It is currently Fri Dec 15, 2017 3:53 am
Post new topic  Reply to topic  [ 609 posts ]  Go to page Previous 17 8 9 10 1141 Next
PostPosted: Mon Sep 23, 2013 3:25 am
Not real sure which gear I was in when it broke, it's an 11-25 cassette, I'm guessing in my 17 or 19?
The bike was perfectly dialed. I've spent nearly a decade as a mechanic in some very high-end shops. I've recently had this bike dialed by mechanics wrenching for national-level elite teams.
The problem isn't a mal-adjusted drivetrain, I can promise you that.
The first of my cassettes that exploded was one of the first available in the US. Did that have something to do with it? I don't know, maybe. But when I spoke to Shimano about that one the tech rep didn't seem to be too terribly surprised.
Since posting the photo to friends I've had a few others pipe up about this happening to them. At the end of the day now though, we're at what, 10-15 cassettes that have this problem? Can you imagine how many 9000 cassettes are out there?
This still seems to be a relatively rare problem, but it's certainly not isolated.
PostPosted: Mon Sep 23, 2013 3:50 am
You are not counting the broken ones occurring on pro teams. When they break something they are unlikely to report it here.
PostPosted: Mon Sep 23, 2013 10:09 am
Please. We also aren't counting the broken ones belonging to illiterate cyclists who can't write complaints. And ones that broke in Tibet and whose owners' letters haven't traveled by yak to a national post office yet. If a pro team, which will be sponsored, has any significant number of cassette failures, we'll certainly hear about it and you can bet that Shimano will.
Remember the SRAM Red front shifter problems? More of a pro problem than an amateur one, yet we heard plenty about it. Simple fact is, there's a very small number of failures and so far what we've heard they've been clustered with a much smaller group of users. Let's see all the Shimano-sponsored pro bikes being built with Ultegra cassettes instead of Dura Ace, like SRAM Red bikes were built with lower-level SRAM front shifters, and then your statement at least makes sense.
Nothing says that this isn't a serious equipment failure when it happens, or that Shimano isn't going to be looking at it. It just means that figuring the cause will be difficult and any statistical failure expert will say that there was something about the bikes or the wrenches on those bikes that was probably at fault -- it's the only statistically valid explanation for why you get repeat failures for a very few individual riders. There isn't enough information to say exactly why the cassettes DID fail, but there IS enough information to say that statistically the cassettes are meeting realistic reliability expectations.
PostPosted: Mon Sep 23, 2013 12:57 pm
Hi Eric, I cant be sure what gear I was on at the time (I'm sure there are a few pro's out there who've used that phrase before :wink: )...
but I wasn't changing gears, I was in the gear at the time it broke.
You have an excellent point in that a cassette should be able to deal with other minor forces and not break apart.
Simple fact is however, I've broken three DA cassettes.
I've got SRAM cassette on now and it works perfectly, gears change precisely... absolutely nothing wrong and all I did was put it on(myself) and adjust the gears. That's it.
As I said before there are no issues now with the bike now and there wasn't before hand, bought a SRAM cassette and problem solved... but if you simply can not accept that this product is a bad design after you break one... Try you luck with the following tips from 11.4
"I'd honestly suggest that you have the bike hangar and drive train alignment checked by someone who really knows what they're doing (preferably a good frame builder). Go to a different chain and intentionally change the number of links. Change the b-screw setting. And so on. Be sure the free hub isn't sticking at all, nor the rear derailleur jockey wheels -- fastest way to get this kind of failure is if a couple links fold up and jam on the cassette right above the upper jockey wheel -- you'll have a failure essentially without warning even if the cause has been there all along or since a change induced the scenario. My point is that there's a way to tear a cassette spider apart, and it can come about from a combination of issues that is almost impossible to diagnose or predict. The cassette is generally reliable and riders shouldn't be hesitant about using them, but if you do start to have problems with one, I'd look at the whole drivetrain and its geometry to see what is causing this"
PostPosted: Mon Sep 23, 2013 3:26 pm
Not a Shimano guy so I wouldn't have noticed in any pix, but is it possible that the Pro teams are/have been using Ultegra cassettes?
C
PostPosted: Mon Sep 23, 2013 4:05 pm
@11.4 "any statistical failure expert will say that there was something about the bikes or the wrenches on those bikes that was probably at fault"
The problem with that analysis is that the first cassette broke while on my steel bike with King R45 wheels and the second one broke on my carbon bike with ENVE wheels. The first bike I built myself, top to bottom, the second bike was built by an elite-level mechanic who makes a living being contracted by professional teams (continental and Pro Tour) as a mechanic, top to bottom.
The steel bike is 9070 Di2, the carbon bike is 9000 mechanical.
Both were using Dura-Ace chains.
Before these two cassettes, I've never had a cassette fail in anyway (other than my expectations of reasonable noise control, which the first-gen Red cassette failed miserably).
PostPosted: Mon Sep 23, 2013 4:28 pm
C
Since the Ultegra cassette also uses a carbon spider their only choices would be either Campy or Sram. And this would likely violate their sponsorship agreement with Shimano.
PostPosted: Mon Sep 23, 2013 4:31 pm
11.4 would say since YOU broke two in a row it must be user error :mrgreen:
PostPosted: Mon Sep 23, 2013 6:33 pm
I agree, it IS "user error". This user shouldn't have put a second one on in the first place.
PostPosted: Tue Oct 01, 2013 5:40 am
CS-9001... Coming to a bike shop near you...
PostPosted: Wed Oct 23, 2013 4:06 pm
9001 IS coming. Shifters at least. Will be here shortly.
PostPosted: Wed Oct 23, 2013 5:14 pm
When will people learn, never, never, EVER, buy first generation of anything. Ever. It's bound to be flawed. :)
Oh, the list of self-imploding first generation bike products is so long, bike manufacturers just fix them quick enough that we don't remember them later on. But think back over the last 10, 15, 20 years... That list of parts and standards is a mile long.
Remember early HollowTechII? Yeah, changing bearings every third month is the new black. Haha.
The Shivenge
PostPosted: Tue Nov 05, 2013 4:28 pm
I have exactly the same issue. Brand new 9000 Di2 drivetrain and the cassette in the top three gears where the carbon body attaches all creak under torque.
PostPosted: Wed Nov 06, 2013 8:55 am
Not happy at all about the 9001 revision of the shifters with no announcement or list of issues fixed by Shimano. Imagine any modern software company doing the same thing!
PostPosted: Wed Nov 06, 2013 8:57 pm
Actually we do it all the time.
But you are right to complain about Shimano doing it.
There are no new unread posts for this topic. Token 11sp cassette, xg-1190, dura 9000, zipp 404 combo
432r
12
1309
Mon Jan 30, 2017 8:45 am
Marin View the latest post
There are no new unread posts for this topic. Dura ace 9000 V 9100 brakes
scottmmw
Mon Oct 23, 2017 7:51 pm
evan326 View the latest post
There are no new unread posts for this topic. Dura ace 9000 rear derailleur?
sinjun
Mon Apr 10, 2017 6:02 am
richscott View the latest post
There are no new unread posts for this topic. Campag 10 speed cassette with 11 speed chain?
campagowlo
Sun Apr 16, 2017 1:10 am
BRM View the latest post
There are no new unread posts for this topic. Dura Ace 9100/9150 noisier than 9000!
James0133
11
3298
Sun Aug 20, 2017 5:44 am
James0133 View the latest post
Users browsing this forum: evan326, Google Adsense [Bot], mnmasotto, TobinHatesYou, toshi, Yahoo [Bot] and 19 guests
