It is currently Wed Jan 17, 2018 7:33 pm
Post new topic  Reply to topic  [ 609 posts ]  Go to page Previous 118 19 20 21 2241 Next
PostPosted: Fri Aug 15, 2014 9:39 pm
Even if we knew what an acceptable rate of failure was, there's no way to determine what the current rate of failure is. The sample size on this forum is small and people tend to only post online when they have an issue. Trying to extrapolate failure rate based on a forum thread where the subject line is "rubish product design" is not a good way to go about it.
PostPosted: Sat Aug 16, 2014 12:28 am
uraqt wrote:
Ok, I'll keep trying....
What is the acceptable rate of failure for a cassette?
C
ZERO. Go one piece.
Get a solid steel one for 180USD from RECON @ 210g.
Or SRAM or other...
Why keep playing around?
Wear is another matter. Failure should not be an option.
PostPosted: Sat Aug 16, 2014 12:44 am
I agree in this case ZERO!!!
C
PostPosted: Sat Aug 16, 2014 5:06 am
Well then I guess you should switch to single speed. I've pretty much seen a failure in every brand of cassette out there. There was just a thread on a sram red cassette failing a couple weeks ago so guess you can't buy those. Recons are known for teeth breaking off. Had a rivet fail on a customers 6700 cassette. Guess those are out of the question too.
PostPosted: Sat Aug 16, 2014 10:59 am
Zero failure/defect rate is pie in the sky, lots of companies talk about it. None achieve it.
Quite a few claim to. Which is another matter altogether.
TBH, if everyone on here (US based) filled in a Consumer safety report (you've all done that, right? Why not?) if you aren't US based, fill in your local equivalent. Then we'll actually get a response. With proper engineers and actual statisticians actually having looked at the actual data. Rather than armchair experts declaring a dozen popped cassettes being a major manufacturing/design disaster. For a volume of maybe a million units a year.
PostPosted: Sat Aug 16, 2014 11:01 am
Oh, single speed sprockets fail too. Seen a few pictures floating round the net.
And seen a mate peeling one off his hub while JRA.
PostPosted: Sat Aug 16, 2014 5:04 pm
Have you seen a steel one piece fail?
PostPosted: Sat Aug 16, 2014 5:49 pm
If you consider a sram OG1090 a steel one piece, then yes.
PostPosted: Sat Aug 16, 2014 5:51 pm
I guess I should have phrased that "the majority of mass production cassettes" instead of "pretty much every brand of cassette out there".
PostPosted: Sat Aug 16, 2014 11:51 pm
I don't.
Cogs are getting thinner (with 11 vs 10 vs 9 vs...). Ti seems like a good material. I think steel is hard to beat for those teeth. That being said, we use alloy for racing - and do have issues. The Miche alloy is the same weight as the steels solid. The RECON alloy, is well, alloy.
http://1drv.ms/1p0cKoa
http://1drv.ms/1p0cUff
PostPosted: Sun Aug 17, 2014 7:01 am
I wonder how many of the naysayers still use chain drive.
chains snap with amazing regularity compared to cassettes popping
PostPosted: Tue Aug 19, 2014 7:47 am
That maybe true, but I would put that down more normally to poor maintenance with bad joining, or a worn one that's done way too many miles.
I make a point of changing mine regularly and have never had one of my own break in 28 years of cycling (despite breaking many other things). I've broken a friends once when riding, but then subsequently discovered he'd never replaced it for years. Many of my friends that had them break had also been remiss in changing them.
Regardless, anyone that's ever had something break in the drive train (pedal, chain, cassette etc) when going max chat at 1000+ watts out of the saddle will know how devastating this can be, and normally equates to a crash.
I still maintain that Shimano is taking a big gamble here and sooner or later one of these will throw somebody off into a car or something.
PostPosted: Thu Aug 21, 2014 7:20 am
Well my fears came true.
I wrecked a new DT swiss freehub due to the stupid design.
Contacting wiggle now to see if they will replace it and the hub
PostPosted: Thu Aug 21, 2014 10:30 pm
My 3rd broke the other day.
Only XG 1190 from now on.
2015 FELT AR1 TeXreme! http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=134989
 Post subject: It is design after all
PostPosted: Tue Sep 02, 2014 4:55 am
Ok so update. Where should I start?
Shifter replaced. Mounted on a trainer- same issue. To their credit Shimano pursued with a green light to change EVERYTHING- shifter, derailleur, polymer cable, etc etc. The shop did not need to call me in- they could detect the issue.
Shop used another maintenance due bike, one of those owners that never complained of his 11 speed set-up, mounted a 12-25 11 speed on their bike and- SAME PROBLEM. Essentially, no matter the bike tried etc- same problem
Problem was found through trial and close observation: Cassette design around the cluster, AND chain tolerance. Shifter can never get the chain to engage fully the carbon cluster, resulting in a grind when upshifting, and lag when downshifting. Also, DA chain has NO room in the center of the cassette, depending how it (sits left ) or ( sits right) on the tooth, left or right side ALWAYS hits and nearly grabs the adjacent tooth- BUT ONLY IN THE CARBON CLUSTER SECTIONS. When watching the trainer, became clear that the angle (17-18-19) or 18-19 between the chain cogs and the 53 chainstay automatically has the DA chain ALWAYS rubbing- effects varying from slow to strong effort. One cannot see light between the DA chain and the cogs.
