?
stormur
Mon Feb 06, 2017 9:18 am
stormur View the latest post
There are no new unread posts for this topic. power2max crankset choice
commendatore
Mon Jun 20, 2016 5:00 pm
eric01 View the latest post
There are no new unread posts for this topic. Rotor inpower or power2max
TomColnago
11
1081
Tue May 31, 2016 6:13 pm
There are no new unread posts for this topic. Power2Max NG. Where is the Shimano four bolt version at?
jspaceman
13
1323
Sun Dec 25, 2016 12:49 am
TheDarkInstall View the latest post
There are no new unread posts for this topic. 2016 Wilier Cento1SR and Power2max Fitment
r_mutt
Sat Dec 17, 2016 9:26 pm
r_mutt View the latest post
Users browsing this forum: Bing [Bot], CrankAddictsRich, NYCPrynne and 29 guests
