Dura Ace 9000 11 speed cassette- rubish product design
pdlpsher1 wrote:I'm seeing the DA cassette going on sale for $148. I have a feeling that Shimano is clearing the old stock and getting ready to launch a revised cassette. Anyone has info. on the new cassette?
It does not matter. won the TT portion of the Ottawa Fondo last year using the Hyperglide+Campy chain+ Gore cables. PERRREFECT setup
On my second bike, SRAM HYPER + SRAM chain + Yokozuna cables. Near perfect- the SRAM pings ocasionally, false catching. very rarely though, 1/50 miles or so if slowing down and reaccelerating.
Shimano cassette, PTFE and chain are GARBAGE. cannot believe we wasted a summer replacing parts under 3 yr warranty...
Belisarius wrote:.
Kind of hard to disagree with DA cables being bad. The PTPE/polymer coating of the DA cables start unwinding/shredding and clogging. If nothing else, they look horrible...
- ultimobici
- in the industry
- Contact:
I'm curious to know how many of these cassette failures are on cassettes that are used on Shimano wheels or hubs rather than third party manufacturers.
ultimobici wrote:I'm curious to know how many of these cassette failures are on cassettes that are used on Shimano wheels or hubs rather than third party manufacturers.
Does it matter? Dropped in on several bike shops these two years, and casually asked about these issues. The number one answer I get is that "the Shimano cassette kept having problems and clients were coming back, and we kept replacing them through Shimano." Once I mentioned the core issues, the Eurika! dumbfounded look I see tells it all. Veteran mechanics jumping on a computer to confirm that the carbon-based Shimano cassette is a design failure is a unique experience. Or the shop owner having trouble getting his wife's cassette to stop creaking, proper gear changing (he runs campy), again, priceless. When showing them on any assembled bike how the Shimano chain is too wide and touches the cogs, the stun effect is complete: "It never could work??!?!?"
Replaced my Gore cables as their own PTFE had began wearing on the inside and shifting was marginally compromised (nothing as bad as Shimano after 1 weeks). Only did it as a rear hanger snap destroyed my DA cassette while riding, and we opened it up and also redid the cable. 6500 kms. Sixty five hundred kms. AND...
.... After removing the cables, I stripped the PTFE coating from both, and they ARE AS GOOD AS NEW, ready to go. 6500 kms aggressively ridden Gore cable, now just a shiny glossy cable, no compression, no permanent bends, looks as if new out of the box. While waiting for Yokozuna cables to arrive, tried the top Teflon-covered Jagwire for two rides and they began shifting erratically after 100 kms. When pulling them out, their Teflon coating was coming off and the cables were permanently bent.
Am presently running Yokozuna on both bikes, again, terrific performance- NO PTFE to worry about. The Gore cable is going on whatever next job- whenever am replacing cables again.
BTW the new 9100 cassette is supposedly running carbon as well, the lesson was evidently not learned... We get what we pay for, and 9000/9100 cables, chain and cassettes are overpriced rubbish junk.
At this point have amassed over 10,000 kms riding two Shimano bikes with SRAM 1190 hyperglide, Campy/SRAM chains, Gore and Yokozuna cables- flawless...
I switched about 12 months ago to the DA9000 cassettes on both my wheelsets from SRAM 1190. Primarily due to price.
Anyway, not one issue with them. One is on a DTSwiss 240s rear hub, the other on Reynolds Strike SLG factory hub.
I did switch to the newer Jagwire cables, they works much better than the previous iteration.
I must say though, the SRAM XG-1190 steath ring 11speed cassettes, that are 1 piece, are quiet and really nice. Just the price is darn near 2x of the Shimano DA.
Of course, the prices have started to drop a bit on those even. Think I paid around $130ish for the DA9000 last year. The SRAM is still $200+++?!?!
When the DA wear out, going back to the SRAM. They are overall better IMHO.
Sorry if somebody mentioned a solution to the creaking. I skipped all the posts between the 1st and last pages.
The creaking results from the carbon fiber cog carriers chafing against each other. Putting a thin layer of grease between the two carriers solved the problem for maybe a hundred miles, only. So I put a thin layer of teflon tape directly on the carbon fiber piece - actually split the tape down the middle to create a 5mm x approx 150mm strip. No more creaking, ever.
Successfully employed the same tactic on 7900. Works like a charm.
Oldbie
Shimano's lead Technical Instructor Nick Murdick explains more in a response to a bike rumour article. http://www.bikerumor.com/2014/06/06/shi ... -creaking/
I don't care about the creaking I care about the breaking .... it's clear from the number of post broken cassettes that unacceptable that there is an issue and it's unacceptable that Shimano isn't replacing them.. there are even a few of the V2 cassettes failing ....
C
C
tb123 wrote:Don't think I would bother wasting my money on the high end cassettes, Ultegra is just fine.
that
uraqt wrote:I don't care about the creaking I care about the breaking .... it's clear from the number of post broken cassettes that unacceptable that there is an issue and it's unacceptable that Shimano isn't replacing them.. there are even a few of the V2 cassettes failing ....
C
I got mine replaced under warranty, it was about 10 days short of 3 years when it broke (it had spent some time in the cupboard during that period).
