It is currently Sat Jan 21, 2017 9:00 pm
Post new topic  Reply to topic  [ 561 posts ]  Go to page Previous 1 2 3 4 538 Next
PostPosted: Sun Sep 15, 2013 11:47 am
And of course its the internet so internet statistics holds........one failure reported out weighs thousands of "no problems".
My RCA
PostPosted: Sun Sep 15, 2013 6:19 pm
further to the exploding cassette saga, I have spoken with a senior guy at Shimano Europe and told them about my experience... though he played it down a bit he admitted that they were aware of the problem and had some of them come back in but were not inundated.
I didn't call Shimano to complain for my benefit...but because quite simply its down right dangerous and if they were not aware of the problem they need to be because its only a matter of time until someone has a bad accident.
I've already agreed with the LBS where I bought my bike to replace it with a SRAM 11 spd and I'm confident that will be ok.
Cant remember who asked but I have ksyrium sls 2013, and although I haven't seen one in person I've been told that the ultegra 11spd cassette also has a carbon mid body.
Pleased to hear that re-torqueing has solved the noise for some people..... however, after installing three cassettes correctly using grease on the cogs and the threads and then re-torqueing to the specified tension and STILL having the carbon body shatter like candy. there is no way I could ever trust this product. looking forward to fitting the SRAM when it comes in tomorrow.
PostPosted: Sun Sep 15, 2013 6:50 pm
i suppose by re-torquing the cassette means that there's some slight compression on the carbon spider. being that the become loose, assuming that loose cogs will tear the spider up...thus causing failure. i have checked my cassette a few times...not because of noise, but to repack grease in my DT240 hubs.
- AX Lightness Vial EVO D + DA9070 + Enve SES 2.2 tubeless with carbon hubs
- Parlee Altum + DA9070 + Enve SES 3.4 carbon hubs
- Parlee ESX + DA9070 + Enve SES 6.7 CK hubs
- Independent Fabrication Ti FLW + Campy SR11 + Enve 3.4 CK hubs
PostPosted: Sun Sep 15, 2013 8:04 pm
One failure? I counted more than a dozen under this thread alone: http://www.bicycles.net.au/forums/viewt ... 34&t=62450 Using your math I assume there are perhaps 50,000 DA cassette in use with no problems?
PostPosted: Sun Sep 15, 2013 8:28 pm
It looks pretty fragile to me on it's ability to handle the torque generated by a fit cyclist. I also question whether is material could really be deemed 'carbon fiber'. It looks like reinforced Nylon used to make such things as automotive engine intake manifold.
PostPosted: Sun Sep 15, 2013 9:51 pm
Fitness doesn't break bike parts, weight of the rider is a bigger culprit. A 250 lb cyclist can create higher tenth of a second force than any elite 160 lb athlete. Holding 400 watts for an hour won't break anything. But send a big guy over a small bump with the crank at 9 o'clock while out of the saddle and boom.
And yeah, that cassette design is a bit of a joke - very surprised to see Shimano let that one out of the door.
wheelsONfire wrote:
When we ride disc brakes the whole deal of braking is just like a leaving a fart. It happens and then it's over. Nothing planned and nothing to get nervous for.
PostPosted: Sun Sep 15, 2013 10:19 pm
I have over 2000 miles on my Two bikes fitted with DA 9000. I have never had an issue with any of my cassettes. I asked my local bike and they have never heard of any issues either?? I can't imagine Shimano would not have done extensive testing on these cassettes and material. By the way, I am no WW. I weight 175 lbs!
PostPosted: Sun Sep 15, 2013 11:37 pm
pdlpsher1 wrote:
One failure? I counted more than a dozen under this thread alone: http://www.bicycles.net.au/forums/viewt ... 34&t=62450" onclick="window.open(this.href);return false; Using your math I assume there are perhaps 50,000 DA cassette in use with no problems?
You should hide under your couch and sell your bike. Lots of problems get reported here........because that what you do when you have problems. And you get good info and advice......BUT for every problem reported, there are many, many without problems and they usually don't post "no problems". If you went with the same logic:
- most zipps are crap
- most cervelos crack
- most ultegra chains break
- etc.
My RCA
PostPosted: Mon Sep 16, 2013 1:28 am
Had a guy riding next to me and his carbon carrier broke as we came up to a set of traffic lights! Luckily he didn't fall off really. It was only one of the sprockets affected. FWIW bike had done 2,600kms without issue prior...
PostPosted: Mon Sep 16, 2013 1:49 am
One failure? I counted more than a dozen under this thread alone: http://www.bicycles.net.au/forums/viewt ... 34&t=62450" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false; Using your math I assume there are perhaps 50,000 DA cassette in use with no problems?[/quote]
- etc.[/quote]
You got those 3 things right. :lol:
PostPosted: Mon Sep 16, 2013 3:34 am
Ok, then, Timzcat, how about this? Insert your ride into the google search and add the words "failure", "problems", "cracking", and see what comes up. Then you may conclude what you are riding is an accident waiting to happen.
My apologies for taking this thread way OT. Carry on.
PostPosted: Mon Sep 16, 2013 4:47 pm
Good luck it's a Cannondale Evo Ultimate. :roll:
I had a Cervelo and cable stops that fall off I found undesirable. You can't argue, they've had their fair share of issues.
PostPosted: Mon Sep 16, 2013 6:09 pm
Mine is creaking now. It is about 2 months old- I weigh 64-65 kg.
I tried switching qr skewers to see if that was the issue. Still creaks, lockring is tight.
PostPosted: Mon Sep 16, 2013 6:31 pm
Just like Cannondale...
OT: I'll probably replace my cassette with a Force 22 if it breaks or wears out whichever comes first.
My Cervelo R5
My Lynskey Helix
My MTB
PostPosted: Mon Sep 16, 2013 6:39 pm
rmerka wrote:
Just like "Crack and fail"...
Fixed that for you....... :twisted:
There are no new unread posts for this topic. Dura Ace 9000 cassette; top two cogs creaking...
TheDarkInstall
10
892
Mon Jun 27, 2016 2:35 pm
uraqt View the latest post
There are no new unread posts for this topic. Dura Ace 9000 levers and cassette question
alkoro
7
884
Fri May 13, 2016 8:03 pm
fromtrektocolnago View the latest post
There are no new unread posts for this topic. Shimano CS-9000 cassette vs. CS-9100?
eaglejackson
44
3611
Thu Nov 17, 2016 9:38 pm
vanmatthew View the latest post
There are no new unread posts for this topic. Is 11 speed Dura Ace chain compatible with Dura Ace 7900 gruppo?
wootenlakeguy
Thu Oct 13, 2016 7:07 pm
pdlpsher1 View the latest post
There are no new unread posts for this topic. Dura Ace 9000 Brake Blocks?
Titanium22
Wed Apr 20, 2016 9:33 pm
wingguy View the latest post
Users browsing this forum: jgrano, Miller, punk, roeman, spdntrxi, wheelsONfire, zazo and 25 guests
