It is currently Sat Jun 24, 2017 4:57 am
Post new topic  Reply to topic  [ 5 posts ]
PostPosted: Thu Sep 12, 2013 11:22 am
Anyone knows the capacity of a Campy Super Record EPS rear derailleur? I'm planning to use a 52/36 combined with either a 12-27 or 12-29, but I'm a bit worried about exceeding max capacity. For mechanical RD, I can always use a medium cage, but it doesn't seem to be such a thing for the EPS...
PostPosted: Thu Sep 12, 2013 12:49 pm
Assuming the geometry is the same (which it is) as mechanical, then the answer would be in the range 30-31T max total takeup, IF you want to be able to cross-chain both ways.
So, 52 - 36 = 16T. leaving 14T max for the cassette. So a 12-27 is stretching things at 15T. Chain length is critical in this whole discussion.
Alternatively, if you promise not to cross chain into the small-small combos, then you can go wider range. Just size the chain on the big-big for safety, and remember that the RD will run out of capacity as you approach the small-smallest sprocket. So, if using the 52-36 and 12-29, the chain, if correctly sized, will start to sag around the 36-14 point. So, still quite safe and useable.
Also if using a 29T sprocket on mechanical, it's worth checking and backing out the "H" screw for max clearance. Don't know how EPS RD handles this, but there's always the instructions. :) Regardless, it is compatible with a 12-29 cluster.
edit.
Just checked the tech specs. EPS and mechanical RD's have the same takeup capacity, since their sprocket spacing is the same at 55mm. The same as the previous generation also.
ps. loved that the EPS battery has a case of
Quote:
Fireproof technopolymer
. Good to know in case your bike is trapped inside a burning building.
There's sometimes a buggy.
One.
PostPosted: Fri Sep 13, 2013 11:42 am
Thanks for the great and detailed info! 12-27 with 52/36 would give her the range she needs in all terrain we ride in. Right now, her bikes are all 53/39 with 13-26 or 13-29 cassettes (swapping to fit the terrain).
PostPosted: Fri Sep 13, 2013 12:47 pm
Advise buying the KMC 11-spd chain link. Makes correct sizing of the chain so much easier. Works great. No finicky pins or fancy chain tool required.
One.
PostPosted: Fri Sep 13, 2013 11:18 pm
Already planned to use the KMC X11SL chain. Have very good success with the X10SL...
There are no new unread posts for this topic. Campy Rear Derailleur Compatibility
tomato89
Mon Nov 21, 2016 2:44 am
joeyb1000 View the latest post
There are no new unread posts for this topic. Attachment(s) New??? Rear derailleur Dura-ace 7970-A
Ritxis
10
1566
Thu Jan 26, 2017 11:30 pm
ooo View the latest post
There are no new unread posts for this topic. Sram CX1 shifters and X01 rear derailleur
bikemaniack
7
575
Fri Jul 29, 2016 6:38 am
kman View the latest post
There are no new unread posts for this topic. 3D printing rear derailleur hanger
ChristianB
Wed Jul 20, 2016 7:14 pm
Camilo View the latest post
There are no new unread posts for this topic. Switching rear derailleur pulleys from 11t to 13t - is it possible?
alcatraz
Wed Oct 12, 2016 8:03 am
Marin View the latest post
Users browsing this forum: Baidu [Spider], LouisN, Yahoo [Bot] and 52 guests
