Dura Ace 9000 11 speed cassette- rubish product design
spud
by spud
So long as the lock ring is tight enough to prevent the carrier from squirming on the freehub body, that should be sufficient. If the freehub body itself flexes, that could cause the carrier to twist so that chain tension produces a force across the carrier, which it may not like.
I've had creaking from my DT hub in the past, and always felt it was the freehub body squirming. Maybe it was something else, but I tried multiple cassettes on it, and they alway creaked when on the 19 cog (which happens to be near the middle of the freehub body, where it is unsupported by bearings).
by 5 8 5
bikerjulio wrote:
This breakage pattern is user error.
I don't have any interest in this other than idle curiosity. I'm 100% Campy :D
What is it that the "user" did wrong do you think?
I was wondering the same thing considering the torque issue has been put to bed.
FourRings
by FourRings
4914 wrote:Regardless of this I think many would agree its still a bad idea to use a carbon spider body in a cassette
Unless you're a Mechanical Engineer / Materials Scientist who's done a thorough analysis of the design and materials, this really is pure conjecture.
uraqt
by uraqt
"pure conjecture"
Just like everyones assumptions that it's a user issue!!!!
C
pdlpsher1
by pdlpsher1
If carbon is so good for this application why didn't Shimano use carbon on the last two cogs?
rijndael
by rijndael
pdlpsher1 wrote:If carbon is so good for this application why didn't Shimano use carbon on the last two cogs?
Unless he works for Shimano, or has inside information, how is he supposed to answer that question without more conjecture?
pdlpsher1
by pdlpsher1
I'm sure he's connected with Shimano or the bike shops. He's the one who said there aren't many reported failures. Only an insider would know the number of reported failures.
FourRings
by FourRings
Oh, this is getting fun - now we have conspiracy theories. Well, to put this particular conspiracy theory to rest, I have no connection to Shimano, bike shops, or the bike industry. Full disclosure: I did work in bike shops when I was in college over 20 years ago and I do ride Shimano equipment.
My interest here, is to try inject some thoughtful discourse into the discussion or, if nothing else, an alternate viewpoint.
11.4
by 11.4
This is a long read, so my apologies for that. But this thread is so full of speculation and errors that I thought I'd just contribute what little I can do that's impartial and factual.
First, I have no dog in this fight. I'm not affiliated with Shimano, a bike shop, or anybody else in the industry. So I have no reason to cover up or to foment a storm.
Second, as far as credentials go, my career (and my doctorate) have been focused on high volume manufacture of precision composite devices for medical and military purposes (both areas with high regulatory oversight). I've also worked in the past with a couple ultra high end automobile manufacturers and a couple carbon fiber bike component manufacturers to do manufacturing design and failure prediction.
Third, any time a bike equipment manufacturer encounters a failure (typically a report from a bike shop and usually a matter of replacing an item), the manufacturer has to report it to CPSC. If any number of problems arise (the number determined statistically based on manufacturing numbers reported by the manufacturers to CPSC), they escalate the problem and begin to investigate it. They are watching for long-run trends, for bad manufacturing runs (cluster failures), and for consistent patterns of failures. You can FOI most of this information but it's usually processed for release and won't tell you much -- only attorneys find it useful.
Now on to the failures documented here. 4914's failures were documented in two threads on this forum (and are the only postings he's made on WW). As his forum name says, he sees himself as a former track sprinter. Now 4914 shows three photos of failures. The first one involves failure of the outside cog of the three (which has its own set of rivets); the other two superficially involve failure of the other two cogs (which are joined by their own quasi-independent set of rivets) (but let's get back to this in a moment). Let's look first at how this group of cogs is engineered. The outer cog is supported independently by its own rivets, and the back of the rivets additional bear on the shoulder of a fairly substantial pillar. This is the only actual rivet failure I've seen. In the other two cases, there's no clear way to know which cog of the inner two was in use when the spider actually fractured, but since they are joined and the rivets still appear to be intact, they had to break off as an integrated unit. If you look at one of these spiders, you'll see that the single outside cog is mounted towards the rear (counterclockwise) side of the spider, so it actually has most of the spider to break through. The two in the rear actually bear against the spider plus the rivet for the single outside cog. That's good engineering to make this unit extremely strong. (This is also why the rearmost two cogs aren't mounted on a carbon fiber spider. Plus, if on a low flange hub like most road hubs today, if the chain derails into the spokes it will drop down against the spider and a carbon spider can't handle that as well as aluminum can.)
Now, the question was raised of whether carbon fiber was strong enough to begin with. If carbon was used in a unit like this on its own, then the answer would probably be no. But the parts of this cassette unit act in an integrated way. The spider gains immense strength from being pinned to two different sets of cogs -- you would typically have to snap a cog to weaken the spider (or have a rivet failure). Now go back for a second to the observation above about how one rivet bears against the other in the spider. If you look at #2, you can see that the front cog has actually failed and that allowed the rear cog to collapse shortly after. In #3, the rivets of the outside cog are still at least partially enclosed within the material of the spider, so they never dislocated -- this was a failure of the inside ones. And the inside ones actually ripped away the carbon surrounding the outside-cog rivets as well. This is a very improbable failure.
