It is currently Tue Jan 16, 2018 8:47 am
Post new topic  Reply to topic  [ 609 posts ]  Go to page Previous 114 15 16 17 1841 Next
PostPosted: Tue Jun 17, 2014 7:03 pm
Shop Wrench
Zig - the revision is on the inner carbon piece. The lowest cogs are still unchanged.
 Post subject: Go One piece
PostPosted: Tue Jun 17, 2014 11:38 pm
Years ago I bought a Token 9 speed milled from a single billet. Still in use.
SRAM, as mentioned is one piece too. RECON has them in alloy and some in steel. They are light - 120-140 and cost 2X what a nice chain or tyre does. One pieces don't leave dig marks on the alloy freewheel body (WW all have those right?).
PostPosted: Sun Jul 06, 2014 5:58 pm
My saga:
Critical failures in the 9000 design.
Pro set up Columbus Genius, DA 9000 11 speed, 39/53, 12-25, internal routing, Zipp 303 tubulars. Worked like a charm for 900 kms. Then the rear cassette issues began, uncertain if a cog or the chain or why would it struggle on one disk (18t) specifically? Clank noise resonating in the frame (BB?) No we checked without the chain. Up or down gears no matter. My Gianella specialist (Montreal) changed the DA cassette twice, set it up several times, the issue came back.
Part of the shifting issues: the 'Polymer' coating had began unraveling inside, at contact points, and coiling around the rest of the cable, changing aspect and thickness of the cable. With a new uncoated stainless steel, lubricated cable, shifting issue resolved.
In the end, the 'polymer' coating is a gimmick that is condemning the rider without knowing. In contrast, the 'BOA" steel lacing system, on shoes worn 7000-10000 kms, it is also coated in a tiny plastic and NEVER unraveled itself. At similar look or feel, this critical Shimano component will fail the rider when it comes to one thing: gear shifting. The steel cable is intact, it is the polymer failure specifically that fails the steel contained within. Seeing the sections next to the lever where it unraveled and coiled (COILED) on itself, one could not even see the metal pattern underneath, and the gear issues became clear. Drag was local, and shifter position / gear issues were associated only with the location of the polymer blockages.
In addition to the cable, the 11 cassette spacing may be too narrow for a standard crankset (angle of chain and CN-9000 thickness). Once the chain is on 53/18t, the angle and tolerance changes, favouring unnecessary rubbing and grinding (Shimano admitted this a few weeks ago, see the bikerumour article on the new upcoming DA 9000 cassette). Particular care is required to keep the chain soaked to the point of it gliding across the engagement teeth on the nearby 17t. That aside, none of it changes the chain whips I get occasionally under load, 18t and higher.
More, the technician must adjust the derailleur angle relative to the plane of the cassettes, adjusting or bending the hanger on the frame, neutrally, positive or negatively. Turns out the DA requires a slight positive (Shimano recommends neutral); however, the chain is slightly twisted on the cogs. The higher the chain tension (53 17t/18t) the more likely it will skip or grind. On the 18t the chain 'rests' on the left side of the 17t and moves up and down along its engagement teeth, even though on the 18t, and this oscillation is accentuated by the spider oscillation. 21/23 are not a factor as, by then, the size of the cog is sufficient to keep the chain clear from the nearby smaller cog and often one drops load and tension going down on the smaller chainring (36 or 39).
But these default issues (Polymer cable flaw, Chain perhaps to thick for cassette or cassette space tolerance too low, etc), forced this rider for weeks back at the shop. One culprit- the cable- was gradually annoying. Sufficiently working to mask the symptoms, but failing in actual usage. Failure means poor to no riding, and hence the one star.
Gear shifting resolved, the cassette issue is critical- as a riding and safety issue. 18t, 19t 21t sound as if they are worn out about to die (2nd cassette in a week) Yesterday, 06 Jul, brand new cassette, the chain nearly jumped out twice under load, 18t or 19t. Grinding/moving, the carbon spider section flexes, is too close to 17t, and the chain is literally shaken and vibrating until a critical oscillation may throw it off that cog. The metallic bang that ensues is quite concerning. SRAM 11 is my next bet until the new cassette is released- the bikerumour article.
Rider: 173 cms 73 kgs, 350-400 kms / week, rest speed 30-32 km/hr, cruise 35-36, faster pace (10 k sustained) 40-43km/hr.
Current usage: 1800 kms/2 months.
Previous systems used: 105, Ultegra. Issues- nil
PostPosted: Mon Jul 07, 2014 2:52 am
Shop Wrench
Wow, long post. I have set up plenty of 11spd shimano bikes and am yet to see this issue with the 17 and 18t or any sort of chain jumping. I have da9000 on my personal bike and have only had the cassette carrier problem that we all know about.
