It is currently Sun Oct 22, 2017 11:32 am
Post new topic  Reply to topic  [ 13 posts ]
 Post subject: FSA Compact Bars
PostPosted: Sun Sep 15, 2013 1:43 am
Is there only one FSA Compact shape? Or, has there only been one FSA Compact shape? I ask this because in pictures some FSA Compact bars can look quite different from other FSA Compact bars.
Thanks.
 Post subject: Re: FSA Compact Bars
PostPosted: Sun Sep 15, 2013 8:58 am
Compact refers to the drop shape, not the bar shape. So most of the fsa models will have a standard drop model and compact drop model. Look at the fsa website for more info.
PostPosted: Mon Sep 16, 2013 1:14 am
I would be interested to know whether the dimensions of FSA Compact have changed since it was introduced and if there are any variants out there. Or are all FSA Compacts the same dimensions?
There's no need to get insulting
PostPosted: Mon Sep 16, 2013 6:42 am
my point remains. why not just go to the FSA site and take a look at published drop/reach figures? taht would answer your question.
PostPosted: Mon Sep 16, 2013 7:11 am
Awkward? I thought he gave you a great piece of information and good advice to help you find answers to your questions.
You sound more ungrateful than he sounds awkward.
PostPosted: Mon Sep 16, 2013 2:35 pm
Again, visiting the FSA site will yield the most definitive information but FSA does not make a variant of the 'Compact' drop. I suspect what you may have seen is one of the new 'Ergo' bars which has a 150mm drop and 80mm reach versus the Compact's 125mm drop and 80mm reach.
 Post subject:
PostPosted: Tue Sep 17, 2013 3:11 am
PostPosted: Tue Sep 17, 2013 8:07 am
and I suspect that you really wouldnt feel the difference in that 2mm.
 Post subject:
PostPosted: Tue Sep 17, 2013 9:53 am
PostPosted: Tue Sep 17, 2013 3:31 pm
If I am interested in how the dimensions of the FSA Compact shape have changed over the years, how would looking at the FSA website help me with that? The FSA website just shows the dimensions of the FSA Compact shape how it is today.
PostPosted: Tue Sep 17, 2013 4:28 pm
Oh, I don't know, how about RTFM - i.e. take a look at FSA's tech support section where you might find technical reference documents for older products?
PostPosted: Wed Sep 18, 2013 12:26 pm
Causidicus wrote:
2mm can be quite significant when you have gone to the trouble of custom frame measurements. Even 1/2 a millimetre can be perceptible to some.
Alright, I'll bite. I'm a biomechanics researcher. My brother in law is a continental cyclist and a retul+serotta trained bike fitter who also makes custom steel bikes. we are both mechanical engineers who are starting our own bike-parts business together. we share notes pretty regularly. in our experience the human body is not perceptible enough to tell a 1/2mm difference. simply no way. at 0.5mm you are talking in terms of engineering manufacturing tolerances already (i.e. when your bike parts are manufactured, things are never perfect due to calibration/measurement errors, differences in the machine, etc.) . now 0.5mm would be approaching the low end of engineering tolerances, and I think bike parts are manufactured to slightly better toleracnes than that, but really, I'd bet you it wouldnt be difficult to find bike parts off spec in that region. these tolerances are good enough for aerospace/automotive applications, and they don't even make a difference in my research where I have machines requiring calibration way more precise than any human can need. you can feel the difference of 0.5mm? I sincerely doubt so. I'd bet its in your head. 0.5mm could arise from so many different things ( abit thicker layer of paint, poor lacquer job, improperly done bar tape, etc.) if your fit had to be dialed in to the 0.5mm, you'd spend more time getting your fit right than actually riding.
( in fact, I just did an experiment yesterday. a 4cm long, 3mm thick alumnium plate I tested deforms about 0.4mm when under 49kg of load. Now, I'll grant you that the shape of the sample in question plays a part as well, but it shows you the level of detail you're talking about. I wouldn't be surprised if your bars deformed somewhere in that region when under load, and 50kg isn't an unreasonable load to see your bars under. which would mean that you'd need to take into account ahndlebar flex under load if you wanted to set your bike up right, if according to you you can feel a 0.5mm difference! thats silly !)
now, I'd grant you, if you had some specific physical problem, there IS a chance that 2mm may be important to you. which is why i said I SUSPECTED the OP wouldn't feel the difference. but for the vast majority of the population anything below 5mm difference would be really difficult to judge the difference.
^ this. Or you could contact FSA customer support. you do that when you need to get a quotation in your day job, or when you're buying a car, or need help at a store. you ask the staff. :roll: people need to learn to use the search tools.
 Post subject:
PostPosted: Thu Sep 19, 2013 11:59 am
 Post subject:
There are no new unread posts for this topic. Compact v semi compact
wilwil
35
2040
Thu Jul 27, 2017 11:05 pm
shimmeD View the latest post
There are no new unread posts for this topic. Changing to compact?
Peedee
11
1062
Fri Mar 31, 2017 11:26 am
DJT21 View the latest post
There are no new unread posts for this topic. Compact Handlebar with Flat Top?
daveydoo
24
1835
Thu Aug 17, 2017 2:47 pm
daveydoo View the latest post
There are no new unread posts for this topic. Looking for compact aluminum handlebar under ~260 grams
mpulsiv
21
1963
Thu Feb 02, 2017 11:14 pm
DutchMountains View the latest post
There are no new unread posts for this topic. Ribble R872 and campy compact cranks
Stewche
Thu Mar 23, 2017 11:40 pm
OliverRB View the latest post
Users browsing this forum: Baidu [Spider], csteeds, PetSounds and 24 guests