Campy chain: you can see light AND it self-trims on the trouble cogs-18 and 19 (my only carbon cluster presently).
When told, Shimano shipped a fancy calculator tool to verify critical angles, hanger bolt, alignment etc. My bike passed with excellence. By now was on my 3d-4th week without my best bike. Anyhow, Shimano sent an additional part that I cannot divulge- as it does not yet exist.
However, my shop decided to experiment separately. A campy SR chain was installed. It is 0.2 mm thinner than the Shimano, and a different, more resilient construction. Difficult to describe the transition my bike experienced, kinda like going from an Infinty Q50 to a McLaren P1. 95% of all grinding and catching disappeared. Cannot feel, hear or sense the chain. Or the cassette (minus the carbon cluster) No lateral, longitudinal or horizontal vibrations. Gained 2km/hr in the 34-38 range, and 1km/hr in the 40-50 km/hr+ range. The only issue that I still experienced was partial engagement grind, followed by the Campy chain self trimming. Something like this:
tac tac tac grrind grind tac tac. (15-16-17- grrr18,-grr19, 21,23,25)
downshifting would get tac - tac - taaaac=taaaac-taac- tac-tac, (25-23-21-19---18---17-16-15-14) a few millisecond delays on 19 and 18th and 18th to 17.
Chain dropped once under load, likely 1000W short effort, 53/19t, chain engaged 18t and ping!!! Dropped back on 19t and self centered. After that was more cautious. With the DA the chain could never center as there was no room for it physically, and would drop frequently. With campy I got one drop in 100 kms.
Between the DA chain and the Campy, 95% of the issue had been solved. Additional steps with Shimano involve trying their new parts. The also want a footage and my bike- but I want to ride until Nov.
What causes it? I have three theories:
- Engagement Flex- as the chain mounts the carbon based cogs, these lean 0.1-0.3 mm inwards and begin a slow and uncertain recentering.It is POSSIBLE (though not necessarily a fact) as I can BEND by as much the carbon cluster squeezing them with my fingers. A few times, I just let the chain grind and see? 5-10 m of rolling the grinding stopped as the Campy chain mysteriously quieted. That, my friends, had NOTHING to do with cable shifting.
- Tolerance: Spacing is NARROWER on all carbon cluster cogs- visually seems so but do not have a tool to check with precision, but DIFFERENT than spacing on below or above cogs, and DIFFERENT than the 11 SRAM spacing which appears equidistant
- A combination of the two above.
Will pursue the Shimano venues- my bike been requested by them- but only in Nov. What seems certain is that:
Campy chain removes 100% of the pedalling grind, and 95% of the engagement grinds (the 5% being those two or three carbon cluster cogs). Cycling in the Campy configuration was safe, solid and one could not feel or hear the chain or any movement whatsoever, at 35, 40 or 50 km/hr. However, not to imply a carbon cluster cannot break, the issue above is that there is still something weird happening when the chain engages it.
Only sounds are in the 53/18-19 movement, after which the chain settles-1-2 seconds.
NONE of this was possible with the DA chain, which rattled terribly 17-21 and semi noisy the rest of the gears. More lube would silence it in the 12-17 range. However, the Campy chain DOES NOT EXIST on the 12-13-14-15-16-17- - -21-23-25 configurations. No chain sound, no lag, no energy loss, no noise, and I feel I can brutalize it and it just begs for more effort. The DA crank is powerful, the Campy chain a workhorse, and the only variable still in doubt is the cassette.
My next step? A new cassette, DA 11-23 experiment (to determine if a general issue with 12-25 DA or 12-25 Ultegra cassette). SRAM if that experiment fails.
What was tried: 4 cassette, x3 cables, x2 complete new 9001 shifters and x2 derailleurs, x3 wheelsets, x2 road bikes, no solution to a working 11 speed DA or Ultegra set up in a 12-25 / 39-53 mount.
Mobile Pro Bus tech had also confirmed to me not having seen it work in a 12-25 carbon cluster 11 speed configuration.
Furthermore, from asking around, some people have it but just ride with grind (though not too fast), creaks and partial shifts and push too little to experience drops.
Comments from Pros: they cannot comment due to non-disclosure agreements (this is literally in the press). But TDF close pics reveal that no matter the group manufacturer, the pros mix parts in their set up.
There are no new unread posts for this topic. Token 11sp cassette, xg-1190, dura 9000, zipp 404 combo
432r
12
1408
Mon Jan 30, 2017 8:45 am
Marin View the latest post
There are no new unread posts for this topic. Dura ace 9000 rear derailleur?
sinjun
Mon Apr 10, 2017 6:02 am
richscott View the latest post
There are no new unread posts for this topic. Dura ace 9000 V 9100 brakes
scottmmw
Mon Oct 23, 2017 7:51 pm
evan326 View the latest post
There are no new unread posts for this topic. Campag 10 speed cassette with 11 speed chain?
campagowlo
Sat Dec 30, 2017 10:41 am
bikerjulio View the latest post
There are no new unread posts for this topic. 28C tyres on Dura Ace 9000 Brake Calipers
chutneyyy
Thu Jun 29, 2017 7:58 am
Delorre View the latest post
Users browsing this forum: bikeguy0, bremerradkurier, Google [Bot], Google Adsense [Bot], jch3n and 42 guests