Does your bike have 400mm chain stays? I have only seen the problem you are describing on bikes with the shortest possible stays. The other cause would be a chain connecting pin pushed in the wrong way or some sort of aftermarket quick link that is too wide.
I don't know what you read on bikerumor, but I have no reason to think in a million years that shimano is going to change the dimensions of their chains or cassettes.
PostPosted: Mon Jul 07, 2014 8:25 am
I have two 12-28 cassettes, no issues at all. I also have the older design. I must be lucky, i have had them on Fulcrum Red Wind and Mavic CCU 2014.
Been running a Shima DA chain and now a KMC chain. Works great with both.
Bikes:
Ax Lightness Vial EVO D
Paduano Racing Fidia
Open *UP*
PostPosted: Mon Jul 07, 2014 1:55 pm
People can say what they want about SRAM in general, I run Di2 9070 personally, but SRAM 1190XG cassette...that cassette is a genius one piece design, light, stealth rings...quietest cassette..you can barely hear me pedaling next to you at times.
Not sure what Shimano is doing..but hey, many pros are running the 6700 Ultegra cassettes due to a need for weight increase anyway.
PostPosted: Sat Jul 19, 2014 6:02 pm
This is pretty unfortunate from the standpoint of SRAM not offering the 12-28 or 12-25 configurations. Does anyone notice/care about that difference? I wanted to go the D/A route because it doesn't have those 3t jumps in the higher cog, which I find annoying.. I'd rather have the closer spacing in the higher cogs and lose the 11t. Anyone else w/ opinions on this?
PostPosted: Sat Jul 19, 2014 7:24 pm
Would love the 12-28 in DA, might go Ultegra simply to have that option. The closer spacing in the top half would be helpful.
PostPosted: Sun Jul 20, 2014 3:16 am
sram offer an 1050 model 12-28.
One thing I dislike about Sram's 1x-28 is the 3t jump from 19-22. Shimano's 11-28 do a more usable 19-21 there and make a 4t jump from 24t to 28t, which is fine if the 28t is a bailout gear for super steep sections.
PostPosted: Sun Jul 20, 2014 4:07 am
after 1500 miles my 11sp dura ace popped. it kept skipping and skipping, when i stop and look down, 2 of the gears where close to each other. ill take it to the bike shop and have pics up tomorrow. SUCKS!!! arghhhhh.
PostPosted: Sun Jul 20, 2014 7:14 pm
There actually is no 12-28 in ultegra... that range is unique to D/A. Ultegra has an 11-28, which seems interesting as it's got a pretty tight range, then its a 3t jump from 25-28, which i think is great as a bailout gear. Curious about weight though - I can't find an 'actual' weight that I feel i can trust on the ultegra. Competitive cyclist has actuals listed at 212g for all the different sizes, which can't be true. A different site has 255g listed for the 11-28 which seems more spot on. THat being said, a 100g penalty over the SRAM seems like alot.
THinking i might just go for the 11-26t option in SRAM.. and force myself to suffer and/or get stronger.
PostPosted: Mon Jul 21, 2014 1:45 am
here it is. the replacement i got is the same, not the revised version. lets see how long this one last.
File comment: broken DA 9000.
PostPosted: Mon Jul 21, 2014 2:06 am
I just bought one off Wiggle :s 11-28.
After reading this I'm thinking of returning it and going with trusty SRAM :/
PostPosted: Mon Jul 21, 2014 5:37 am
You are correct, I must have been wishing for the Ultegra version,
PostPosted: Mon Jul 21, 2014 6:41 am
Just looking at cassettes on wiggle... Crikey when did SRAM get so pricey?!
There are no new unread posts for this topic. Token 11sp cassette, xg-1190, dura 9000, zipp 404 combo
432r
12
1404
Mon Jan 30, 2017 8:45 am
Marin View the latest post
There are no new unread posts for this topic. Dura ace 9000 rear derailleur?
sinjun
Mon Apr 10, 2017 6:02 am
richscott View the latest post
There are no new unread posts for this topic. Dura ace 9000 V 9100 brakes
scottmmw
Mon Oct 23, 2017 7:51 pm
evan326 View the latest post
There are no new unread posts for this topic. Campag 10 speed cassette with 11 speed chain?
campagowlo
Sat Dec 30, 2017 10:41 am
bikerjulio View the latest post
There are no new unread posts for this topic. 28C tyres on Dura Ace 9000 Brake Calipers
chutneyyy
Thu Jun 29, 2017 7:58 am
Delorre View the latest post
Users browsing this forum: Aya, MirkoR, pdlpsher1, silverster, Yahoo [Bot] and 39 guests
cron