There's a thread cited on an Australian forum that refers to someone who broke two 9000 cassettes back to back. No photos, so no way to assess what happened. There's also a poor Twitter photo of Craig Bennett's cassette having a failure, and in that case it isn't clear what happened -- whether the chain simple derailed behind the cassette and collapsed the cluster, or whether it suffered a failure of the inside or the middle spider is unclear. However, the tooth configurations and the continuous drilling around the smallest cog are inconsistent with a DA9000 cassette anyway. It might be Ultegra or possibly something nonstandard, but it isn't a 25 or a 28 Dura Ace 9000 inner cog. So we can't deal with those instances in any analytic way. So, back to 4914's three failures.
There's no evident damage on the back side of the inside cog, so it doesn't appear that something was happening on the inside that snapped the cogs outwards. However, look at the splines that mate with the freehub. All three cassettes, for being brand new, show significant fraying of the splines. Now since the center of the spider is intact in all three cases, there is no way that the spline could lift up and pop over the freehub splines, at least so it could fray a few of the splines and not others. That damage could only come if the spider were flexed hard inwards or outwards. It would be helpful to see both sides of all three spiders, but assuming there's no telltale scoring there, I'm starting to think that there's either something wrong with the chain (wrong chain sizing or defective links?) or something wrong with the setup of the bike so that the chain can lever against the cogs in the middle cluster. All three failures could be explained by the chain (or possibly the rear shifter acting on the chain) prying the middle cog of the spider until the spider gives way. The spider isn't engineered to be strong in that direction and shouldn't need to be, but if a chain of the wrong width was used or if the rear derailleur was adjusted (or chain length was wrong) so that it jammed the chain and snapped it sideways, it could explain not only one failure but also why the bike kept destroying cassettes.
Any time you have one cassette failure, it's a very rare event. When one bike causes multiple successive failures and does so almost immediately, you have to look at the bike and how it's set up. Looking in detail at the damage to the cassette, everything is consistent with a prying action from side to side, not with a rotating load (for which it's engineered). Once the damage begins, when the chain tries to run over the cog in question or an adjacent cog, it jams and tears everything apart. The torque vector applied by the speed of the bike is far greater than what any rider can accomplish, and greater than what the cassette is engineered for, so it can tear the cassette apart once the cassette has been damaged. And the source of that original damage? My guess -- and this is only a reasoned guess at this point -- is that something about the bike caused a sideways deflection to damage the spider or cogs on it. That would explain the recurring failures and why the cassette is otherwise basically reliable for almost everyone else on this forum and elsewhere.
The creaking is somewhat of a bogus issue. We all know that carbon against metal likes to creak. That it happens here is probably irrelevant. If it's relevant, it's only because creaking might be accentuated if damage had already begun. But these cassettes do creak and do need retightening and lubrication. I wouldn't make creaking a direct correlation with failure.
A while back we collected almost four hundred hubs that had undergone flange failure due to radial spoking, so we could understand whether radial spoking was really an issue or not. We did similar studies on tubulars that had rolled off rims -- almost two hundred tubulars. That kind of failure analysis is what really tells you what happens on the bike. Send these cassettes to a common repository and let's start looking at them. I think we'll find a common thread that isn't a pure design failure. Until then, I'd keep riding my 9000 cassettes and not worry about them. I'd change chain, chain length, and rear derailleur setup (especially b-screw) and see if we could get rid of the problem. It's a new bike, remember. So I'd start there.
Just my $0.02. But I'm trying to stick to the facts and to looking carefully at the photos that were provided. Probably just time to move on.
goodboyr
by goodboyr
That's certainly more than 2 cents worth! Finally some logical fact based analysis. Thank you!!!!!
11.4
by 11.4
To emphasize one point made above, this is a brand new bike and it's destroying cassettes. If the bike had a history of not damaging 9000 cassettes and then three broke, or if it took a long time to break cassettes, I'd look at it a little differently. But I rather suspect that there is something about the bike that causes cassette failures. Again, it's a brand new bike and it's doing it repeatedly right out of the box. I'd suggest that someone who really knows what they're doing take the bike apart and put it together again, checking all adjustments, trying with a different chain, and adjusting gearing, b-screw, chain length, chain choice, and derailleur alignment to be sure that the bike isn't taking out its problems on the cassette. That it's a brand new bike doing this is highly significant.
bikerjulio
by bikerjulio
11.4 thanks for the discussion.
You seem to be saying that some unusual force applied is what caused this. Like sudden chain skipping under load for instance. And agreed, it looks like it. Yet OP excludes this.
The only area you didn't really address was my last one - a manufacturing problem. Did a few perhaps escape into the wild and OP was the unlucky recipient?
Oh, and nobody's perfect, even Shimano http://www.cpsc.gov/en/Recalls/2013/Shimano-American-Recalls-Disc-Brake-Calipers/
There's sometimes a buggy.
One.
11.4
by 11.4
bikerjulio wrote:11.4 thanks for the discussion.
I don't think the OP could rule out this problem. Possibly if he'd been riding the bike for a while, but everything was brand new. And how could he definitely rule out the small variety of issues that could cause this?
As for a manufacturing problem, these cassettes didn't even fail for the same reason -- different failure modes just among the three. If they had all died exactly the same way, then yes, perhaps a manufacturing problem. But to have at least two and possibly three different failure modes? The odds are astronomical.
by 4914
Put the SRAM cassette on yesterday, did absolutely nothing else bar gear adjustment
Ride is smooth as can be now, and no problems.... hope this one can cope with that vicious side to side prying action that cause the DA to fail
if the rivets had any issue whatsoever that resulted in the slightest reduction in their ability to fasten the cog to the carbon body then the carbon body would be dealing with different forces than what it was designed to deal with and presto... failure
Anybody called up Henry Bosch to hear about the rivets from the horses mouth as they say?
